Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-22-2009, 16:17   #1 (permalink)
DEEPAK_ATOZ's Avatar
Member: 349089
Thanks Meter: 112
Lightbulb N95 8GB mass memory not available SURE SOLUTION
Hi guys,
After a long time on this fault I found the same error even after
1) Flash
2) update latest file
3) reheat hard drive
But the problem solved by changing flex cable, but in one hand set i need to change both lcd and flex .
I Done 5 handsets with same
THE PROBLEM SOLVED
TRY AND POST RESULTS
A TO Z
The Following 8 Users Say Thank You to DEEPAK_ATOZ For This Useful Post:
Old 05-22-2009, 17:33   #2 (permalink)
Member: 722274
Thanks Meter: 14
bro, how is this possible i think there is no connection between MASS memory and flex cable
Old 05-23-2009, 20:01   #3 (permalink)
cell surgeon's Avatar
Member: 698937
Thanks Meter: 85
No idea bro have anybody tested then reply..
Actually i faced the same problem before in 2 sets then at last, i solved it by re-bolling the hard drive ic..
http://forum.gsmhosting.com/vbb/showthread.php?t=612391
Old 05-24-2009, 11:36   #4 (permalink)
Member: 349089
Thanks Meter: 112
I also wondered after seen this
But it really works 4 me
you just try to use another fornt from a working set and post result
I hope it will solve your problem
just try
worked for my sets
br,
The Following 3 Users Say Thank You to DEEPAK_ATOZ For This Useful Post:
Old 11-28-2009, 13:55   #5 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
need to replace d5200
Old 11-17-2010, 11:59   #6 (permalink)
Member: 531336
Thanks Meter: 10
take solution; i"m about to test it, i will post result later //gsmnepal.********.com/search/?q=nokia+n95+8gb+mass+memory+not+available+solutio n&x=0&y=0
Old 12-08-2010, 21:07   #7 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
I have same problem in my N95 8Gb, I change the 100% working Mass Memory in my mobile, but its not working. I also make the Latest Flash file, but same position.
Old 12-16-2010, 14:55   #8 (permalink)
Member: 615730
Thanks Meter: 256
Now my problem is solved to do this Jumper 100% tested solution :-
The Following 5 Users Say Thank You to Sagitarious For This Useful Post:
Old 03-04-2011, 21:40   #9 (permalink)
Crazy Poster
Member: 1466194
Sonork: 100.86843
Thanks Meter: 8
hi i can't explain what connection between mass memory and flex cable.
but its a proved solution. I solved successfully.
The Following User Says Thank You to anoopkurumathur For This Useful Post:
Old 05-12-2011, 15:15   #10 (permalink)
Member: 494907
Thanks Meter: 2
this is not worked for me.
BR. good solution regards
Old 06-20-2011, 09:15   #11 (permalink)
Member: 615730
Thanks Meter: 256
Then you must change the Mass Memory.....
Old 03-21-2012, 22:31   #12 (permalink)
Member: 1029665
Thanks Meter: 9
just replac that small ic it well work fine 10000%
HELP: N95 8GB mass memory not available oncedotcom Nokia Base Band 5 ( BB-5 ) 16 10-06-2010 18:53
N95 8gb mass memory not available solution 100% raseelmsm Nokia Hardware & Hardware Repair 22 12-07-2009 07:10
:::Nokia N95 8GB mass memory not available.100% solution::: indikait Nokia Base Band 5 ( BB-5 ) 2 10-02-2009 19:55
Nokia N95-8GB-Mass memory not available mohibr Nokia Base Band 5 ( BB-5 ) 3 05-22-2009 16:51
N95 8gb mass memory not available coolmax Nokia Hardware & Hardware Repair 0 01-01-2009 17:50
Page generated in 0.18031 seconds with 10 queries
