05-12-2007, 17:05 | #46 (permalink) |
Freak Poster Join Date: Oct 2003 Location: nigeria
Member: 41664 Status: Offline Thanks Meter: 37 | You Are 2 Much And maybe some of the people who have used it succesfully give us more info on HOW. Hope this works ...DEJAN you are too much.... justx24 |
The Following User Says Thank You to justx24 For This Useful Post: |
05-12-2007, 17:09 | #47 (permalink) | |
Freak Poster Join Date: May 2004 Location: Ukraine-Lugansk Age: 44
Member: 67246 Status: Offline Thanks Meter: 70 | Quote:
This language is no more different with Poland, Chech , Slovak, Ukrainian, Serbian. Horvatian and almost other languages And rememmem about Russian language better english and not cheap | |
05-12-2007, 17:11 | #50 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | proud to be serb today:-) c'mon people,dihd he ever published non-working sw??? we can expect all box manufacturers will implement this calculator in very short time... |
05-12-2007, 17:13 | #53 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | My instructions: 1. Connect DKU-5 or normal COM cable to computer 2. Set proper COM cable (must be, between 1 and 9) 3. Download unlocker, run `install.bat` 4. Open file c:/bb5_unlocker/logs/bb5_unlocker.cfg and write here proper COM port (1-9) 5. Run c:/bb5 unlocker/BB5logunlocker.exe 6. Click READ PHONE 7. Click MAKE LOG, log will be created 8. Enter codes to phone (in /psw/ dir), or 9. Click SP UNLOCK to enter codes via FBUS Done |
05-12-2007, 17:14 | #54 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Around the world Age: 56
Member: 106484 Status: Offline Thanks Meter: 400 | ******* CONECTION ****** For this program you need Fbus cable like DK5, CA43 or similar conected to ports from COM1 to COM9. First unpack zip fiole and strat install.bat In file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" with any text editor change your COM port setings! ******* USING ******** Program can be started successfully only if is COM port in file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" adjusted properly. READ PHONE: *********** Reading info data from phone and making BACKUP file for that phone( Field 308,1). IMPORTANT DO NOT delete or modify that file because can save your *** if something goes wrong. WR BACKUP: *********** With that function can write backup file with Field 308,1 if exist in BACKUP folder. MAKE LOG: *********** Function for making log file . With that log file BB5_calc.exe calculating codes for unlock. Working with BB5 phones with RAP3G v.2.x (6630,6680,6681,6682,n70,n90). IMPORTANT phone must be without Sim card. SP UNLOCK: *********** Making unlock with codes calculated by BB5_calc.exe. SP UNLOCK PROCEDURE Connect cable to PC and be shure com port is adjusted properly Start BB5logunlocker.exe Connect phone and switch on without Sim card. press button READ PHONE and wait until get the message DONE. If is everything correct you will see info from phone on screen. Pres button make log and wait until get mesage done. Log file is in folder LOGS. Start BB5_calc.exe to make for you PSW file in folder PSW Press button SP UNLOCK and unlock your phone. That is all folks If you got unlock codes from your provider and you used all yours 3 attempts to enter code via keypad then do the following: into dir "c:\bb5_unlocker\psw" create a file "aaaaaaaaaaaaaaa_BB5.psw" where is "aaaaaaaaaaaaaaa" enter your phones imei then in that created file enter in the files start "#pw+bbbbbbbbbbbbbbb+c#" where is "bbbbbbbbbbbbbbb" enter your unlock code and where is "c" enter your logs level number (1-7). save the file and use "SP UNLOCK" function |
05-12-2007, 17:14 | #55 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | And yes, i readed Serbian instrucionts without problems, all western-europe lanugages are similiar (expect Russian cirillica ) Pozdrav |
05-12-2007, 17:18 | #57 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
Between slavic and latin language is too much difference for me, i preferr learning chinese | |
05-12-2007, 17:19 | #58 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | i wonder if i could go back in time and stop dejan somehow to take that step. total loss to gsm industry,, 2nd time in this same week. (db2020 last week bu setool) |
05-12-2007, 17:21 | #60 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | i've instaled Dku5 cable , selected to com2 , i compare it with that one in config file, but when i run bb5unlocker i get msg : unable to open com port! can any1 help me what im doing wrong ? Pali |
BB5 unlock 6630,6680,6681,n70,etc.. | atul_799 | Nokia Hardware & Hardware Repair | 4 | 05-13-2007 17:44 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | psycho_UK | Nokia Base Band 5 ( BB-5 ) | 3 | 05-13-2007 03:02 |
BB5 6630,6680,6681,n70,etc... SP UNLOCKER!!! | graca | Universalbox | 3 | 05-12-2007 21:01 |
