03-06-2009, 11:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: CLOUD Age: 40
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Help help N95 8GB after write pm Phone start-up failed contact the reailer Plz help me |
03-06-2009, 11:31 | #2 (permalink) |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | I think you may write pm with 308 filed and got this this problem. Plz post your Phone Info here, do Self Test also and check St Security Test is Failed Or Not? B.R., kashi4gul |
03-06-2009, 11:48 | #4 (permalink) |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | and where is phone info ? anywyas, write PM 1 - 309 with SX4 Authentication, i m sure it will fix your problem. (if SL Zone not damage) B.R., kashi4gul |
03-06-2009, 11:58 | #6 (permalink) | |
Member: 486357 Status: Offline Sonork: 100.1602846 Thanks Meter: 1,220 | Quote:
FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v51.3 13-02-08 RM-320 (c) Nokia HW version: 4120 PCI version: RFIC version: 17141715 DSP version: mc_3131_ICPR62_2008w04 Retu version: 15 Tahvo version: 22 Production serial number: SHG550909 Product code: 0557135 Module code: Basic production code: 0548236 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 3548290******** IMEI spare to net: 3A 45 28 09 82 35 95 06 IMEI SV to net: 33 45 28 09 82 35 95 06 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 can u upload pm file here 1 - 309 | |
03-06-2009, 12:06 | #9 (permalink) | |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
B.R., kashi4gul | |
03-06-2009, 12:21 | #11 (permalink) | |
After writing PM 308 disconnect phone and power on then remove battary and connect it again with J.A.F and see the result, SL Zone should be oK. B.R., kashi4gul | |
03-06-2009, 12:48 | #14 (permalink) |
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | wat. . . ? where is log when you restored the pm 308 backup ? follow the given steps: - Connect Phone - Write PM 308 backup (No need to use SX4) - Detach (disconnect) Phone, Insert battary and Power On. - Connect it again with soft. . . - Click to Info and see SL Zone is repaired or not It should be repaired, if not then no need to worry, we shall repair it by another way. (Ist we have to repair the damaged SL Zone, then we shall see contact retailer if we need) B.R., kashi4gul |
03-06-2009, 13:00 | #15 (permalink) | |
1st thanxs 4r help me Powering the phone... Writing PM... Field: 308, Record: 1, Len: 8192 -> OK Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v51.3 13-02-08 RM-320 (c) Nokia HW version: 4120 PCI version: RFIC version: 17141715 DSP version: mc_3131_ICPR62_2008w04 Retu version: 15 Tahvo version: 22 Production serial number: SHG550909 Product code: 0557135 Module code: Basic production code: 0548236 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354829028535965 IMEI spare to net: 3A 45 28 09 82 35 95 06 IMEI SV to net: 33 45 28 09 82 35 95 06 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-320.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0557135 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ Searching for default location of ini... Checking path: \Products\RM-320\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ Scanning ini files... Searching for default location of ini... Checking path: \Products\RM-320\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.v01 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_31.0.002_025_xxx_U01_uda.fpsx APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_030_000_M011.fpsx Languages in ppm: English,French,Italian,Spanish,German,Portuguese Done! but same problem | |
Help help N95 8GB after write pm Phone start-up failed contact the reailer:::ANSWERED | mohit_kripalu01 | Universalbox | 10 | 08-16-2009 09:34 |
N85 After ‘unlock Zulea Phone start-up failed.contact the retaler | azouqa | BB5KING | 9 | 05-27-2009 07:43 |
after write RPL phone start up faild contact the retailer | tirum | Federal One | 1 | 03-11-2007 14:32 |
