I have N80 on Fone Startup Contact Retailor i have done erase fone complete flash fone write backups write modified pm also factory setting but fone is still on contact retailor when i have check self test i have found ( Security Test And Vibra Test Fail ) and all are passed Here Is My Fone Log Powering the phone... Reading... MCU SW version: V 05wk33v46 18-06-07 RM-92 (c) Nokia. HW version: 6002 PCI version: RFIC version: 17191719 DSP version: miro_05wk32v42p1 Retu version: 14 Tahvo version: 21 Production serial number: SGG664332 Product code: 0527476 Module code: 0202689 Basic production code: 0524613 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358361000811210 IMEI spare to net: 3A 85 63 01 00 18 21 01 IMEI SV to net: 33 85 63 01 00 18 21 31 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN anyone please tell me what can i do now??? it's urgent B.R., Sonu Quote:
plz help me for cable rpl ok for mt box plz best and easy cable pic 10 pin |
Hi stanner_austin, maybe you are bored reading these questions :) but... I used to send ASK to rpl procedure and I got each RPL file working fine but nowadays I lost my confidence because of 3 failed attempts: All of them with SIMLOCK writting failed. Is it possible RPL file corrupt? is there a way to fix it? Best regards mate. |
there are many case phone don't accept sim lock 1 308 not let him accept : solution erase 308 and write rpl 2 phone is not in test mode . : make perfect cable 3 phone have bad eeprom area pm area : try to erase with erase files if you want to check rpl there is very easy way to do it. as soon we click on jaf write rpl it gona detect all avalable data in rpl for example Quote:
as you can see in red ok means its have not found means not have. here is example for ok and valid rpl Quote:
super dongle key data is for simlock key for phone special high encrypted which is like password for phone to accept sim lock in rpl. in case your rpl don't have it means phone can't accept simlock data .. and please no one is able to make rpl his own.. all are using nokia access some are using direct api with valid sx4 to get real time lol i got some :D. in future you will see nokia change method of calculating rpl br chevli |
pls hep me i have n72 and n70 both of them problems is contact the retailer IMEI is OK (3598**********) & profile bits: 0000000000000000 simlock config:2440700000000000 & and ST_SIM_LOCK_TEST IS PASSED and ST_SECURITY_TEST IS PASSED how can i do repair it?:( what ia this problem is hardware & softwaer ? thanks |
try do do factory set if same problem means its in hardware. |
hay brother tanks for info but iwant mor info in urdu or hindi pless zzzzz my email:[email protected] |
use hand reset *#7370#12345 |
-write full pm -sx-4 again untill....done tested working by me,if software problem. if still no succed,....check your hardware. br. |
mr staner austinn.i have problem with my n73,after i write rpl,sx4,pm.become phone start up...can you help me???im from indonesia.. |
NPC DATA OK... VARIANT DATA OK... CCC DATA NOT FOUND... HWC DATA NOT FOUND... NPC APE DATA NOT FOUND... VARIANT APE DATA NOT FOUND... CCC APE DATA NOT FOUND... HWC APE DATA NOT FOUND... SIMLOCK DATA OK... SIMLOCK KEY DATA OK... SUPERDONGLE KEY DATA OK... CMLA KEY DATA NOT FOUND... WMDRM PD DATA NOT FOUND... write RPL also used.... modified pm with sx4 also..... used erase option still provider FFFFFFFF.....phone is working well without sim....pl.reply |
first chang flasher ic then chang uem ic |
just try to spend time more.. erase ONLY sim lock.. and rewrite rpl. |
thanks for the information really it helped a lot :):):):):):):):):) |
after write Rpl, downgrade n upgrade but phone still lock Powering the phone... Reading... MCU SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. HW version: 6001 PCI version: RFIC version: 150a160f DSP version: rolf_05wk07v29p1 Retu version: 32 Tahvo version: 53 Production serial number: CIH650920 Product code: 0524086 Module code: Basic production code: 0522156 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359567011131039 IMEI spare to net: 3A 95 65 07 11 31 01 03 IMEI SV to net: 33 95 65 07 11 31 01 13 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2040400000000000 Provider: Vodafone / Libertel;Netherlands Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20404F Lock 2: CLOSED -> Lock Data: 20404F Block 2: Lock 1: CLOSED -> Lock Data: 20404F Lock 2: CLOSED -> Lock Data: 20404F |
