03-17-2011, 07:54 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | Easy reset new and old bb5 phones without fbus cable OF USING THE UFC LED TO THIS DISCOVERY YOU CAN MAKE FACTORY RESET, REMOVE SECURITY CODE AND FULL FORMAT VIA USB, ALL YOU NEED IS TO FIRST PUT THE PHONE IN TEST OR LOCAL MODE BEFORE CONNECTING CABLE.. WHAT YOU NEED A 4.7K RESISTOR OR SIMILAR, SEE ATACHMENT POWER OFF PHONE, PUT ONE LEG OF THE RESISTOR ON THE BATT - AND ONE LEG ON THE BATT BSI PUT BATTERY AND PRESS AND HOLD POWER ON PHONE SHOULD SHOW LOCAL MODE OR TEST MODE. DEPENDING ON THE VALUE OF YOUR RESISTOR. ONCES PHONE IS IN TEST MODE, CONNECT USB CABLE AND READ INFO. YOU CAN DO JOBS. 4.3K WORKS ALSO IN TEST MODE. 4.7 GOES TO LOCAL MODE. ALL WORKS. I ALSO BROKE A BB5 CABLE AND REMOVE RESISTOR, TESTED ON NOKIA E75 WORKED, n70 WORKED, E5 WORKED.. SHOULD WORK ON ALL BB5 PHONES. YOU CAN TEST DIFFERENT VALUES OF RESISTORS AND POST REPLY. |
The Following 7 Users Say Thank You to ::gsmcoder:: For This Useful Post: |
03-17-2011, 11:25 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Actually this is great trick for new phones and old phones as well....Its very old trick to get phones in local or test mode.... As far as resistor value concern for latest phone we need 7.5K or above value resistor or 10+K resistor for N95 type phones... You can use power supply or even usb power for test/local mode.... |
The Following User Says Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post: |
03-17-2011, 13:12 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: London
Member: 241938 Status: Offline Sonork: 100.1663699 Thanks Meter: 477 | 4.7k resistor works for all mobiles no need to change resistor for different kind of sets |
The Following User Says Thank You to amirsaishi For This Useful Post: |
03-18-2011, 12:55 | #4 (permalink) |
Freak Poster Join Date: Mar 2006 Age: 44
Member: 252859 Status: Offline Thanks Meter: 53 | No need to hunt for resistor if you own a F-bus cable... You can simply connect all bb5 with the B+, BSI, and GNDS of your Universal F-BUS instead of using a battery, and connect phone directly to PC using USB cable... Most Universal F-Bus is able to vary resistor Vaule...Must Work!!! |
The Following User Says Thank You to Christobol_007 For This Useful Post: |
05-07-2011, 00:25 | #6 (permalink) |
Junior Member Join Date: Feb 2007
Member: 446956 Status: Offline Thanks Meter: 0 | hi all frinds plz tell me i want ? we need infomtion abut new nokia phone how to fhls and wish box new for nokia best i want to buy plz any body have good nolij to inform me plz and with abut cyclon box its good for all nokia set |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
