03-27-2010, 15:29 | #1 (permalink) |
Junior Member Join Date: Oct 2006 Location: Doha, Qatar
Member: 373766 Status: Offline Thanks Meter: 14 | e75 no display history: sometimes displayed and sometimes not but yet recently the display went out thoroughly... action taken: change middle flex and upper flex still not working... change display ic the same thing no display... only blue light and keypad light working no display... need help please... |
03-28-2010, 11:24 | #2 (permalink) | |
Junior Member Join Date: Mar 2010 Location: Mangat
Member: 1268459 Status: Offline Thanks Meter: 9 | Quote:
1st replace LCD if not solve THEN give a little heat to CPU | |
The Following User Says Thank You to aamir.pk For This Useful Post: |
04-08-2010, 16:23 | #4 (permalink) |
Junior Member Join Date: Mar 2009
Member: 996849 Status: Offline Sonork: [email protected] Thanks Meter: 0 | thanks i will try.. by the way thank |
04-08-2010, 17:47 | #5 (permalink) |
Insane Poster Join Date: Dec 2007 Location: Caracas, Venezuela
Member: 663090 Status: Offline Thanks Meter: 25 | Be sure of conditions working for your replacements. If you change the 2 flex and the lcd the problem is obviusly in the board. Full flash with lastest firmware and then check for hardware problem. Maybe is a LIGHT problem or conector. Post results for more help. Regards |
06-30-2010, 11:41 | #6 (permalink) |
Junior Member Join Date: Sep 2005 Location: South Africa Age: 41
Member: 183157 Status: Offline Thanks Meter: 4 | I have problem with E75. When i press hard on flex connector, display comes on and flashes but after reheat display ic's and connector still same. please help |
V3 no display,no display light | celluniversal | Motorola P2k | 21 | 11-21-2011 06:57 |
L7 no display and no lights in display, tricks enside.. | ticksjarub | Motorola Hardware Repair | 4 | 09-18-2010 17:30 |
Nokia E75 No Sim Card Error | wizmanoj | Nokia Hardware & Hardware Repair | 0 | 06-22-2009 21:03 |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
V3 No Display N No Display Light? | jimmyyew | Motorola Hardware Repair | 4 | 05-27-2008 08:33 |
