04-21-2013, 14:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1711671 Status: Offline Thanks Meter: 11 | Asha 308 simlock invalid Using device: USB ROM and HTI, FW ver: 00.50, SN: [0000000 [/B]Connection status: OHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: rm838__05.85.mcusw [XG223,XG223_V0 ALG] size: 30.58 MB Supported Ids: 00000C2016100040 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049922C09A2C1A9B490442D00 [XGOLD 223] CMT PUBLIC ID: 8B0B143B372F17A249922C09A2C1A9B490442D00 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x0 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Invalid Certificate Data, backup will not be created. CMT PAPUBKEYS HASH: FAF910DA218D8536CEFBDCE369A8C034160C6A5F Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 38.87 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [400A0000-4251FFFF] CMT FLASH,NOR area [42520000-4261FFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent CMT PAPUBKEYS: FAF910DA [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 46.688 s Processing PPM file: rm838__05.85.ppm_mh [XG223,XG223_V0 ALG] size: 7.49 MB Supported Ids: 00000C2016100040 Erase size: 9.87 MB CMT FLASH,NOR area [42620000-42FFFFFF] erased in 0.016 s Flash programming ... Programming completed in 8.016 s Processing CNT file: rm838__05.85.image_mh_059N7Z4_059Q756_235_01 [XG223,XG223_V0 ALG] size: 49.38 MB Supported Ids: 00000C2016100040 Erase size: 78 MB CMT FLASH,NOR area [43000000-47DFFFFF] erased in 0.016 s Flash programming ... Programming completed in 1 min 11.453 s Total time for flashing process(boot+erase+write) was 2 min 11.172 s Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 19B0F8CE Waiting for USB device removal ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: AB84696 Verifying communication to device OK. Phone type: RM-838 (Nokia 308) SW version: V 05.85 23-10-12 RM-838 (c) Nokia Imei plain: 12345610654321-? Battery voltage: 4039 mV, current: 138 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: 0A350160XXXXXX, ver: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
