06-03-2006, 14:16 | #1 (permalink) |
Insane Poster Join Date: May 2006
Member: 276474 Status: Offline Thanks Meter: 11 | flash bb5 with usb cable (final solution) i will post there the final soltuion to flash ur bb5 using phoenix 2006 we notice with this methode we cant rebirth coz we still use pheonix.exe 2004(250 ko) we just update the other module to flash but not to rebirth dead phone if any one (cracker) want to do a crack for phoenix.exe 2006(500 ko ) so we will can rebith and may be unlock now i will post the solution for flash and good luck |
06-03-2006, 14:24 | #2 (permalink) |
Member: 276474 Status: Offline Thanks Meter: 11 | Flashing BB5 Nokia phones with an USB cable (Update of 06/2006) © Expert-GSM & all the team: zoolcopa/anakronik/bonhomme/exodia/ombre/behemot/zdig1 This tutorial explains how to upgrade your Nokia BB5 with the latest firmware. You will need a USB DKU-2 cable and the software “PHOENIX Service” by Nokia! (No dongle to buy!!!) This method proved successful by flashing one Nokia 6680 ORANGE and another one branded SFR, and also on other hundreds of BB5 phones, like 6630 Nokia original firmware version, N70, N90… However, we cannot be hold responsible for the damages you can do by making a wrong handle, and losing your warranty! BEFORE BEGINNING! - Save all the data from your phone (on your memory card or on PC) - Remove your memory card and your SIM card - Fully charge your phone’s battery - Uninstall Nokia connectivity cable driver / Nokia connectivity solution from your PC! - Uninstall Diego and Phoenix if you have them on your PC (think to delete manually from « program files » the files that might persist after the uninstall, and even clean tour registries if you still have problems) What you need : - the following software: 1 - Diego (e.g.: 55667793_Diego_3_06.msi) 2 - Phoenix 2004 + crack (e.g. : phoenix_service_sw_2004_39_7_70.EXE + 1-crack_dongle_phoenix_all_.EXE) 3 - Phoenix 2006 (e.g. : phoenix_service_sw_2006_12_5_136.rar) - the firmware of your phone. (check the file ‘last firmware’ for the latest versions of your bb5 phone at the date of appearance of this tutorial) - the DKU-2 cable and the phone, of course. Some of these files are archived on volumes. Unpack them all in the same folder and you will finally get the file you want. For Phoenix 2004, do “Save as” in order to download it, and change it in “.EXE”. Step N° 1 - INSTALL DIEGO - Run and install the following file: 55667793_Diego_3_06.msi - If you get an error during the installation, it’s because you didn’t uninstall the Nokia connectivity cable driver! Step N° 2 - INSTALL PHOENIX SERVICE 2004 WITH THE CRACK - Open the crack first. Just open it, don’t run it now! - Start installing phoenix 2004. During the installation you’ll get an error message. - Press on “Retry” and run the crack immediately after! (Check that the destination folder is Windows/system32). If you’re not fast enough, the message will reappear and you’ll have to re-run the crack the same way as above (but faster…) - You’ll get 2 error messages, just press OK, and then Finish. - You successfully installed phoenix service 2004. Restart your PC. Step N° 3 - INSTALL PHOENIX 2006 You have the shortcut for Phoenix on your desktop. Run it, and you might get several times the message "dskey not found!”. This is normal, just press « ok », and eventually Phoenix should open. - Don’t close the program. You must only minimize the window. - Run phoenix_service_sw_2006_12_5_136.EXE. You shouldn’t have any error! - Make sure you don’t restart the PC at the end of the installation. Just choose "restart my PC later" and then Finish. Now you can close the window of Phoenix that you have minimized. Go to the folder Program files/Nokia/phoenix and copy this entire folder on your desktop. Restart your PC. If you have any error messages after the reboot, just press « Cancel ». Go to /Program files/Nokia/, delete the folder phoenix, then replace it by the folder that you saved on your desktop. Now Re-run the crack of Phoenix 2004. You can now run Phoenix 2006. Step N° 4 – INSTALL THE CABLE It is advisable to close the applications you don’t need during the flashing (like antivirus, anti-spy ware etc). Connect your USB cable (DKU2 or another) to the PC, and connect your started phone. Wait for Windows XP to install all the drivers (it’s better to not have unknown hardware devices), and then don’t touch your phone anymore because the cable doesn’t hang on very well and it might disconnect! Now you have to execute these steps in phoenix: File / Manage connection / New/ select USB / press Finish / Apply and Close. Step N° 5 - FLASHING THE PHONE - Put the firmware folder on your desktop. (e.g. RM36 for a Nokia 6680) It should contain 2 files (this might vary depending on your phone model and download source): One (MCU) with the .COR extension and the other one (PPM) with the .V30 extension. - Do the following in phoenix: Flashing / sw update You should see the name of the firmware folder (like RM36) on the top of the phoenix window. If you can see it, you’re on the good way. - On the first line (Image File), browse for your file that ends by .COR . - On the second line (PPM File), browse for your file that ends by .V30 . Press START and don’t touch your phone anymore. Wait for a message! Phoenix will tell you to press the ON key of your phone and OK on the Phoenix software! Firmware upgrade was done! Notes: for some phones, you don’t have to install phoenix 2006. The 2005 or 2004 might be enough: Phoenix 2004 --- 6630 . . . Phoenix 2005 --- N70 . . . 6680 . . . 6630 Phoenix 2006 --- N90 . . . N70 . . . 6680 . . . 