12-12-2009, 11:28 | #1 (permalink) |
Product Supporter Join Date: May 2009 Location: solution provider
Member: 1022742 Status: Offline Thanks Meter: 187 | Help E71 (210.21.006) upgarded to (400.21.013) need ur reply Regards |
12-12-2009, 12:20 | #3 (permalink) |
Freak Poster Join Date: Jan 2009 Location: india, delhi Age: 36
Member: 940655 Status: Offline Sonork: 1587842 Thanks Meter: 44 | security code dear pls try in ub with the following type. first select model in ub then check that ui default option is in full factory then do ui defaults u r set will ok 100% |
12-12-2009, 12:24 | #4 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | yes i m also upgrade the e71 to 100.00 to 400.00 and its give me problem with buttons like the button of dot and comma is not worked but it was work with before upgrading then i try to downgrade it but its not go to local or test mode i use with all cables like ipmart and gpg and also not comes the local mode with data cable . its very strange |
12-12-2009, 17:17 | #6 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Philippines Age: 42
Member: 20970 Status: Offline Thanks Meter: 14 | if you have mtbox, you can fix that by flashing and some tricks in your ufc ... cyclone also can fix that problem.. tested many times.. e66, e71, e63 etc |
The Following User Says Thank You to Artangel For This Useful Post: |
12-14-2009, 15:02 | #7 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
12-14-2009, 15:06 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | when phone ask Phone code - type 112 and call. then turn on call and phone will be unlocked. it;s a bug in latest version. change product code and flash it again. |
12-14-2009, 15:29 | #9 (permalink) |
Member: 1022742 Status: Offline Thanks Meter: 187 | @~ Nawab Traders ~ tested but not working it isnt dat problem @Boshko_Alfa i did try this way also but also not help for me and for any body cos i think some bugs in new firmware etc... Regards |
12-15-2009, 20:36 | #11 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | I had same problem but done !! I had same problem comes with phone security tryed all tool read ok..12345 but cant reset..finaly done by HWK just reset and factory twise..100% tested in e71 .....just try it................................................ ..................... Good Luck George |
12-16-2009, 08:06 | #12 (permalink) |
Freak Poster Join Date: Jul 2005 Location: vn
Member: 162379 Status: Offline Thanks Meter: 178 | uhm! your phone not have pm(field:308 record: 5) [308] 0= 1= 2= 3=03 4=07 5=31323334350000000000 6=00 7=00 9=000000000000000000000000000000000000000000000000 00000000000000000000000000000000 read pm your phone and check + my sulution!! write pm record 5 after flashing>> @...OF factory setings in JAF,mt....(cyclone not help)( |
12-31-2009, 01:04 | #13 (permalink) |
Junior Member Join Date: Apr 2006
Member: 257228 Status: Offline Thanks Meter: 0 | why don't you use a NOKIA Software update (NSU) . i know its not through flasher but its worth a try .. if you having a problem with dot button its because you used different language firmware , every different firmware has a different keyboard layout (phones with full QWERTY keyboard).. if you have dot button in second last row and second last button (DOT Button) of that row , change your product code to 0561929 and update your firmware through NSU . if anyone want URDU language for their E71 use this product code 0566976 and flash through NSU. by the way you can change your product code by using NSS (google it you'll find it) , its only for non professionals ... PEACE |
12-31-2009, 07:10 | #14 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 664922 Status: Offline Thanks Meter: 211 | Maybe this link help u : E71 - E63 Mcusw 400.21.013 Sw Re-Flash Instructions |
12-31-2009, 13:06 | #15 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1078988 Status: Offline Thanks Meter: 0 | You have to flash again with the same version 400 flash file but this time flash it with JAF. Tick factory settings and press flash, everything will be ok. Do not flash with lower version otherwise you will have problems. |
new firmware e71 rm-346 euro 400.21.013 V6.0 | pitone02 | Nokia Base Band 5 ( BB-5 ) | 4 | 07-08-2010 14:32 |
Nokie E71 400.21.013... | murerlars | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-10-2010 06:19 |
e71 300.21.012 version want to downgrade with 200.21.006 | soho2007 | Universalbox | 1 | 01-30-2010 13:46 |
E66 RM-343 - problems after upgrade to 400.21.013 | robbie | HWK | 9 | 01-23-2010 02:30 |
Which variant is Poland language n E71 400.21.013 | kennyDaktyl | Universalbox | 2 | 01-10-2010 16:05 |
