Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 12-04-2008, 20:13   #1 (permalink)
Crazy Poster
Member: 888141
Help and advice would be godd
hi i have a nokia n95 8gb with a white screen it wont let me do anything with it as soon as i put the battery in it comes up with the white screen and i have to take the battery out to switch the phone off i have changed the lcd and its still the same can i use phoenix to flash it or do i need some type of box to sort it (which i do not have)come on guys someone must have a solution to sort this cheers in advance
Old 12-05-2008, 23:44   #2 (permalink)
misiu22's Avatar
Member: 661523
This sounds like hardware damage. But it's always worth a try to flash with latest flash version. And yes you can use Phoenix to flash n95 8gb. Use latest version availible to avoid complications. If you have any problems with flashing procedure post here and someone surely will help you.
br misiu22
Old 12-05-2008, 23:48   #3 (permalink)
Celui's Avatar
Member: 906535
If flashing the unit does not cure your problem, try replacing ribbon, seen many N95 8GB with similar problems and each time new ribbon cures the problem
Old 12-06-2008, 00:07   #4 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Hello
What white screen is it ?
White screen that stays beaming white all nighgt ?
Or white screen but all sets function are availalbe ?
To flash with Phoenix, yes you have to have some type of box
FLS-x FPS-x PKD-1 , MT-BOX ...
Max_B
Old 12-06-2008, 00:24   #5 (permalink)
misiu22's Avatar
Member: 661523
Originally Posted by Max_B View Post
Hello
Max_B
Offcourse if he don't want to use Patched Phoenix or Phoenix crack.
That is tested by some members here and it works but sometimes complications. But if the handset is dead or just hanging with white screenthen it's worth a try.
br
Old 12-06-2008, 00:33   #6 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
If handset is dead, there is no way for him to flash it through phoenix
Max_B
Old 12-06-2008, 01:11   #7 (permalink)
Crazy Poster
Member: 888141
n95 8gb white screen
hi thanks for the replys first how do i change the ribbon as i have changed the screen and the screen just stays white no nokia logo nothing no controls the phone does turn off using the button though also i dont have a box of anykind but i do have phoenix which i have tried but i get an error saying unable to load the device driver is there a solution to this ? or am i wasting my time probably better off just slinging the phone in the bin
Old 12-06-2008, 03:24   #8 (permalink)
Crazy Poster
Member: 888141
oh and which ribbon cheers
Old 12-06-2008, 11:37   #9 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
The ribbon is included with the slide.
Either you have ribbon faulty flex , or more like esd filters
If you want to install drivers, you have to set phone to "pc suite mode" on the handset.
When the phone turns on press center key 2 or 3 times
Try to find another N95-8GB and check how it acts when connected to the cable so you can understand what to press
Max_B
Old 12-06-2008, 14:59   #10 (permalink)
Crazy Poster
Member: 888141
white screen
cheers for the reply i have changed the ribbon on the slide and tested it in another phone and it works in the other phone so i think the phone must be kaput a hardware problem i have no idea the centre key press did not work looks like its going in the bin probably the best place for it i have one last thing to try and that is take it to a local shop a very small one and see if it can be sorted by them as they have different boxes etc maybe they can find the problem as i have another n95 8gb with phone start up failed contact retailer and they could not fix that and i have no idea how much nokia would charge to sort it
Need help and advice?/ zeizz Twisterflasher 0 02-09-2010 10:40
GD330 and GB115 would be nice.... Sulaco Z3X-Team Products 1 01-13-2010 19:24
pleas help and advice (M600i) fethi Sony Ericsson 1 08-28-2007 19:39
Help and Advice Required Regarding V600! b1gt1m P2k Series 2 11-02-2006 05:57
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.88965 seconds with 8 queries
