07-31-2009, 13:21 | #1 (permalink) |
Junior Member Join Date: Jun 2009 Location: B_DESH
Member: 1045015 Status: Offline Thanks Meter: 127 | Flash,Update,Unlock,Downgrade Your Nokia(BB5), from 6630 to n96 , ONLY NEEDS USB CABL Flash,Update,Unlock,Downgrade Your Nokia(BB5) just download the JAF sw and its Emulator and run emulator, if you wanna flash or reset security code run JAF MAIN, if Unlock then run JAF UNLOCKER. COMPLETLY TESTED AND WORKING LIKE CHARM .................................................. .................................................. .. How to work with flasher ? 1.mark "manual flash" then press on MCU and PPM and CNT one by one and select the required flash image files. ( MCU: main image file, larger than other PPM: it contain language pakages CNT: it contains multimedia files ) 2.connect completly turned ON phone to USB and select PC SUITE mode from the pop-up menu, drivers should be installed. 3.for normal flashing only mark "CRT 308" , "Factory Settings" , "Normal Mode" and press flash 4.for flash dead phones only mark "Dead USB" , "Normal Mode" , "Factory Settings"and press flash then do simple 1 power on phone. 5.for downgrade phone's firmware only mark "Downgrade", "CRT 308", "Normal Mode", "Factory Settings" and press flash (phone should be ON for downgrade) Warning : if you got any Popup window during Downgrade procedure EXEPT the first one DO NOT CONTINUE ------------------------------------------------------------------------ TESTED PHONES FOR DOWNGRADE : - N81 v21.0.010 downgrade to V10 - 5610 XP Music all firmwares - 6500S all firmwares - 6120C all firmwares - N82 V20.0.062 to lower version - 6300 all firmwares - 6120c 6.51 to 6.01 and 5.11 this list will be update .... ------------------------------------------------------------------------ - here some screen shot and status logs of its work : Status LOG of Dead USB Flashing : PHP Code: Status LOG of downgrade flashing : PHP Code: Code: DOWNLOAD LINKS : JAF 1.98.62 : http://rapidshare.com/files/188390717/JAFSetup_1.98.62.rar JAF 1.98.62 Emulator : http://rapidshare.com/files/188383839/OGM_JAF_PKEY_Emulator_v4.zip Nokia Flashing Cable Driver : http://rapidshare.com/files/190847608/Nokia_Flashing_Cable_Driver.msi Nokia Connectivity Cable Driver : http://rapidshare.com/files/190856478/Nokia_Connectivity_Cable_Driver.msi |
The Following 18 Users Say Thank You to ::..s@uddin..:: For This Useful Post: |
08-03-2009, 17:56 | #14 (permalink) |
Freak Poster Join Date: May 2008 Location: Uganda
Member: 774126 Status: Offline Sonork: 100.1645006 Thanks Meter: 42 | i know and every one knows this info is old but useful. i really like it. i have tried usb flashing with jaf before but i think i had never installed my drivers correctly. could someone help and upload these drivers. |
is possible to format chinese phone only with usb cable? | rerasta | Chinese Models & Cloned Phones | 17 | 06-19-2009 21:11 |
need to downgrade this phone from R26 to R24 firmware | Ran | Smart-Clip | 1 | 12-16-2005 16:36 |
is the PBB box support flash BB5 phones only with USB cable ? | cellularman | Phoenix Black Box | 1 | 08-19-2005 21:35 |
