Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6 |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Nov 2003 Location: My Room (its small, but I like it :) )
Member: 43098 Status: Offline Thanks: 0
| How To Put N95 8gb in Test Mode? - Help? I have a N95 8gb that is Security Locked (not SP locked, but Security or PIN Code locked) and I cant use my computer software to try and reset the code since the USB is locked out from the code. So my question is: How can I put this phone in "Test Mode" or "Local Mode" so I can activate the USB port of the phone and then use my software to reset the code? Many thanks in advance for any help. I truly appreciate it. *NOTE* I have been searching for awhile now, but everything I come across is for a box of some sort, I'm looking for a solution just for a computer and phone, no box. Again many thanks in advance. |
| | #3 (permalink) |
| Thanks for your reply, but I have already seen and read that thread. If you read post 2 of that thread, they quote my same problem. When a Symbian 3rd device is security locked, the USB is locked aswell, so when I try that software, my computer doesnt see the phone because the USB port on the phone is locked out. And that is my problem. How can I get my computer to see the phone, since the USB port is locked out from the security code.... |
| | #4 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks: 37
| Quote:
ok try this Remove standard battery from phone. Look on battery where are +,- so you can find +,- on phone 3 pin battery conector. 3-th lefted pin is BSI ! Now use resistor of 10K and one wire of resistor connect to "-" and second wire to BSI. Now connect Power suply set to 4,6V and 300mA and connect to +,- on phone battery conector. Connect FBUS (DKU-5) to phone and PC. Power phone ON and phone will go into test mode. | |
| The Following User Says Thank You to sharaz191 For This Useful Post: |
| | #6 (permalink) | |
| Major Poster ![]() ![]() Join Date: Nov 2005 Location: CV, Ukraine
Member: 197849 Status: Offline Thanks: 1
| Quote:
| | #7 (permalink) | |
| Quote:
Alright so if I understand this correctly, if I put the resistor on the BSI line just like instructed, it will not work with my original oem factory nokia usb cable? (DKU-2) I have to get a unlocking box, and go from there? Also, what does everybody mean by FBUS? Sometimes I see it being referred to as a USB cable, other times I see it being referred to as a box cable with a enthernet jack on the other end.... So i'm confused. Thanks again | |
| | #8 (permalink) |
| Well, I tried using a 10k resistor and a 8.2k resistor between the BSI line and the - Line of the back battery terminals, and nothing happend. The phone just booted up like normal and still asked me for the lock code, it did not go into local mode or test mode... Is there something that I am doing wrong? |
| | #9 (permalink) |
| IT WORKED! The 8.2k resistor does infact put a N95 8gb into Local Mode! Apparently the first time I tried it, I didnt have enough connection for the resistor... I tried a few more times, and made sure there was connection, and it worked like a charm! Many many many thanks to sharaz191 and everyone else that helped me on this forum, I read alot of information here about this issue and finally I got everything working. Thanks |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: Canary Islands Age: 42
Member: 17351 Status: Offline Thanks: 43
| Or use BB5 Box to reset phone code lock etc Take battery out plug in BB5 box cable and select full factory and its sorted ![]() Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-320 Version: V_06wk41v51.3_13-02-08_RM-320_(c)_Nokia IMEI: 356983019492450 SP LOCK status: Config Key: 2341500000000000 Block 1: CLOSED Type 5 Data: 23415F Block 2: CLOSED Type 5 Data: 23415F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK |
| The Following User Says Thank You to The Dog For This Useful Post: |
| | #12 (permalink) | |
| Crazy Poster ![]() ![]() ![]() Join Date: Jul 2009
Member: 1074149 Status: Offline Thanks: 14
| Should I not use the "TX" adapter for the cyclone when doing your procedure? Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem to put gx 30 in test mode ??? | mannny | Sharp | 11 | 03-21-2005 08:32 |
| does anyone know how to put gx3O, tm100 in diagnostic mode with keypad? | Sigma | Sharp | 10 | 09-16-2004 06:55 |
| how to put samsung phones in TEST MODE (for unlocking)?? | majid | Samsung Flashers, Software, Firmware. | 0 | 02-16-2002 09:21 |
| How to putting OLD Ericsson in test mode : read this | jonwillow | Old Ericsson Phones & Sony Phones | 0 | 02-23-2001 08:05 |
| How to put the phone into test mode?PLEASE! | Prodigal | Old Legacy Motorola (EMMI) | 1 | 12-26-2000 04:42 |
