02-21-2006, 15:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | BB5 proto type - Repair solution needed the imei was 0044 after flash changed to 12345610654321? phone working with contact retaulire Is there any way to repair the phone with hardware solution ? i know there is no way with software or i am wrong ? |
02-21-2006, 16:23 | #2 (permalink) |
Junior Member Join Date: Sep 2005 Location: in the pub Age: 50
Member: 185726 Status: Offline Thanks Meter: 4 | 6680 flashing what method of flashing are you using.... if you can see the option try ui options...full ui defaults,ui factory defaults, full factory defaults,soft upgrade defaults,, hope this helps... |
02-21-2006, 16:27 | #3 (permalink) |
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | i used fps10 - jaf - twister - phonix nothing help proplem wit imei make proplem to start the phone in normal mode only contact retaulire and now way to format it |
02-21-2006, 22:00 | #5 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Jo Age: 45
Member: 36706 Status: Offline Sonork: 100.58560 Thanks Meter: 122 | mostafa u need full certifecate recovery using ur fps10 .. but u must find some one to calculate ur log file .. from offecial nokia service center . |
02-21-2006, 23:28 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Europe Age: 44
Member: 126827 Status: Offline Sonork: 100.70299 Thanks Meter: 60 | prototype BB5 phones have empty RAP3G CPU and special patched firmware when ever you flash prototype phone you will get corrupted imei and security area. thats normal, unless you flash with prototype firmware which is available only for R&D right now there is no any solution to refill RAP3G not even by FPS-10 & RPL the only solution for your phone is to replace RAP3G and NOR flash from working phone ,same as H/W unlocking method hope that my reply help you |
***sl3 bb5 imei 12345? Repair solution with video*** | UHK | Nokia Base Band 5 ( BB-5 ) | 53 | 01-04-2012 08:01 |
nokia 7600 proto type | simfree | Nokia Multimedia | 1 | 01-11-2004 20:02 |
S46 repair solution needed ! | ficho | x1x to x45/x50 | 0 | 11-23-2002 18:28 |
SAGEM 939 repair solution needed | NBG | Infineon C16X M51 & ARM7 M52 BASED | 0 | 03-19-2001 23:47 |
