04-15-2013, 05:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PILIPINAS
Member: 759375 Status: Offline Sonork: www.GSMPIONEER.com Thanks Meter: 895 | easy local mode + testmode & CONNECTION for UFC cable here is a SIMPLE BUT VERY USEFUL tip broken battery clips or loose battery connectors? flashing error flashing stops code reset or factory reset failed because FAILED to set LOCAL MODE or TEST MODE? DO THIS FOR EASY CABLE SET UP and FLASHING thru UFC or USB as well you can reset phone locks and password on start UP even if you are using USB ONLY without flashing just set phone to testmode or local mode DONE! TAKE NOTE... you still need to put battery frame for bl4c but bl5ct connectors don't need the battery frame anymore some of the proofs here |
The Following 10 Users Say Thank You to snakebreeder For This Useful Post: |
04-17-2013, 02:11 | #4 (permalink) |
Member: 759375 Status: Offline Sonork: www.GSMPIONEER.com Thanks Meter: 895 | here is sample bro problem: 5250 blinking led and display showing system error message on screen connect phone to usb with ufc power supply then long press the button until "nokia usb phonet or port" appears on device manager open cyclone program then follow the screenshots (set phone to testmode) DONE |
The Following User Says Thank You to snakebreeder For This Useful Post: |
