Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-17-2007, 04:11   #91 (permalink)
Member: 198040
thanks for the directcom setup
Old 05-17-2007, 12:26   #92 (permalink)
RsT
Member: 27309
Thanks Meter: 2
Couldn't find my DKU 5 cable from yr's ago, so went out and bought a cheap **** CA42 cable (non official). They told me this is the same cable as the DKU 5 anyway. Not sure that it is, but it works just fine
It just unlocked my 6680 and N70 without any major problems.
If you connect the phone up, hit read, and that bit's ok.
Hit make log, if the phone reboots and you get an error, clear that error, then wait till the phone has just booted and hit make log again.
This works for me.
Old 05-17-2007, 13:38   #93 (permalink)
Member: 269459
hi,i also have ca42 cable not original i think,and drivers dont work...maybie i dont know something,but this cable works for me how usb cable,how to create com port.can you help? can somebody send me working drivers,i tried some drivers they dont work...
Old 05-17-2007, 21:48   #94 (permalink)
LAD
Member: 51517
Thanks Meter: 24
if you can't get the DKU-5 or CA-42 cable to work, and u have some soldering skills, make this:
Serial Com port to Nokia Pop Port Cable (for BB5 unlock) - Tested
best of all...no drivers needed, just a PC/Laptop with a COM port!! (and some soldering skills)
Enjoy!
Old 05-20-2007, 10:41   #95 (permalink)
Member: 258761
Thanks Meter: 27
Originally Posted by Kevbodian View Post
1. connect UFS to computer
2. open directCOM.
3. setup COMPORT in directCOM and click CONNECT
4. open 'C:\bb5unlocker\logs\bb5_unlocker.cfg'
- change "comX:" to "comM:" where M = directCOM port
5. open bb5 unlocker in 'C:\bb5_unlocker\bb5logunlocker.exe'
6. click READ PHONE and wait
7. click MAKE LOG and wait
8. click READ PHONE (make sure SP area not corrupted, if corrupted click WR BACKUP and READ PHONE until it doesnt say corrupted)
9. click SP UNLOCK. if you get the message about "psw" needed, close BB5_unlocker and open BB5_Calc, you should get message "*****DONE*****"
10. open BB5_unlocker, click SP UNLOCK, wait for message.
sir What cable shoud i use?? the 6680 rj 45 or the dku 5
Old 05-21-2007, 03:44   #96 (permalink)
cairnquay's Avatar
Member: 64893
Thanks Meter: 220
If you have ufs and com emulator then you can use 6680 RJ45 cable
otherwise you need to use dku5 usb cable. Some types work and some types dont
Old 05-21-2007, 09:02   #97 (permalink)
Member: 201126
any solution for sp area corrupted
is it use without hwk
Old 05-21-2007, 19:46   #98 (permalink)
Member: 509037
my english is bad so
i have problem : i have got NK 6630 Ver. 3.45.113 04-01-05 RM-1 he has got a simlock for english T-mobile i download your program and connected to cable DKU-5 and press "Read Phone" and program read it, but i press "Make Log" and have got this masage please help ;[
[IMG][/IMG]
Old 05-30-2007, 05:05   #99 (permalink)
Member: 434533
Thanks Meter: 20
phone damaged with bb5 unlocker..plz help
this is what ive done..
1.set the port number
2.install.bat
3.read phone..done
4.make log..( cannot make log for this phone)
now the phone display invalid sim even i puit in vodafone sim.. plz help..
i have done write backup many times but still cannot..plz help..
Old 05-30-2007, 12:24   #100 (permalink)
EBRJO's Avatar
Member: 105175
Thanks Meter: 31
maybe phone is 4 locks already, that why it say invalid sim or even vodafone sim... maybe you'll wait for the update of the bb5 unlocker that can unlock 4 locks...
Old 08-10-2008, 17:53   #101 (permalink)
Member: 503210
http://www.schwantz-i.org/nokia/DirectCOMsetup.zip
matur nuwun mas bos
Old 09-15-2008, 20:40   #102 (permalink)
pakstar's Avatar
Member: 59991
Thanks Meter: 40
2. open directCOM.
many thanks for your helpful instructions. managed to unlocekd 6630 using DKU-5 cable
Old 10-11-2008, 13:37   #103 (permalink)
Member: 590811
Thanks Meter: 5
HI everyone...
I have tried that circuit and with a dke-2 usb cable it did not work. Ive also used a digital camera cable the same as dke-2 and it dd not work they have straight through wiring for all 4 pins...the camera cable works with nokia pcsuite and the transfer is slightly quicker though, but with this custom circuit and dijan bb5 unlocker I get the bad connection error...
tried even two different com port serial cables and still no luck...
I have a Nokia 6300 and trying to unlock it...
Old 10-11-2008, 16:39   #104 (permalink)
Member: 687548
Thanks Meter: 10
N6300
Nokia 6300 don't work with Dejan BB5 unlocker
BR,
Old 10-11-2008, 22:42   #105 (permalink)
poochone's Avatar
Member: 525022
Thanks Meter: 32
No don`t work with DEJAN BB% uunlocker
Unlock 6300 with dku-5 theyikes Nokia Base Band 5 ( BB-5 ) 5 07-12-2009 16:41
Finally Got My N70 Unlocked Using USB DKU-5 CAble realmafia Nokia Base Band 5 ( BB-5 ) 4 06-24-2007 15:12
Unlocking 6680 using DKU-5 cable. ARRGGG!!! Conquerz Nokia Base Band 5 ( BB-5 ) 10 05-24-2007 17:02
BB5 Unlocker and USB DKU-5 for Nokia 6680? Sharpharp Nokia Base Band 5 ( BB-5 ) 2 05-17-2007 17:32
Page generated in 0.41349 seconds with 9 queries
