03-13-2014, 23:16 | #1 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2147269 Status: Offline Thanks Meter: 0 | Asha 300 camera, Operation failed. I've got a problem on my asha 300, when i try to open the camera it says operation failed, camera is on standby. I've cleaned the memory(also the memory card) and reset my phone but i still get the same problem. Any help? |
03-14-2014, 03:39 | #2 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | In Nokia Asha 300 Camera Not Working problem can occur because of the faulty Camera Module or it’s bad connection to the Cell Phone’s Motherboard. So first of all you should clean Nokia Asha 300 Camera On Standby Ways and Motherboard of the Mobile Phone. If that does not work then you can replace the Camera Module. Sent from my iris458Q using Tapatalk |
03-14-2014, 14:18 | #4 (permalink) |
Member: 2141811 Status: Offline Thanks Meter: 38 | Small Yellows Lines around the camera Module in First Diagram represent Camera Connector Legs 6 above and 6 below. Replacing camera module or camera connector is recommended, Jumper Only if a leg is broken. Sent from my iris458Q using Tapatalk |
