10-31-2006, 01:07 | #1 (permalink) |
Insane Poster Join Date: May 2006
Member: 276474 Status: Offline Thanks Meter: 11 | flash to original FW with NSU , bye bye phoenix and it's again expertgsm discover how to flash only in 15 mn ur nokia by nokia software update and to have original nude version for any question u can c the original link http://www.forummobiles.com/index.php?showtopic=107252 |
10-31-2006, 01:09 | #2 (permalink) |
Member: 276474 Status: Offline Thanks Meter: 11 | Here’s a tutorial that will teach you how to update your phone’s firmware to a Nokia original version (without your operator’s personalization) with NSU (Nokia Software Update – the official Nokia program). NSU reads the product code of your phone and it searches its database for a newer version of the corresponding firmware in order to upgrade it. This is why you will need to change the product code of your phone into a non-branded product code, before running NSU. Download the « NSS » software in order to change the phone’s product code. This is a shareware program that you can download on the site of its author here : http://bphreaks.brinkster.net/files/NSS/NSS10373b.zip After that, download the following program: gsm-magic http://rapidshare.com/files/1236869/...magic.rar.html (this is not a crack, but a program that allows the activation of any disabled option on no matter what program). And finally, download NSU here: NSU. http://www.nokia.co.uk/nokia/0,1522,...softwareupdate NOW WE CAN BEGIN: Install NSS Install NSU Connect your phone and wait for Windows to install the drivers. Open NSS and click on “Scan for new device” on the right-upper part of the window Click on the icon « Phone info » Click on “Scan” Open « gsm-magic » without closing NSS, then push the button « Enable » of “gsm-magic”. As you can see, now you can change the product code (on the right of the « phone info » window of NSS). For a Nokia 6680, type the product code 0521637 (this is the product code for France!) and then mark the case “Enable”. Now press “Write”, and your phone’s product code will be changed (you might think that nothing happened, because the phone is still in normal mode, and the changing of the product code only takes a couple of seconds, but don’t worry, the product code changed !). Close NSS and “gsm-magic” and you can proceed now with the NSU flashing. When the flashing with NSU is over, start-up your phone and you’ll have the pleasant surprise that your phone’s firmware is the latest Nokia non-branded firmware in date! NOTE: I advise you to disable any antivirus and firewall on your PC during the flashing. In order to find out the product code for other phone models, download the firmware for your phone model, connect your phone to NSS, click « Scan », then « Flash », and after that look for your product code when on « Market » you will see your country. Write down this number, then you can start the manipulation as described above. Anyway, we will soon have the product codes for all the models, so we won’t need this step. Product code E61 0529663 product code N70 0523982 product code N80 0526966 product code 6680 0521637 product code 6630 0518104 EXPERTGSM English translation by Behemot |
10-31-2006, 13:56 | #3 (permalink) | |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Quote:
We have released a new version of NSS, so no need to enable anything with additional software. Till now was limited because was not tested properly. Although read of Production Data is not working correctly yet via USB(only on F1 works fine) you can write the product code in Virtual USB Device mode. To check result, go to the Flash Menu and press scan. The product code will be desplayed on the left. Download here. Regards | |
10-31-2006, 20:40 | #4 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: India ( Punjab ) / China Age: 38
Member: 154749 Status: Offline Sonork: 100.92483 Thanks Meter: 1,048 | Quote:
Thnx for it ... one ques is this version flash all bb5 like old phoneix crack...Dead BB5 flashing possible..if yes how.. in ur given version i sucessfully connect my 3250 Thnx waiting for reply | |
11-01-2006, 20:17 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 53
Member: 88938 Status: Offline Thanks Meter: 16 | sweet nice one chaps it works now i have got a debranded N91 updated .i changed the product code using nss and ran the nokia update software and sure enough there was an update. well sorted cheers loneunlocker |
11-02-2006, 00:53 | #11 (permalink) |
Junior Member Join Date: Nov 2006
Member: 382828 Status: Offline Thanks Meter: 6 | I did this and it worked great, however my keys are not correct anymore. Apparently I flashed to a version with a different keyboard! Does anyone know how I can get the qwerty keyboard instead of azerty? |
11-02-2006, 01:47 | #12 (permalink) |
Member: 382828 Status: Offline Thanks Meter: 6 | First of all, let me apologize for all these posts. I am not this stupid, I promise. I surfed around and found the code for a keyboard that is close enough, but it is not exact. Mine has a little chinese symbol on the Chr key, as well as little chinese dashes on q, w, e, a, s. I can give any other defining characteristics, I just dont know what to look for. I like the new unbranded firmware, I just want to know if I can get my keyboard to work. Thanks, and sorry about all the posts. |
11-02-2006, 19:16 | #14 (permalink) |
Member: 382984 Status: Offline Thanks Meter: 0 | I have an branded E61 with 3 mobile hong kong. The FW version is 2.608 etc (the newest one). Product code is 0538361, i have choice of 3 languages, english, traditional and simplified chinese. I want to get rid of the branding, and do not lose my keyboard layout. What should I change my product code to? Thanks |
Can F480 be flashed to other FW for unlock? | khawar | UST Pro II | 4 | 01-28-2009 10:09 |
Convert Vygis Flash Read Flash to Original format ? | Nokia man | VygisToolbox | 1 | 12-17-2008 02:16 |
KF700 can't flashing to Chinese FW? | Scree | Z3X-Team Products | 2 | 07-27-2008 21:15 |
is that possible to convert setool flashes to use them with cruiser? | AjeeB | Cruiser Suite | 2 | 11-26-2007 18:46 |
Can I Flash to Nokia 1101 with my Twister | .:MobileLife:. | Twisterflasher | 1 | 01-15-2006 08:52 |
