08-12-2011, 11:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | How to modified your nokia usb cable tested 100% Tutorial is for Already Locked Phone by Security Code or Lock Code and When you don't have a RJ45 cable or which is not Modified!!!!!!! What is Test Mode ? Nokia has three modes of working : Normal Mode Local Mode Test Mode Now when your nokia phone is ALREADY LOCKED WITH SECURITY CODE it does not get connected to the PC through its supplied Dku2 cable. As the phone blocks the functioning of its usb pin and pc does not detect any USB device. Now in that case if you start your phone in Test or local Mode, PHONE GETS CONNECTED TO PC VIA DKU2 (your supplied usb cable) and hence can be used or repaired my any software like mt box, jaf or nemises suit. So then you can perform all operations on it without even formating , like: -RESET YOUR SECURITY CODE -GENERATING PM FILE -GENERATING ASK FILE -FLASHING (formats everything) Now How to do it ??? BSI NEGATIVE POSITIVE NOKIA-C5 RPL Backup. Reading RPL backup ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 94AF0A CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 1BF00019AB9C0344FBE5B7BCFA8D0BC45BB0ADEF CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 94AF0A FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35433004574665 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: 3791BB9 Verifying communication to device OK. NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA is empty. RPL saved to "C:\Documents and Settings\zcs\Desktop\BB5_35433004574665_BACK.rpl" PM-BACKUP-C5 Reading PMM area 0 - 512, please WAIT ... Section: 1 - got 28 key(s) - key: 0, readed 114 bytes - key: 2, readed 10 bytes - key: 4, readed 110 bytes - key: 6, readed 10 bytes - key: 7, readed 214 bytes - key: 8, readed 110 bytes - key: 13, readed 10 bytes - key: 16, readed 208 bytes - key: 18, readed 208 bytes - key: 20, readed 208 bytes - key: 22, readed 16 bytes - key: 23, readed 4 bytes - key: 24, readed 84 bytes - key: 26, readed 110 bytes - key: 28, readed 10 bytes - key: 29, readed 10 bytes - key: 31, readed 208 bytes - key: 33, readed 36 bytes - key: 34, readed 376 bytes - key: 35, readed 16 bytes - key: 37, readed 4 bytes - key: 39, readed 36 bytes - key: 40, readed 16 bytes - key: 41, readed 182 bytes - key: 42, readed 4 bytes - key: 43, readed 36 bytes - key: 44, readed 182 bytes - key: 45, readed 182 bytes Section: 2 - got 1 key(s) - key: 0, readed 2080 bytes Section: 4 - got 5 key(s) - key: 3, readed 10 bytes - key: 4, readed 8 bytes - key: 5, readed 8 bytes - key: 6, readed 8 bytes - key: 9, readed 5 bytes Section: 6 - got 1 key(s) - key: 0, readed 32 bytes Section: 8 - got 10 key(s) - key: 0, readed 2 bytes - key: 1, readed 16 bytes - key: 2, readed 16 bytes - key: 3, readed 128 bytes - key: 4, readed 128 bytes - key: 5, readed 8 bytes - key: 7, readed 4 bytes - key: 8, readed 8 bytes - key: 9, readed 8 bytes - key: 10, readed 32 bytes Section: 11 - got 5 key(s) - key: 0, readed 4 bytes - key: 1, readed 4 bytes - key: 2, readed 4 bytes - key: 3, readed 4 bytes - key: 4, readed 1058 bytes Section: 12 - got 1 key(s) - key: 0, readed 102 bytes Section: 26 - got 2 key(s) - key: 0, readed 16 bytes - key: 1, readed 68 bytes Section: 31 - got 1 key(s) - key: 4, readed 18 bytes Section: 44 - got 1 key(s) - key: 0, readed 1 bytes Section: 50 - got 1 key(s) - key: 0, readed 2 bytes Section: 54 - got 2 key(s) - key: 0, readed 2 bytes - key: 2, readed 24 bytes Section: 88 - got 1 key(s) - key: 0, readed 36 bytes Section: 96 - got 2 key(s) - key: 0, readed 2 bytes - key: 1, readed 20 bytes Section: 107 - got 6 key(s) - key: 0, readed 41 bytes - key: 1, readed 89 bytes - key: 2, readed 89 bytes - key: 3, readed 70 bytes - key: 25, readed 236 bytes - key: 26, readed 12 bytes Section: 117 - got 11 key(s) - key: 0, readed 4 bytes - key: 1, readed 3 bytes - key: 2, readed 6 bytes - key: 3, readed 1 bytes - key: 4, readed 9 bytes - key: 5, readed 10 bytes - key: 6, readed 8 bytes - key: 8, readed 42 bytes - key: 13, readed 3 bytes - key: 14, readed 3 bytes Copy of readed PM saved to: "data\backup\PM\RM-645_354330045746651_11_08_11_232633.pm" Completed in 9 min 24.641 s |
The Following 15 Users Say Thank You to Dooha_Bd For This Useful Post: |
08-13-2011, 14:32 | #2 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan
