Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-11-2008, 11:45   #1 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
Red face how to convert 6300b to 6300
i recived a6300b from abroad after unlock it will accept only 1800mhznetwork but its imei from 35 how can i use 900mhz network in this phone need urgent repley plz
thx for all members
Old 10-11-2008, 11:55   #2 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
this is not possible..
i had search alot but no result
u can also search on this fourm..
Old 10-11-2008, 12:09   #3 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
yah realy this big problem try to reflash it with6300 fw and change filtter bat the same problem
wbr
Old 10-11-2008, 12:10   #4 (permalink)
newfoundghori's Avatar
Member: 575597
Sonork: 100.1590575
Thanks Meter: 559
hi
simple....just flash it to 6030
write pm and unlock...
modefied filter....goodluck....!!!
Old 10-11-2008, 12:29   #5 (permalink)
Member: 206476
Thanks Meter: 459
Originally Posted by newfoundghori View Post
hi
are u drink some think bro rh-74 is dct4 and joni seek for one 6300 bb5 so u are wrong bro
wbr
The Following 2 Users Say Thank You to freeman2001 For This Useful Post:
Old 10-11-2008, 12:37   #6 (permalink)
Faster Update's Avatar
Member: 85757
Sonork: 100.1581882
Thanks Meter: 23
thx for all members
Hi
you need convert 6300b to 6300
step 1 flash phone 6300 after flash write pm
step 2 unlocke your phone
step 3 change filter .
your ready now working 900 mhz .
BR.
Wawe
The Following User Says Thank You to Faster Update For This Useful Post:
Old 10-11-2008, 13:12   #7 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
Thanks Meter: 140
no need to change filter or flash file
no any solution for this
see this
and forget convert this
/vbb/showthread...=6300b+convert
Old 10-11-2008, 13:18   #8 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
see this
sir the topic here is 5300b convert where is the 6300b? thank you sir...
Old 10-11-2008, 13:24   #9 (permalink)
gerovgsm's Avatar
Member: 52180
Thanks Meter: 47
900Mhz is disabled in phone certifiкate
so-no way
Old 10-11-2008, 13:47   #10 (permalink)
Member: 508072
Thanks Meter: 1,621
i try to pur 6300 filter and also fleshed that phon with 6300 firmwere after that i use sx auth for writing pm afer writing pm file problem still
1800mhz working 900 mhz not working still
Old 10-11-2008, 14:48   #11 (permalink)
Member: 85757
Sonork: 100.1581882
Thanks Meter: 23
impossible man i change 3 phones 6300b to 6300 working ok 900:1800
you sure filter work .Try change filter and not need Sx4 .
im sure for change 6300b to 6300following.
Br.
Wawe
Old 01-04-2009, 12:03   #12 (permalink)
Member: 216844
Thanks Meter: 30
Br.
Wawe
this solution not worck after chenged 2 filter and flashed with 6300 rm217 write pm 6300 rm217 no netvorck need picture hardver
The Following User Says Thank You to Selmir For This Useful Post:
Old 01-04-2009, 12:46   #13 (permalink)
kashi4gul's Avatar
Member: 460762
Sonork: 100.1592082
Thanks Meter: 3,104
Change this filter and write this attached pm
and see the result, it should b work.
B.R.,
kashi4gul
File Type: rar 6300_RM-217_Full+Working modified PM.rar (7.2 KB, 388 views)
The Following User Says Thank You to kashi4gul For This Useful Post:
Old 06-26-2009, 21:39   #14 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
B.R.,
kashi4gul
any one try this solution
Old 06-26-2009, 21:45   #15 (permalink)
Member: 909622
Thanks Meter: 8
I have a issue ,6300 imei not showing *#06# = i want to input a new imei and it must work with the code (*#06#) to check imei , please can you give some guide line how can i overcome this issue...
also the other problem is if i dont use it for few minutes phone is auto off.
Battery is Fine, what can be the possible reason and how it can be resolved.
pls explain...
Thank you in advance
how to convert 6300b to 6300 plz help amanhalwara Nokia Hardware & Hardware Repair 3 06-26-2009 22:19
Page generated in 0.23661 seconds with 10 queries
