08-21-2006, 10:49 | #32 (permalink) |
Junior Member Join Date: Aug 2006
Member: 335078 Status: Offline Thanks Meter: 0 | Hello, I think that I following the guide correctly. However, during the installation of Phoenix 2006, I received two pop-up messages notifying me that it has not passed some windows logo test or something. That i can just click -continue installation. However, the real problem I run into is at the end. Whenit starts to register the files and such, and when the DESkey not found message comes up. I am unable to click ok. I try to click ok.. and a few seconds later the whole isntallation freezes up. My computer is fine, but the installation crashes. and I must end the tastk. In the end, I am unable to install this. I'm not sure why and was wondering if anyone could offer some insight. Thanks. |
08-21-2006, 19:04 | #33 (permalink) |
Freak Poster Join Date: Jun 2006 Location: pok wong malaysia
Member: 300886 Status: Offline Thanks Meter: 61 | I was successfull installed Phoenix 2006.20.9.148 with the crack. when i trying to flashing a dead phone i cant find ' DEAD PHONE USB FLASHING ' option. any idea? B.R |
08-21-2006, 19:10 | #34 (permalink) | |
Member: 335267 Status: Offline Thanks Meter: 0 | Quote:
Lets hope there is a solution to this so I can get my 6680 working again. The phone is still detected by windows but it is in ADL mode, i've tried it on two different computers and still got the same error and the error is the same even if the phone isn't connected at all. Would point towards either an error in the installation or a windows usb config error. Have tried two different cables with the same result as well. Last edited by bmh.01; 08-21-2006 at 21:17. Reason: more info | |
08-22-2006, 07:26 | #35 (permalink) |
Junior Member Join Date: Jan 2005 Location: Middle of Sweden Age: 53
Member: 104334 Status: Offline Thanks Meter: 0 | Verify Phoenix-install before flashing? Hi! The method described here seems to work perfect, much better than the Ph2004-2006 method. For now Ph 2006 starts without errors and is able to scan/identify product. It also selects the proper Image and PPM. But before i press "Start" on my girlfriends N90 i wonder if there's a way to minimize the risks of a dead phone, a way of checking the Phoenix-installation from within Phoenix? As a last resort i could always try with an older 6630 but i prefer to keep it alive too Regards, Per |
08-24-2006, 14:06 | #38 (permalink) |
Member: 337029 Status: Offline Thanks Meter: 0 | Hi People, I followed the installation instructions, except for the cable installation because I told me my exsisting versio is newer (I have the latest vesrion from NOKIA). Now when I try to run Pheonix 2006 for the first time it tells me: " Pheonix applictaion hs encountered a problem and need to close etc..." In the details it says something about the pheonix_framework.DLL - I have installed the 2006 crack properly. Please advise. Thanks! |
08-24-2006, 21:08 | #39 (permalink) |
Member: 337277 Status: Offline Thanks Meter: 0 | 6131 hi folks, I got 6131 and very unhappy. will try to flash from 03.50 to 03.70 FW. I followed all steps and chicken out on the upgrade itself. What files to use from RM-115, where is US English? what "black", "white", "Latin" mean in description in read_me.txt ? What PPM file to use? thanks anyone for the explanations. |
08-26-2006, 18:03 | #41 (permalink) |
Member: 335267 Status: Offline Thanks Meter: 0 | For anyone that has had a dead phone due to the check connections error, I don't think there is a way to recover the phone via usb. I got my 6680 stuck in ADL mode and in the end just payed to get it reflashed with a proper flashing box, its working fine again now. So all is not lost, but it is going to cost to get it working again. |
08-27-2006, 23:01 | #44 (permalink) |
Junior Member Join Date: Jul 2006
Member: 310168 Status: Offline Thanks Meter: 0 | open phoenix with your phone off but connected to pc.then go to manage connections and be sure tha t is at usb.select product rm-xx.now goto flashing-sw update and wait to finish scan.dont worry it will find nothing.then go to code area and select your firmware from the drop down menu.select it and push start to flash the phone.push yes to both of windows that will appear.at the end you will have a full working phone.good luck. it worked for me n80 after a fault update and mine was dead.you can do the same procedure in some phones with manage connection to no connection after you select phone product. |
08-28-2006, 10:44 | #45 (permalink) |
Member: 339279 Status: Offline Thanks Meter: 0 | I am unable to download Diego v3.70 SP2 from from the following URL http://www.4shared.com/file/1509393/...diego_307.html File size is 0 Does anyone have another link ? |
Best way to install Phoenix 2006.20.14.153 | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-09-2013 02:02 |
Best way to install Phoenix 2006 without any dongle | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 10 | 07-31-2007 11:00 |
How to flash "dead" N80 with Phoenix Service Software 2006.20.9.148 | aeomholt | Nokia Base Band 5 ( BB-5 ) | 4 | 07-10-2007 22:21 |
Phoenix 2006.20.9.148 & Nokia 6101 Connection Issue | kingshweaty | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 12-08-2006 19:00 |
N73 dead after flasing phoenix 2006.20.9.148. Please help | technod | Nokia Base Band 5 ( BB-5 ) | 12 | 09-13-2006 20:46 |
