Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 08-28-2006, 12:40   #46 (permalink)
Member: 338529
Hey. All same s/w find at http://nokia.dogtoe.com/files/diego/
Old 08-28-2006, 13:10   #47 (permalink)
Member: 338699
there are no Nokia Diego v3.07 Sp2.msi
there are only Diego_3_06.msi
Anybody!
give us another link!!!!!!!!!
Old 08-28-2006, 13:13   #48 (permalink)
Member: 339355
succesfully flashed a 6233 to 4.52
this method is brilliant works perfectly thankyou
for those wanting diego 3.07 u can use http://www.4shared.com/file/1925302/...o_307.html?s=1
if that doesnt work goto 4shared.com and search diego there are several other links that will work
Old 08-28-2006, 21:20   #49 (permalink)
Member: 230913
Please, help me guys!! I did everythink in the right way, but when I try to flash after installing the firmware I have this message:
Matching Adl loader was not found on this device. Flashing failed. FPI no loader found.
Where I make a mistake?
Old 08-28-2006, 23:42   #50 (permalink)
Member: 339692
Thanks Meter: 11
>duffuduck70 check f/w you are going to install, if it doesn't help, reinstall phoenix 2006. This is not the proffessional way of servicing cellphones, but the easy one
If u miss some software, contact me via personal msg or mail.
Old 08-29-2006, 15:11   #51 (permalink)
Member: 116970
Thanks Meter: 3
Originally Posted by Perus View Post
Hi!
The method described here seems to work perfect, much better than the Ph2004-2006 method. For now Ph 2006 starts without errors and is able to scan/identify product. It also selects the proper Image and PPM. But before i press "Start" on my girlfriends N90 i wonder if there's a way to minimize the risks of a dead phone, a way of checking the Phoenix-installation from within Phoenix?
As a last resort i could always try with an older 6630 but i prefer to keep it alive too
Regards,
Per
i have same problem any way for solved it
Old 08-29-2006, 19:11   #52 (permalink)
Member: 230913
Thank you for the tip, but the phone shows always the same error message.Probably I do something wrong. For example, after Installing everything in the right way, I connect the usb cable to the phone and computer while turning it on, but It can't install cable drivers. So after this I Install manually Usb Connectivity cable drivers from Nokia and It recognize it? Does it depends on that?? What Can I do if I Install the drivers in the wrong way???
Anyway, phenix shows at the bottom the actual firmware, so that means there is a link among t phone and computer!!! What Can I do???
Old 08-30-2006, 02:03   #53 (permalink)
Member: 338529
Did anyone flash 6230i same way? I think it needs a prommer now
Old 08-30-2006, 18:48   #54 (permalink)
Member: 339982
her is guide to repair dead phone after bad flashing.
http://rapidshare.de/files/31343354/...efonu.rar.html
and here is Phoenix framework.dll
http://rapidshare.de/files/31343689/...ework.dll.html
Old 08-31-2006, 12:16   #55 (permalink)
Member: 338529
No man, I did not start flashing procedure via USB with 6230i
I just wonder, how can this be made with this model?
With BB5 phones it's absolutely no problem. But for 6230i it asks for smartcard pin and other nonsenses..
I work with FPS8, FPS10, but I wish to find out the way to solve this matter via USB only.. please HELp me!!!
Old 09-03-2006, 21:32   #56 (permalink)
Member: 342994
PLEASE say me a link for download last V. PHOENIX & DIEGO.( Some link u say don't work.)
Old 09-03-2006, 22:36   #57 (permalink)
Member: 341548
Latest phoenix
Latest phoenix version 153 thanks to madcorny
http://rapidshare.de/files/30674808/phoenix_service_sw_2006_20_14_153.rar.html
Old 09-03-2006, 23:57   #58 (permalink)
Member: 342994
http://rapidshare.de/files/30674808/phoenix_service_sw_2006_20_14_15 3.rar.html
Say other link please.
Old 09-04-2006, 10:33   #59 (permalink)
Member: 343265
I updated an N80 (01) that I am using in Australia to firmware V 4.0623.0.41 (EMEA version) using this method. Everything worked very smoothly. Thanks very much for the post.
Old 09-04-2006, 22:58   #60 (permalink)
Member: 341548
New Link
Try This:
http://rapidshare.de/files/30611588/phoenix_service_sw_2006_20_14_153.exe.html
Best way to install Phoenix 2006.20.14.153 cprasad7 Nokia Base Band 5 ( BB-5 ) 3 07-09-2013 02:02
Best way to install Phoenix 2006 without any dongle cprasad7 Nokia Base Band 5 ( BB-5 ) 10 07-31-2007 11:00
How to flash "dead" N80 with Phoenix Service Software 2006.20.9.148 aeomholt Nokia Base Band 5 ( BB-5 ) 4 07-10-2007 22:21
Phoenix 2006.20.9.148 & Nokia 6101 Connection Issue kingshweaty Nokia Digital Core Technology 4 ( DCT-4 ) 0 12-08-2006 19:00
N73 dead after flasing phoenix 2006.20.9.148. Please help technod Nokia Base Band 5 ( BB-5 ) 12 09-13-2006 20:46
Page generated in 0.27498 seconds with 9 queries
