06-23-2016, 06:06 | #1 (permalink) |
Product Supporter Join Date: Apr 2007 Location: Planet Earth
Member: 487420 Status: Offline Sonork: 1590016 Thanks Meter: 3,202 | Nokia Repair Corrupted IMEI Certificate (NPC) - IMEI ( 12345xxxx ) Corrupted Simlocks (Contact Retailer) Phone switches off after 3 minutes (secure WD reset) Blocked phone unlock counter Common symptoms to show corrupted data: Contact Retailer( ST_SECURITY_TEST failed, SIM_LOCKS_TEST failed) IMEI number shown as default: 123456789012345 Switch off after 3 seconds, missing or invalid NPC certificate will cause reset of the RAP3 WD Not working Transmitter/Receiver or Not Charging (those could be caused by faulty HW also!) RPL after calculation contains: NPC_DATA, CCC_DATA, HWC_DATA, SIMLOCK_DATA, SIMLOCK_KEY_DATA, CMLA_KEY_DATA, WMDRM_PD_DATA Damaged imei (123456654321?) : SL1, SL2, SL3 Damaged SimLock data : SL1, SL2, SL3 Damaged Superdongle data : SL1, SL2, SL3 Can I read and write the ASK/RPL if I don’t have any special equipment? Yes, you can repair any Nokia BB5 with simlock state: FFFFFFFFFFFFF with only the use of the free software available in our support forum. If your phone has IMEI: 123456xxxx then you will need a flash tool (MTBOX, JAF, etc) Usd:12 contact : sonork 1590016 skype [email protected] |
The Following User Says Thank You to rotharo For This Useful Post: |
