Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 11-26-2006, 00:10   #1 (permalink)
Member: 193023
Thanks Meter: 7
How to install RM-84_dp_v9.0/9.01/9.02/9.03/9.04...
I have installed the package :
N70_RM-84_dp_v9.0_SW5.0638.3.0.1_EURO
all ok when i install the upgrade dpv 9.01 ( RM-84_dp_v9.01_SW5.0638.3.0.1_EURO) the upgrade search the rm84-dpv9.0 same chose for 9.02 9.03 9.04
Bu i have installed befor the 9.0...
Any ideas?
Regards
Old 11-26-2006, 01:39   #2 (permalink)
Lomnica_city's Avatar
Member: 275559
Thanks Meter: 6
Your post is veeeery confusing,what is it that you wanna know actualy?
Do you have to install all of those packages?If that's what's bothering you,the answer is that it's suficient to install 9.0 and then upgrade to the latest package,in your case 9.04,and that's it,you're ready to flash!!
Pozdrav
Old 11-26-2006, 03:21   #3 (permalink)
Member: 243420
Thanks Meter: 6
Deltafox
Is it possible that you didn't uninstall the previous Data Package before installing the new one??
That could cause confusion within Phoenix or other programs and it is clearly expressed that you should uninstall old packages before upgrading to new ones.
Bavarianchris
Old 11-26-2006, 14:19   #4 (permalink)
Member: 193023
Thanks Meter: 7
I use Jaf
I have unistalled all previus version of RM-84 from my pc...
After I follow this step :
1) Install RM-84_dp_v9.0_SW5.0638.3.0.1_EURO
All ok
Now i tried to install the Upgrade 9.01.. whit the RM-84_dp_v9.01_SW5.0638.3.0.1_EURO
But it is impossible the v9.01 ask me the v9.0 installed but i have also installed v 9.0..
This the image of my problem.. i have installed v9.0 but when I Install v9.01 i have this error : see the image athis link :
Link Image
This is a problem of nokia pakage? The v9.01 don't recognize the v9.0 installed..
Regards
Old 11-26-2006, 15:04   #5 (permalink)
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,681
Lightbulb
it's mean that you installed dp version 8.0 and didn't uninstall it,now you can try first to remove every version for RM-84 from add remove programs and then install your desired dp versions.
Old 11-26-2006, 22:21   #6 (permalink)
Member: 193023
Thanks Meter: 7
I have unistall all version rm-84 incluse dpv 8.0 but i have same error I have tested this also on new computer and i have installed dpv 9.0 but v9.01 not install..
Work 9.01 for you? you can test this?...
Regards
Old 11-27-2006, 08:14   #7 (permalink)
Member: 386949
Regards
I have very same problem, install 9.0 without problem then 9.1 ask me to install 9.0 first . Maybe the bug is 9.1?
Old 11-30-2006, 16:08   #8 (permalink)
m4m
Member: 126208
Thanks Meter: 52
whay you need to install 9.1???
Old 12-03-2006, 03:21   #9 (permalink)
Member: 193023
Thanks Meter: 7
v9.01 9.02 etc have more language and brand...
Regards
Old 01-07-2007, 00:31   #10 (permalink)
Member: 193023
Thanks Meter: 7
I ask if someone has ever succeeded in installing the versions 9.01 .... 9.07?
it is impossible to install these updatings
answer me
regards
Old 01-07-2007, 02:15   #11 (permalink)
Member: 61378
Me too facing the same problem, can any one help us out with this issue.
i can install only 9.0 later versions give the same error as mentioned above. Is there any way to install them.
Help us
Thank you
Old 01-07-2007, 13:23   #12 (permalink)
Member: 9848
Thanks Meter: 143
The first released RM-84 dp 9.0 was faulty.
NK released a second one.
Old 01-08-2007, 02:34   #13 (permalink)
Member: 193023
Thanks Meter: 7
How to download the second one?
Many Thank's
Old 01-08-2007, 16:30   #14 (permalink)
Member: 193023
Thanks Meter: 7
does nobody know where to be able to Download the version dpv 9.0 correct?
what he allow the installation of the updatings 9.01 .... 9.07?
Regards
Old 01-08-2007, 22:59   #15 (permalink)
Handycracker2k2's Avatar
Member: 20633
Thanks Meter: 193
dont worry start regedit, and search for RM 84 DP entry, there is a MAJOR Version and a DP Version entry!
major is 8.0 to due error in installer, just set this to 9.0 and all problems are gone easy, isntīt it ?
here is link to this entry: HKLM\Software\Nokia\DataPackages\RM-84 PHone Data Package EURO
br
how to unlock iphone 3.0 louisgsm iPhone 2 / iPhone 3G / iPhone 3GS 10 03-29-2010 15:53
how to install crassy 5.0 fancyvpp NEC 0 05-23-2005 16:35
Universal SP Unlocker Update 5.01-5.02-5.03 valti Universal GSM Software 3 04-22-2001 07:46
Page generated in 0.34338 seconds with 9 queries
