04-16-2008, 07:53 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 418230 Status: Offline Thanks Meter: 8 | help my 6280 cant unlock Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101003000 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 1C700219F1990054578962F4823AD84580EC7FB2 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 002F0001 <=> SPANSION -> 72NS256N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg Loader version: 01.0C.05 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\351861014566152_CRT_backu p_1549164.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... Read SP error! plsssss any solution for this phone |
04-17-2008, 16:02 | #3 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 49
Member: 174853 Status: Offline Thanks Meter: 84 | So can someone explain what is the meaning of this?? it says unlocking for 6280 already supported on this jaf setup version JAF Setup 1.98.38 ready... - BB5 usb ask plain reading - BB5 usb rpl write (only simlock data) - 2760 cnt bug fixed (again!) - added phone name in status bar - enabled TP unlock for BB5. You need adapter and activated pkey for bb5 tp unlock list of BB5_supported_17-10-2007 for unlocking 3109c RM-274 - Versions:-(5.30,5.50) 3110c RM-237 - Versions:-(4.91, 5.01, 5.50) 5200 RM-174 - Versions:-(5.00, 3.92) 5300b RM-147 - Versions:-(5.02) 5300b RM-146 - Versions:-(5.02) 6085 RM-198 - Versions:-(3.51, 3.52, 5.03) 6126 RM-126 - Versions:-(5.60, 5.61 6131 RM-115 - Versions:-(5.50, 3.50, 3.70, 6.10, 6.60) 6151 RM-200 - Versions:-(3.91)(ad0) 6234 RM-123 - Versions:-(5.10, 3.50, 3.70, 5.43, 4.91)(ad0) 6233 RM-145 - Versions:-(5.10, 3.50, 3.70, 5.43, 4.91)(ad0) 6280 RM-78 - Versions:-(6.10, 6.43, 5.96,5.92, 3.81, 5.94)(ad0) 6288 RM-78 - Versions:-(6.10, 6.43, 5.96,5.92, 3.81, 5.94)(ad0) 6300 RM-217 - Versions:-(4.70, 4.71, 5.00 6630 RM-1 - Versions:-(Just for fun ver 04wk47_m_v14.2 (6.03.40) 7373 RM-209 - Versions:-(04.71, 04.70, 03.90, 05.00) E50-1 RM170 - Versions:-(7.13, 7.05, 7.36, 6.27.1, 6.41.3) E61-1 RM-89 - Versions:-(3.0633.09.04, 1.0610.04.04, 2.0618.06.05) E65 RM-208 - Versions:-(1.0633.18.01) N73 RM-133 - Versions:-(3.0704.1.0.1, 4.0723.2.0.1, 4.0726.2.0.1, 4.0727.2.2.1) N73-5 RM-132 - Versions:-(3.0638.0.0.1, 3.0649.0.0.1, 2.0628.0.0.3, 3.0713.1.1.2, 4.0726.2.1.1) can someone explain? |
04-17-2008, 16:07 | #4 (permalink) |
Member: 174853 Status: Offline Thanks Meter: 84 | MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.10 21-12-06 RM-78 (c) Nokia HW version: 2000 PCI version: RFIC version: 17191719 DSP version: pb05w46v46 LCD version: SHARP PPM version: V 06.10 21-12-06 RM-78 (c) Nokia X Retu version: 32 Tahvo version: 52 Content Pack version: Content: x V 06.10 21-12-06 RM-78 (c) Nokia Production serial number: CRA185998 Product code: 0529983 Module code: Basic production code: 0520041 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 357926000089651 IMEI spare to net: 3A 75 29 06 00 80 69 05 IMEI SV to net: 33 75 29 06 00 80 69 15 F7 LOCK STATUS: CONFIG KEY: 5050600042465540 Provider: Hutchinson 3G;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50506F Block 2: Lock 1: CLOSED -> Lock Data: 50599F Block 3: Lock 1: CLOSED -> Lock Data: 00101F i try to unlock but.... Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\357926000089651_CRT_backu p_225174.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: 5050600042465540 Provider: Hutchinson 3G;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50506F Block 2: Lock 1: CLOSED -> Lock Data: 50599F Block 3: Lock 1: CLOSED -> Lock Data: 00101F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Read SP data error! or Phone not supported |
04-17-2008, 22:08 | #5 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Quote:
And btw, Jaf forum is here: http://forum.gsmhosting.com/vbb/newr...reply&t=526259 | |
04-18-2008, 10:02 | #8 (permalink) |
Member: 426389 Status: Offline Thanks Meter: 2,356 | Yes, my mistake, here it is: https://forum.gsmhosting.com/vbb/f420/ |
e61 and 6280 cant unlock | accurate | J.A.F. V-SPEC | 9 | 01-13-2014 17:26 |
my geniebox cant unlock and cant update!!! | hjfwei | Genie Universal | 5 | 09-14-2009 07:53 |
6280 cant unlock | ABI-GSM | BB5KING | 6 | 11-06-2008 19:33 |
please help my i cant use my new box | razorra_mooon | UST Pro II | 3 | 09-23-2008 18:06 |
6280 cant unlock | simlock | Nokia Base Band 5 ( BB-5 ) | 1 | 06-10-2008 13:55 |
