04-26-2009, 14:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: dubai
Member: 539557 Status: Offline Thanks Meter: 193 | help me pls 8800e charging problem urgent charger not soppurted i dont know where can i get this 47k to another board??pls can you show me wHere can i take this resistor?? pls help verry urgent |
07-24-2009, 20:00 | #2 (permalink) |
Insane Poster Join Date: Feb 2001 Age: 42
Member: 3195 Status: Offline Thanks Meter: 0 | from 6233 near charger contacts... loojk at the diagram of 6233... they are found on many boards... 6300 also... good luck. have you solved the problem with 8800e if the same problem is, but the 47k resistor is ok... ? |
08-01-2009, 22:52 | #3 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Montenegro Age: 36
Member: 17230 Status: Offline Thanks Meter: 6 | try to change R2007 IC, near usb connector, it is the same as on sonyericsson K750/D750/W810 (N2802 - 8 pin IC)... if doesn't help change R2010 ic... it is the same on 6300... if doesn't help - change N2000, N2002 or N2001, check capacitors that are in the circuit near... if that doesnt help - go ahaed studying your board for a bad capacitor )))))))) |
The Following User Says Thank You to Leslie_B. For This Useful Post: |
08-03-2009, 09:21 | #5 (permalink) |
Member: 3195 Status: Offline Thanks Meter: 0 | problem solved, in my case there was no contact between r2007 and connector, contact #3 (D+), the charger shortens contacts #2 and #3, and only in that case the charger works normally, if not - it shows Charger not supported... but on the other phone i've got problem that the charger gives 3.8 volt to battery cintacts and battery can't charge fully... does smb know about this? |
Help me! File 8800e Mt 6225 | lequangmobile | Chinese Models & Cloned Phones | 1 | 01-08-2010 10:05 |
help me pls!!! urgent | omatundan | Nokia Hardware & Hardware Repair | 5 | 11-20-2009 07:07 |
C-145 ringer&speaker not work help me pls urgent | Kannaraje | Samsung Hardware Repair | 0 | 06-23-2009 13:08 |
help me pls.... urgent my 6131 no light n display no light | WinD_VteC | Nokia Hardware & Hardware Repair | 3 | 02-18-2008 10:21 |
hi help me pls in this problem.... | digitized | Alcatel TCL Hardware Repair | 1 | 07-25-2007 21:32 |
