06-16-2009, 18:05 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 581486 Status: Offline Thanks Meter: 2 | hi iwant repair n82 CONFIG KEY: 0000000000000000 (c) Nokia HW version: 4003 PCI version: RFIC version: 17141715 DSP version: sharaku_ICPR62_08w29 APE SW Core version: 31.0.016 APE Variant version: 31.0.01608.01 APE Test version: rm313_eno_2008wk06updv0.030 Retu version: 15 Tahvo version: 22 APE HW version: 1 APE ADSP SW version: 256 Production serial number: SBJ832212 Product code: 0551528 Module code: Basic production code: 0549319 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358082019725411 IMEI spare to net: 3A 85 80 02 91 27 45 01 IMEI SV to net: 33 85 80 02 91 27 45 01 F7 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 |
06-16-2009, 18:14 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 852543 Status: Offline Thanks Meter: 2,338 | Quote:
06-16-2009, 21:04 | #3 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | Quote:
06-16-2009, 21:43 | #6 (permalink) |
No Life Poster Join Date: May 2008
Member: 783315 Status: Offline Sonork: 100.1588917 Thanks Meter: 228 | Hi, i have a n95 which i didnt make a back up , n now the phone is unknown provider the imei is ok the config is oooooooooo THE PHONE IS VODAFONE SPAIN 21401 can u advice pls how to revive this phone ? Br |
06-16-2009, 22:39 | #10 (permalink) |
Member: 783315 Status: Offline Sonork: 100.1588917 Thanks Meter: 228 | hi, just found the tool n downloaded it thnx but i m a bit confused shd i just put in the imei with the operator 00101 n make a new pm n write it to the phone or make a pm with vodafone operator code or what ? pls put some light on this my friend as u have more experience on this / br |
06-16-2009, 22:47 | #11 (permalink) | |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
witch tool you use? my tool (by harald kubovy) ? you need to select the operator witch it was locked before... then you need to test all possible blocks till your simlock data okay... so you need to select first "1 block locked" then you need to press "WRITE PM" my porgamm writes fresh calculated pm120 block to your phone and reads the simlock data. if simlockdata okay, it shows you, if it not okay it shows you too. you can only write pm to phone if simlockdata not okay... if simlockdata okay, software dont let you write pm to your phone... br. hari | |
06-16-2009, 22:55 | #12 (permalink) |
Member: 783315 Status: Offline Sonork: 100.1588917 Thanks Meter: 228 | hi, yes i use ur tool but it does not connect to jaf ,,,,,, the program gets stuck in connecting mode ????/ do u have any updated version of this proggy/ thnx |
how to repair 3110c CONFIG KEY: FFFFFFFFFFFFFFFF by MX[SOLVED] | Gsm Hưngyên | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-28-2010 13:13 |
cyclone repair N95 config key: 00000000000 okey working | Nurettin Duman | Cyclonebox | 6 | 02-13-2010 16:24 |
Can cyclone repair N80 config key: FFFFFFFFFFFFFFFF ?? [SOLVED] | Platijet | Cyclonebox | 22 | 02-13-2010 10:36 |
I have backup but CONFIG KEY: 000000000000000 | JAVA Good | Nokia Base Band 5 ( BB-5 ) | 13 | 11-26-2009 23:01 |
