help! my 5130 dead and failed to boot in flash mode help me guys! during flashing my 5130 with jaf 1.98.62, the cable is discnnected with pc after half flash. after that i cant flash my phone with even dead phone method. it shows phone cant boot in flash mode cmt |
press check and post here the log..................... |
You need to flash it by fbus cable usb cable will not help because you stop it in half process try to flash now with fbus it will work fine br nadim_mobiles |
Is there any other way please tell me bro. Because i dont have fbus cable |
I gave my mobile to my friend. So i will post the log in 5-6 hours. |
my jaf log JAF version 1.98.62 Detected PKEY: 90009A86 Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.22.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-495\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.mcusw PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.ppm_aa CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__07.95.image_aa_red APE Variant file: NONE Detected P-KEY: 90009A86 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 09.07.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... .....................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Phone failed to boot in flash mode CMT... |
Charge the battery full,thick "dead usb",choose the latest flash version and flash! |
Bro i done this dead usb but i cant boot see my log. And i have full charged because i have two sets |
Bro i done this dead usb but i cant boot see my log. And i have full charged because i have two sets. |
totally dead after flashing due to disconnected cable with pc. Pls pls pls help |
Unthick "Normal mode",leave "dead usb" and try again!Which flash version do u use? |
The only solution is to flash with F-BUS cable!.......... |
I also try the fbus cable 5 pin from nokia care. I know dead usb method but my phone cant boot in flash mode. |
I also try the fbus cable 5 pin from nokia care. I know dead usb method but my phone cant boot in flash mode. I use jaf 1.98.62 and firmware 7.95 |
I am also using 7.95 version GPG fbus cable but failed any help plz...... |
