Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
View Poll Results: 5130 NOKIA LOGO THEN TRUN OFF
SOFTWARE 49 48.51%
HARDWARE 45 44.55%
I DONT KNOW 7 6.93%
Voters: 101. You may not vote on this poll
Old 04-28-2011, 07:03   #181 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Originally Posted by bhavik1312 View Post
I HAVE NOKIA 5130c2 WHEN I INSERT THE SIM ERROR IS "ENTER RESTRICTION CODE" SO HOW CAN I GET THIS CODE SO REPLY ME IMEI 35422/03/989296/3.
bro i think ur phone simlocked or sl zone damaged
u can show me info details i will check it then give result
Old 04-28-2011, 07:04   #182 (permalink)
Member: 351924
Originally Posted by guljee786 View Post
SHIJILFONOTLY
shigi bro i see that u have lot off informetion abut mobile hardware ok i have a 6120c , beore when i flash problem is that when on its show nokia then off i flash it with higer vertion now set is totlly dead i also wash mother board.. and then flash but no luck
now in flashing eror is
1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5
Block Length : 0F
BB ASIC Index : 00
Error Type : 01
Error Spec : 06
Of*****ng Address : 00084400
Expected Content : 00004F10
Detected Content : 0000FFFF
Try to change the Flashing clock...
what can i do confused.
Guljee
brother problem CMT flash damaged u can try to reflow combo then try again.but one this water entry phone is cause some time avilam
Old 05-04-2011, 18:48   #183 (permalink)
ham_sang's Avatar
Member: 901472
Thanks Meter: 48
Originally Posted by SHIJILFONOTLY View Post
brother u know this phone cant enter local mode and test mode then how can format this phone!!!!!!!!!!!!!?
i used Fluke Electronics multi metter
same working on oscilloscope
brother,fluke electronics multimeter good? this tool help alot ?
Old 05-05-2011, 06:50   #184 (permalink)
Member: 351924
sure but u need to study use this multi meter
search google then u got a mannuls
Old 05-12-2011, 21:10   #185 (permalink)
ramjan_777's Avatar
Member: 1226253
Sonork: 1602755
Thanks Meter: 69
dear.all good solution 5130c heat fully
bout and water cool solve 101%
Old 05-23-2011, 05:55   #186 (permalink)
Member: 1406553
Thanks Meter: 2
can anyone post picture for that problem.....
Old 05-24-2011, 08:21   #187 (permalink)
Member: 341171
mostly this problem happens with "Silver 5130C-2" Models i have 6 phones with same problem, and try most firmwares, but no solutions
Old 05-24-2011, 09:29   #188 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
i solve some sets with this fault steps r theses
1. flash with 7.97
2. remove camera
3. remove bt ic
4. rehot cpu
all 4 methods r working thats is from me
Old 06-08-2011, 15:24   #189 (permalink)
Member: 750538
Sonork: iloveu
plz helpvery urgent 7210c black secreen nokia logo hang remove camera bt ic usb ic bettyic heat up but seam
Old 06-08-2011, 15:46   #190 (permalink)
Member: 942817
Thanks Meter: 20
please make new treadh or search with same type of problem
Old 06-08-2011, 22:57   #191 (permalink)
Crazy Poster
Member: 1540613
Sonork: papi77
Thanks Meter: 4
Hi to all
Can somebody send me the solution of Nokia X3 the fone empties the battery very quickly, I changed the battery but no result.
If any picture help to my email [email protected]
Thnx in advance
Old 06-29-2011, 13:19   #192 (permalink)
Member: 485404
5130 n 2700c show nokia logo then turn off
Old 07-02-2011, 14:51   #193 (permalink)
debapra_gsm's Avatar
Member: 1247853
Thanks Meter: 71
A1)flash lhe phone higher version via usb or Fbus
2)usb flashing time computer show usb error?
must check usb connector usb controll driver(remove usb esd)
usb flashing and fbus flash 100% done?but phone same nokia logo then trun off?
B1)open handset then check display connector or change display(display also make this problem)
2)remove camera and power on phone with battery,phone still same problem(nokialogo then trun off)???
3)check vcore,vio,vdram vrfc volt
this 4 volt controlled by combo ic
vdram,vrfc,vio volt controlled by AVILMA
Vcore controlled by BETTY
this 4 volt is prefect???then one thing is conformed avilma betty working fine
4)reflow or change keypad ic
5)Remove MMC ic
6)BT ic also make this problem(6120 75% nokia trun off bt ic)
7)finaly reflow or change combo ic
no more option like this cause
thank u for very nice to runing this discussion
special thanks go to ktkwajid,neilthirumuttam
http://forum.gsmhosting.com/vbb/f656...splay-1293685/
Old 07-02-2011, 15:04   #194 (permalink)
rajeesh007's Avatar
Member: 622323
Sonork: r@j#e$h007
Thanks Meter: 18
hi all, this problem mainly due to s/w.........first backup the sertificate area....erase only npc area...........then check local mode .if localmode ok,write hwc and ccc readed frm a ok set,then write npc frm backup.........this may help u
Old 07-02-2011, 15:22   #195 (permalink)
Member: 1247853
Thanks Meter: 71
Rajesh babu SL3 308 is write protected if one time u reset npc after that u cant restore lock data..so.....?????
Page generated in 0.23477 seconds with 11 queries
