Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-01-2011, 04:18   #1 (permalink)
Member: 1028741
Thanks Meter: 5
Unhappy Dead Nokia 6280/8 bb5 flash Help
I'm trying to flash it with JAF but got this instead
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
P-key nokia module version 01.02
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.36.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-78\
Searching for default location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\Products\RM-78\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.100.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm783006.10.ppm_s
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.10.image_ctv_sg
Languages in ppm: English,Chinese Trad ,Chinese Simpl,Malaysian
Detected P-KEY: 90009699
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
    Elf2flash 02.31.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
......Error booting phone...
Any solution to this?
Old 04-02-2011, 13:00   #2 (permalink)
Member: 1028741
Thanks Meter: 5
are there any alternative? i tried phoenix but it is very buggy
Old 04-02-2011, 13:33   #3 (permalink)
Member: 696136
Thanks Meter: 205
Rehot flash ic than try again.
B.R
Old 04-02-2011, 14:12   #4 (permalink)
Member: 1030568
Thanks Meter: 37
use ufs or mskey then post result
Old 04-02-2011, 14:15   #5 (permalink)
nadeem6677's Avatar
Member: 1252644
Sonork: 100.1602567
Thanks Meter: 47
use MX key with nokia dead usb rom.
Old 04-02-2011, 14:37   #6 (permalink)
Member: 1028741
Thanks Meter: 5
okay I tried Mx key and got this
Processing file: rm7830006.100.mcusw
--- Press phone's POWER button or connect a CHARGER ! ---
warning: Some new phones consume more power, please connect cable to USB host instead of USB hub.
[ADL] Pooling for ADL device
[ADL] Device found : nmwcdnsuc\Nokia USB Flashing Generic-35471b5e
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
RAP EM1 ID: 00000232
RAP EM2 ID: 00000352
RAP PUBLIC ID: 27D00009CF9501540B5BED44F6BE081AD2CCD990
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3880 bytes
Device IO error: A device attached to the system is not functioning (code: 31)
Flashing terminated with error(s) in 11.532 s
RX Buffer: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000
Old 04-02-2011, 14:39   #7 (permalink)
Member: 1028741
Thanks Meter: 5
I also did a successful clean install with Phoenix after several tries. Phoenix won't detect my phone(dead) although i already plugged in my charger to the phone..
Old 04-02-2011, 14:46   #8 (permalink)
cristi_slob's Avatar
Member: 631660
Thanks Meter: 134
rehot ram flash brain arm and leg...and maybe you`ll use real gsm equipment not crack`s
Old 04-02-2011, 14:49   #9 (permalink)
Member: 1028741
Thanks Meter: 5
Im using nokia dead usb rom
Old 04-02-2011, 16:21   #10 (permalink)
Member: 1028741
Thanks Meter: 5
well if there is no other solution other than replacing or reheating Flash IC. Its concluded.
Old 04-02-2011, 16:28   #11 (permalink)
rana_g_mobiles's Avatar
Member: 1421704
Thanks Meter: 63
try with fbus cable
100 fone working
Old 04-03-2011, 02:30   #12 (permalink)
Member: 1028741
Thanks Meter: 5
Does an fbus cable need some kind of box or hardware to connect? I wish a bb5 flashing for dummies book exist
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.33966 seconds with 8 queries
