Download Official Nokia Firmware Even Without Navifirm+ Here’s a trick to download official Nokia firmware without Navifirm+ Things you need: 1. Latest version of Nokia Suite (version 2013_13_4_4 download): HERE 2. usergroupsconfiguration.cfg file: HERE Installation: 1. First install Nokia Suite. Do not run after the installation is finished. http://imageshack.us/a/img836/7409/021kw.jpg 2. After Nokia Suite installs, copy and replace the usergroupsconfiguration.cfg file to C:\Program Files (x86)\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if you’re running a 64-bit version of Windows. Or C:\Program Files\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if on 32-bit. Running Nokia Suite and Downloading the firmware: 1. Open Nokia Suite. And select ‘Product Support Tool For Store 5.0′ http://imageshack.us/a/img716/8084/24676232.jpg 2. When prompted, select ‘CareSuite External’ then hit ‘Sign-in’ button. http://imageshack.us/a/img42/2152/35462266.jpg 3. From the Menu, select Tools, then ‘Firmware Download’ http://imageshack.us/a/img836/608/77295649.jpg 4. Now enter the product code of your device, hit ‘Check Online’ button, to check the latest firmware version of your product code. http://imageshack.us/a/img21/3121/061wfr.jpg 5. Then ‘tick’ ‘Optional Content Files and ‘Download’ to save your firmware. 6. Wait a few minutes for your files to download 7. You may now manually flash your Nokia device with the firmware you just downloaded. ================================================== ========================== Nokia Lumia product codes. HERE TIP: - Your firmware should be stored in the C:\ProgramData\Nokia\Packages\Products folder of your hard drive. - If you need to download a different firmware version for the same product code, I suggest you wait for your first download to finish, save all the downloaded files in a marked folder, then proceed with your next download. WARNING & DISCLAIMER: This process is for experimental purposes ONLY. I will not be responsible for any damage your device may incur during the manual flashing. PROCEED AT YOUR OWN RISK. |
i have tested this and i found that the trick is only working on Nokia Care Suit 2013_13_4_4 it does not work if version is older or newer, but it DOES work. WBR Syed |
They have problems installing the Nokia Suite with Windowa XP, since I always send this message that the installation is not completed. Can you help me know if it does not work with WinXP? |
@drozd Server Asking Some User Name And Password For It |
Where is the Username and Password please :) |
Thanks for this! can anyone help me? i had a nokia x2-02. missing record options in radio. i tried to flash in phoenix but error in digital sign etc. the flash files ive download form mrcrab. please help me guys. can work in usb method only? |
@drozd provide all product code plz help |
i was able to do that but after the download where am i supposed to find the flash files for x2-05 for example?in which folder exactly? |
is this only for Lumia? |
I downloaded the firmware How to manually flash my Nokia lumia 520 ? thanks |
when i tried to download nokia 501 flash file the error is occured like this.how to download file from nokia car suite pls help. "Access is denied. Verify credentials". |
u can use this link below to download latest firmware without user name or password; Nokia Firmware Home |