Member: 277937 Status: Offline Thanks Meter: 48 | [QUOTE=Dooha_Bd;7620724]How to modified your nokia usb cable tested 100% Tutorial is for Already Locked Phone by Security Code or Lock Code and When you don't have a RJ45 cable or which is not Modified!!!!!!! What is Test Mode ? Nokia has three modes of working : Normal Mode Local Mode Test Mode Now when your nokia phone is ALREADY LOCKED WITH SECURITY CODE it does not get connected to the PC through its supplied Dku2 cable. As the phone blocks the functioning of its usb pin and pc does not detect any USB device. Now in that case if you start your phone in Test or local Mode, PHONE GETS CONNECTED TO PC VIA DKU2 (your supplied usb cable) and hence can be used or repaired my any software like mt box, jaf or nemises suit. So then you can perform all operations on it without even formating , like: -RESET YOUR SECURITY CODE -GENERATING PM FILE -GENERATING ASK FILE -FLASHING (formats everything) Now How to do it ??? BSI NEGATIVE POSITIVE NOKIA-C5 RPL Backup. Reading RPL backup ... Reading Secure Storage ... Reading SIMLOCK data ... Reading CERT data ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 94AF0A CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 1BF00019AB9C0344FBE5B7BCFA8D0BC45BB0ADEF CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 94AF0A FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Flash Imei: 35433004574665 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: 3791BB9 Verifying communication to device OK. NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA is empty. RPL saved to "C:\Documents and Settings\zcs\Desktop\BB5_35433004574665_BACK.rpl" PM-BACKUP-C5 Reading PMM area 0 - 512, please WAIT ... Section: 1 - got 28 key(s) - key: 0, readed 114 bytes - key: 2, readed 10 bytes - key: 4, readed 110 bytes - key: 6, readed 10 bytes - key: 7, readed 214 bytes - key: 8, readed 110 bytes - key: 13, readed 10 bytes - key: 16, readed 208 bytes - key: 18, readed 208 bytes - key: 20, readed 208 bytes - key: 22, readed 16 bytes - key: 23, readed 4 bytes - key: 24, readed 84 bytes - key: 26, readed 110 bytes - key: 28, readed 10 bytes - key: 29, readed 10 bytes - key: 31, readed 208 bytes - key: 33, readed 36 bytes - key: 34, readed 376 bytes - key: 35, readed 16 bytes - key: 37, readed 4 bytes - key: 39, readed 36 bytes - key: 40, readed 16 bytes - key: 41, readed 182 bytes - key: 42, readed 4 bytes - key: 43, readed 36 bytes - key: 44, readed 182 bytes - key: 45, readed 182 bytes Section: 2 - got 1 key(s) - key: 0, readed 2080 bytes Section: 4 - got 5 key(s) - key: 3, readed 10 bytes - key: 4, readed 8 bytes - key: 5, readed 8 bytes - key: 6, readed 8 bytes - key: 9, readed 5 bytes Section: 6 - got 1 key(s) - key: 0, readed 32 bytes Section: 8 - got 10 key(s) - key: 0, readed 2 bytes - key: 1, readed 16 bytes - key: 2, readed 16 bytes - key: 3, readed 128 bytes - key: 4, readed 128 bytes - key: 5, readed 8 bytes - key: 7, readed 4 bytes - key: 8, readed 8 bytes - key: 9, readed 8 bytes - key: 10, readed 32 bytes Section: 11 - got 5 key(s) - key: 0, readed 4 bytes - key: 1, readed 4 bytes - key: 2, readed 4 bytes - key: 3, readed 4 bytes - key: 4, readed 1058 bytes Section: 12 - got 1 key(s) - key: 0, readed 102 bytes Section: 26 - got 2 key(s) - key: 0, readed 16 bytes - key: 1, readed 68 bytes Section: 31 - got 1 key(s) - key: 4, readed 18 bytes Section: 44 - got 1 key(s) - key: 0, readed 1 bytes Section: 50 - got 1 key(s) - key: 0, readed 2 bytes Section: 54 - got 2 key(s) - key: 0, readed 2 bytes - key: 2, readed 24 bytes Section: 88 - got 1 key(s) - key: 0, readed 36 bytes Section: 96 - got 2 key(s) - key: 0, readed 2 bytes - key: 1, readed 20 bytes Section: 107 - got 6 key(s) - key: 0, readed 41 bytes - key: 1, readed 89 bytes - key: 2, readed 89 bytes - key: 3, readed 70 bytes - key: 25, readed 236 bytes - key: 26, readed 12 bytes Section: 117 - got 11 key(s) - key: 0, readed 4 bytes - key: 1, readed 3 bytes - key: 2, readed 6 bytes - key: 3, readed 1 bytes - key: 4, readed 9 bytes - key: 5, readed 10 bytes - key: 6, readed 8 bytes - key: 8, readed 42 bytes - key: 13, readed 3 bytes - key: 14, readed 3 bytes but 1 thing this usb cable working like battery. cable only because here u use to cables its org usb cable and second u made too...............explain?????????? |
The Following User Says Thank You to danishshah For This Useful Post: |
08-17-2011, 13:13 | #4 (permalink) |
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | This is for- Already Locked Phone by Security Code or Lock Code and When you don't have a RJ45 cable or which is not Modified!!!!!!! |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
