05-19-2007, 11:12 | #1504 (permalink) |
Junior Member Join Date: Dec 2004 Age: 45
Member: 101168 Status: Offline Thanks Meter: 0 | cable I have a DKU-5 Serial Com Cable and a Nokia n70 I am trying to unlock; The software reads the phone When I click on make log it says "Error: Bad Connection! (Check Fbus cable, turn off/on phone, restart programme, etc..)! What am I doing wrong here? Has anyone had the same problem? Thank You |
05-19-2007, 11:30 | #1506 (permalink) | ||||
Freak Poster Join Date: Jan 2004 Location: UK -Leicester
Member: 51517 Status: Offline Thanks Meter: 24 | Quote:
what are you on about upgrade version??? if your phone is a N70, 6680 or 6630 it will work, it not one of these phone, it won't work Quote:
2. close any program that loads up after 10 seconds 3. open bb5_unlocker.cfg with notepad 4. change the com port number to your com port 5. go back to c:\bb5_unlocker 6. run BB5logunlocker.exe 7. Click READ PHONE 8. Click MAKE LOG, log will be created 9. go back to c:\bb5_unlocker\ and run BB5_calc.exe, 10. Enter codes to phone (in c:\bb5_unlocker\psw\) OR Click SP UNLOCK to enter codes via FBUS | ||||
05-19-2007, 14:15 | #1512 (permalink) | |
Junior Member Join Date: Oct 2003 Location: alive and well
Member: 40693 Status: Offline Thanks Meter: 0 | Re Quote:
Be sure that my BB5 logger is installed properly with apropriate FBUS interface (DKU-5) or old clasic FBUS cable connected to standard COM port. Start loger. Once connected phone by FBUS interface to PC, press "Read Phone" button. If everything is ok, some data will be readed and displayed, otherwise check your connection, phone, cables, etc. If logger shows message "SP Data IS corrupted" than you have phone that somebody played with it and destroyed field 308,1. So, you have to fix that field by sending that phone to official NOKIA repair centre!!! If everything is OK you can press "Make Log" button. LOGER will create backup of field 308,1 and try to make LOG file. In that proces, some time field 308,1 can be corruted which can be checked by clicking again on "Read Phone" button. NOW, if logger shows message "SP Data IS corrupted" than you just have to click several times "WR Backup" and "Read Phone" to check that is your phone is OK. B.R. Dejan Please use the search button this is from his thread | |
05-19-2007, 17:12 | #1515 (permalink) |
Junior Member Join Date: Nov 2006
Member: 402429 Status: Offline Thanks Meter: 0 | I'm trying to unlock 6630 but when i try to make log file then phone hung & after that it give an error msg. when i'm trying to read the phone then it provided sp data corrupted. i try to give backup but some time it show ok & again corrupted. after write the backup when i start the phone some time it show that contact retailer. how should i can fix the problem pls help me... |
BB5 unlock 6630,6680,6681,n70,etc.. | atul_799 | Nokia Hardware & Hardware Repair | 4 | 05-13-2007 17:44 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | psycho_UK | Nokia Base Band 5 ( BB-5 ) | 3 | 05-13-2007 03:02 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | graca | Universalbox | 3 | 05-12-2007 21:01 |
