Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 11-01-2007, 09:07   #1 (permalink)
Member: 622142
Sonork: 100.1680775
Thanks Meter: 40
Flash BB5 to original Nokia firmware without Phoenix!
Hello,
As you might know, Nokia Software Update lets you upgrade your phone's firmware, but it will keep your operator's personalization (and revert to it, even if you flashed the phone to a non-branded firmware with Phoenix before).
ExpertGSM published a new method on a french site (www.forummobiles.com) in order to "trick" NSU so that the phone's firmware will be upgraded with the latest original Nokia firmware.
Here is the translation I've done for this tutorial - just keep in mind that you have to correctly identify (based on a firmware file for your BB5 phone) the correct product code for your country and phone model.
Here’s a tutorial that will teach you how to update your phone’s firmware to a Nokia original version (without your operator’s personalization) with NSU (Nokia Software Update – the official Nokia program).
NSU reads the product code of your phone and it searches its database for a newer version of the corresponding firmware in order to upgrade it. This is why you will need to change the product code of your phone into a non-branded product code, before running NSU.
Download the « NSS » software in order to change the phone’s product code. This is a shareware program that you can download on the site of its author here : http://bphreaks.brinkster.net/files/NSS/NSS10373b.zip
After that, download the following program: http://rapidshare.com/files/1236869/Copie_de_gsm-magic.rar.html (this is not a crack, but a program that allows the activation of any disabled option on no matter what program).
And finally, download NSU here: http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdate.
NOW WE CAN BEGIN:
Install NSS
Install NSU
Connect your phone and wait for Windows to install the drivers.
Open NSS and click on “Scan for new device” on the right-upper part of the window
Click on the icon « Phone info »
Click on “Scan”
Open « gsm-magic » without closing NSS, then push the button « Enable » of “gsm-magic”.
As you can see, now you can change the product code (on the right of the « phone info » window of NSS). For a Nokia 6680, type the product code 0521637 (this is the product code for France!) and then mark the case “Enable”.
Now press “Write”, and your phone’s product code will be changed (you might think that nothing happened, because the phone is still in normal mode, and the changing of the product code only takes a couple of seconds, but don’t worry, the product code changed !).
Close NSS and “gsm-magic” and you can proceed now with the NSU flashing.
When the flashing with NSU is over, start-up your phone and you’ll have the pleasant surprise that your phone’s firmware is the latest Nokia non-branded firmware in date!
NOTE: I advise you to disable any antivirus and firewall on your PC during the flashing.
In order to find out the product code for other phone models, download the firmware for your phone model, connect your phone to NSS, click « Scan », then « Flash », and after that look for your product code when on « Market » you will see your country. Write down this number, then you can start the manipulation as described above. Anyway, we will soon have the product codes for all the models, so we won’t need this step.
EXPERTGSM
Old 10-01-2009, 21:38   #2 (permalink)
Member: 505845
Thanks Meter: 21
Tried to download the last 2 softwares on this thread, but kept on saying error. any ideas, or can someone give me a working link, many thanks
How to edit Nokia firmware .... ?!?!? Sau_Cell GSM Programming & Reverse Engineering 13 01-09-2014 09:00
Flash BB5 to original Nokia firmware without Phoenix! behemot_behemot Nokia Base Band 5 ( BB-5 ) 617 05-20-2011 16:34
How to format Nokia 6131 without Cabel !!!!! Urgent Please bukshi_mobile Nokia Base Band 5 ( BB-5 ) 2 02-07-2008 13:30
how to original nokia flash adapter with ufs?? steinhold2000 UFS2 + UFS3-Tornadoflasher 0 09-09-2006 13:05
how to power nokia 3310 without battery i.e directly with dc supply nikhilele Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 04-16-2006 19:03
Page generated in 0.15025 seconds with 10 queries
