04-24-2009, 00:59 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Casablanca Age: 53
Member: 146353 Status: Offline Thanks Meter: 31 | E90 communicator help needed! plz my e90 reboot itself each tme i enter WPA2 wirless key!, also somtimes gsm radio signal disapear, what's the problem is?, hardware or software, if i want to flash ,wich best firmware? thx for your help |
04-25-2009, 07:16 | #5 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
and dont be disappointed, oK anyways your phone has Restart problem, right ? i would suggest you try to repair it first by software. did you try to repair it by Formating method ? if not then do File System Formate and make Full Factory Setting then check your phone without MMC problem is solved or not ? if not then you must try to repair it by Full Flashing, downlaod and install this latest FW and flash with it, after flashing when it done successfully then use SX4 from any supported tool likt JAF, MT, or UB. . .etc and when it (SX4) done then immediately (withen 10sec) select full modified (without 308) pm to the phone and see problem is solved or not ? hope it will fixed but if still same then you have left only one way to repair it by software and that is Full Erasing, Do you know how to erase BB5 ? if you dont know then Read Here Download Latest FW here: RA-6_EMEA_300.34.84_v7.0_E90.part1.rar RA-6_EMEA_300.34.84_v7.0_E90.part2.rar If all your efforts are failed and problem is still same as it was before then you must check your phone hardware, or post your problem here to get fast and better help: Nokia Hardware & Hardware-Repair Area B.R., kashi4gul | |
04-26-2009, 01:25 | #6 (permalink) |
Member: 146353 Status: Offline Thanks Meter: 31 | thx guys for your help, my phone already have latest firmaware!, i did factory reset with *#7370# all seemed worked properly, SD card transfere mode ok, but still reboot when trying to connect to wifi spot with WPA2 key, signal lost somtimes only when i try connection to internet by gprs, not on phone gsm mode i will study your given solution and see, but i have UFS box tornado 3 without Hwk what soft i will need also?, also have no cable adapter between box and e90, is there any schematic for? i appreciate your reply Last edited by razou; 04-26-2009 at 01:32. |
The Following User Says Thank You to razou For This Useful Post: |
05-24-2009, 00:17 | #7 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 369369 Status: Offline Thanks Meter: 15 | your device without hwk cant do it you should use jaf box my phone already have latest firmaware!, i did factory reset with *#7370# all seemed worked properly, SD card transfere mode ok, but still reboot when trying to connect to wifi spot with WPA2 key, signal lost somtimes only when i try connection to internet by gprs, not on phone gsm mode i will study your given solution and see, but i have UFS box tornado 3 without Hwk what soft i will need also?, also have no cable adapter between box and e90, is there any schematic for? i appreciate your reply [/QUOTE] |
05-24-2009, 01:00 | #8 (permalink) | |
Junior Member Join Date: May 2006
Member: 278477 Status: Offline Thanks Meter: 11 | Quote:
if you not expert how to use your flasher,better you learn how to use at first,or your problem become worst.... but if you still want to do that ,the safest way is try to full formated and full factory default by flasher box... if there still no effect try to repair energy management by SX4 auth then write PM field 1 & 309.(it needs to take very carefull attention) there many many post(threads) in this forum that you can search. | |
Only Nokia E90 Communicator | MoiNKhulna | Nokia Multimedia | 68 | 05-13-2011 04:04 |
Urgently Need Help @ E90 Communicator | bluffmaster | Nokia Hardware & Hardware Repair | 0 | 08-07-2007 08:52 |
