05-27-2013, 14:28 | #1 (permalink) |
Insane Poster Join Date: Dec 2001 Location: USA
Member: 7805 Status: Offline Thanks Meter: 184 | Download Official Nokia Firmware Even Without Navifirm+ Things you need: 1. Latest version of Nokia Suite (version 2013_13_4_4 download): HERE 2. usergroupsconfiguration.cfg file: HERE Installation: 1. First install Nokia Suite. Do not run after the installation is finished. 2. After Nokia Suite installs, copy and replace the usergroupsconfiguration.cfg file to C:\Program Files (x86)\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if you’re running a 64-bit version of Windows. Or C:\Program Files\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if on 32-bit. Running Nokia Suite and Downloading the firmware: 1. Open Nokia Suite. And select ‘Product Support Tool For Store 5.0′ 2. When prompted, select ‘CareSuite External’ then hit ‘Sign-in’ button. 3. From the Menu, select Tools, then ‘Firmware Download’ 4. Now enter the product code of your device, hit ‘Check Online’ button, to check the latest firmware version of your product code. 5. Then ‘tick’ ‘Optional Content Files and ‘Download’ to save your firmware. 6. Wait a few minutes for your files to download 7. You may now manually flash your Nokia device with the firmware you just downloaded. ================================================== ========================== Nokia Lumia product codes. HERE TIP: - Your firmware should be stored in the C:\ProgramData\Nokia\Packages\Products folder of your hard drive. - If you need to download a different firmware version for the same product code, I suggest you wait for your first download to finish, save all the downloaded files in a marked folder, then proceed with your next download. WARNING & DISCLAIMER: This process is for experimental purposes ONLY. I will not be responsible for any damage your device may incur during the manual flashing. PROCEED AT YOUR OWN RISK. |
The Following 8 Users Say Thank You to drozd For This Useful Post: |
06-03-2013, 16:13 | #2 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | i have tested this and i found that the trick is only working on Nokia Care Suit 2013_13_4_4 it does not work if version is older or newer, but it DOES work. WBR Syed |
The Following User Says Thank You to Syed For This Useful Post: |
06-24-2013, 19:20 | #3 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1966218 Status: Offline Thanks Meter: 0 | They have problems installing the Nokia Suite with Windowa XP, since I always send this message that the installation is not completed. Can you help me know if it does not work with WinXP? |
07-06-2013, 05:36 | #4 (permalink) |
No Life Poster Join Date: Nov 2010
Member: 1445819 Status: Offline Thanks Meter: 4,976 | @drozd Server Asking Some User Name And Password For It Last edited by stanner_austin; 07-09-2013 at 11:08. Reason: quote removed |
The Following User Says Thank You to zoneofash For This Useful Post: |
07-07-2013, 11:59 | #7 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1974202 Status: Offline Thanks Meter: 1 | Thanks for this! can anyone help me? i had a nokia x2-02. missing record options in radio. i tried to flash in phoenix but error in digital sign etc. the flash files ive download form mrcrab. please help me guys. can work in usb method only? |
The Following User Says Thank You to baserrano For This Useful Post: |
10-10-2013, 05:49 | #12 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | when i tried to download nokia 501 flash file the error is occured like this.how to download file from nokia car suite pls help. "Access is denied. Verify credentials". |
12-28-2013, 09:05 | #15 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Goma, Democratic Rep. Congo
Member: 1859060 Status: Offline Sonork: 100.1651029 Thanks Meter: 170 | u can use this link below to download latest firmware without user name or password; Nokia Firmware Home |
