10-24-2006, 19:53 | #1 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 317218 Status: Offline Thanks Meter: 7 | Best way to install Phoenix 2006 without any dongle 1 - Windows XP Sp 1 or higher / Windows 2000 Sp 3 or higher 2 - Nokia Diego v3.07 Sp2 3 - Nokia Dongle Crack 4 - Phoenix 2006.xx.xx.xxx (Always try to find the latest version) 5 - Phoenix 2006 Crack Before you begin disconnect any Nokia phone connected to the PC and uninstall Nokia PC suit, cable driver, Phoenix or Diego which you have already installed. Then Follow these steps 1 - Install Nokia Diego 3.07 Sp2 2 - Open the Phoenix Dongle crack but don’t run it now 3 - Start installing Phoenix 2006 during the installation it will prompt you for the Nokia Dongle. 4 - Press on “Retry” and run the crack immediately. Then press “Yes to all”. If you have done this correctly it will continue installing Phoenix 2006 5 - It will stop installing Phoenix 2006 with a message “DESkey not found” click on “yes” twice. Then it will continue registering DLL files.(In some cases you will not get this message in this step.You will get it after restart your PC if prompted) 6 - If it will prompt you to restart windows, you must restart windows. (Sometimes it will not prompt you to restart windows) 7 - Then Run Phoenix 2006 crack.(Set the path if you have changed the installation path of Phoenix when installing it at step 3, otherwise use the default location) Now it is ready to continue with your Nokia phone. Good luck for all. Thanks |
10-30-2006, 11:28 | #7 (permalink) |
Junior Member Join Date: Oct 2006
Member: 363942 Status: Offline Thanks Meter: 0 | I've installed it successfuly but it doesn't detect my Nokia 6630 when i attach it with PC using DKU-2 Cable. I want to Upgrade my Firmware from 5.03.08 to 6.03.08 but Phoenix doesn't detect it. please help |
10-30-2006, 15:59 | #8 (permalink) | |
Crazy Poster Join Date: Oct 2006
Member: 371214 Status: Offline Thanks Meter: 0 | Quote:
Choose Nokia 6630 but check it first *#0000# for sure (RM-1). | |
10-30-2006, 19:51 | #9 (permalink) | |
Member: 317218 Status: Offline Thanks Meter: 7 | Quote:
Thanks | |
Best way to install Phoenix 2006.20.9.148 | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 189 | 10-11-2013 05:28 |
Best way to install Phoenix 2006.20.14.153 | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 3 | 07-09-2013 02:02 |
Best Way To Install New Ust Pro Ii ? | neo_49 | UST Pro II | 7 | 06-28-2007 07:41 |
Best way to install any later version of Phoenix 2006 and USB Dead phone flashing | cprasad7 | Nokia Base Band 5 ( BB-5 ) | 16 | 06-25-2007 21:58 |
Best way to install Fighter onto XP | Mastah-GSi | Cruiser Suite | 11 | 03-13-2005 19:31 |