6630 . . . You will have the list of the supported models for each version, when you make “File / open product”. The same procedure applies for Phoenix 2005, but you don’t have to re-run the crack (if you have trouble with the phone’s drivers, you can install Nokia_Conn_Cable_Driver_159_ita.msi or even re-install Nokia PC Suite). If you uninstall “Nokia connectivity” at the beginning, you can re-use Nokia PC Suite after that. The reference of the language pack helps you to choose the language you want in your the phone (so you can pick a different version than the .V30). The phones that are locked on an operator will remain so after the flashing. The unlock code provided by your operator will work whether you flash your phone in a Nokia original firmware version or not. The number of FW files is depending on the phone model (6630 has 2 files / 6020 has 3 files / Communicator has 5 files). The ideal would be to have a flash .EXE (data package), allowing to know the order of the files due to the included “.INI”; but there’s not always the case (the minimum is to have one mcu and one ppm). The order in the flashing procedure (see the JPG image) Image file: \products\rh12_28_11005.500 (.3 chiffres) PPM file: \products\ rh12_28_11005.50c (.2 chiffres + lettre) Content file: \products\rh12_28_11005.50.ucp_c (.2 chiffres+ mot + lettre) ADSP Flash : NONE (communicator) APE Variant : NONE (communicator) APE Userdisk: NONE (communicator) For dead phones: File/ Open product, choose your phone model and then flash it (see attached PDF). If it doesn’t work, you can still flash your phone with a box, after have been doing a full-erase. A big THANK YOU to all the people that contributed to this tutorial and to those that translated it (Fr, Ar, Eng, It, Ger), so that many people can take advantage of it © Expert-GSM & all the team: zoolcopa anakronik bonhomme exodia ombre behemot zdig1 |
The Following 11 Users Say Thank You to bidoun For This Useful Post: |
06-03-2006, 14:26 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Razgrad,Bulgaria Age: 39
Member: 39126 Status: Offline Thanks Meter: 12 | re! Phoenix cracked is a good free solution for flashing Nokia phones ... my N6630 is with the latest firmware from over a month using this program |
06-03-2006, 16:19 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: The pub
Member: 236929 Status: Offline Thanks Meter: 12 | Quote: For dead phones: File/ Open product, choose your phone model and then flash it (see attached PDF). If it doesn’t work, you can still flash your phone with a box, after have been doing a full-erase. Could you attach the PDF pls |
06-03-2006, 17:07 | #5 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 201503 Status: Offline Thanks Meter: 0 | Thx to all for this tips all over the web !! But, after all this procedure and a flash for example, we can't use again phoenix if we restart windows i'm right ? Because, that is the problem right now, for flashing again, we need to do this procedure at each time..... |
06-03-2006, 17:27 | #7 (permalink) |
Member: 201503 Status: Offline Thanks Meter: 0 | Ok thx ! Damn.. But there is something that i don't understand. At the first install with the crack, we restart the computer and it is ok. But after install phoenix 2005 or 2006, if we restart, the dongle is asked.... So why at the first install it works, but not after ... For a weeks, i'm looking for the solution for that, and nothing.... |
06-04-2006, 07:57 | #11 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 287548 Status: Offline Thanks Meter: 0 | Quote:
06-04-2006, 08:16 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | thank you for this tutorial !! very nice step by step ... after this step can we run 2006 with np after restarts of the pc ? can we use it for other then flashing with usb ? (im more interested on diagnostic options for phones in this soft , will all run well ? ) |
06-04-2006, 09:57 | #14 (permalink) |
Member: 276474 Status: Offline Thanks Meter: 11 | no we dont have to redio all step guy read carfully the tuto this is the final methode w do it only one time and we have phoenix for all live now there phoenix 2006 138 the crack is for 2004 that y when isnatlling 2006 it must be opned with this methode 90% are updated (incliding flash reference ) but still 10% how 2004 use during the install so if u know any man want crack for 2006 and u will c the result for document c this http://www.verzend.be/v/6746576/1_bb5_flashing.rar.html |
06-04-2006, 11:56 | #15 (permalink) |
Member: 236929 Status: Offline Thanks Meter: 12 | I stand corrected If you follow this part of that guide you can restart as much as you like without problems an still run phoenix 06: Go to the folder Program files/Nokia/phoenix and copy this entire folder on your desktop. Restart your PC. If you have any error messages after the reboot, just press « Cancel ». Go to /Program files/Nokia/, delete the folder phoenix, then replace it with the folder that you saved on your desktop. Now Re-run the crack of Phoenix 2004. You can now run Phoenix 2006. ... As for dead phone flashing(search for stickys thread on the subject) The only flash files package ive seen that supports "firmware update" is RM70 and if you try it you always seem to get a dongle error. Anyone who wants this software heres the links: 1. http://rapidshare.de/files/21206858/...crack.rar.html 2.http://rapidshare.de/files/21220570/...ivers.rar.html. 3. http://rapidshare.de/files/21223987/phoenix_06.rar.html I put this up two wks ago so it'l only be there for one more week. Ps id use the instructions on this thread Rather than My own. ty Bidoun |
problem to flash BB5 with usb cable | bezz | Universalbox | 0 | 05-30-2008 20:22 |
Can't flash BB5 with USB cable !!!! | ehab777 | MT-BOX | 2 | 09-02-2007 08:40 |
