Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 05-29-2015, 15:12   #1 (permalink)
Member: 1412237
Sonork: 100.1663820
Thanks Meter: 18
how to repair nokia 5233 some problem????
set problem phone lock i am try fleshing error set dead
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C088158E
Using device: USB ROM and HTI, FW ver: 00.50, SN: 01013CCF
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.117
Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
Processing MCU file: RM-625_51.1.002_prd.core.C00
[BB5,XSR 1.6] size: 95.97 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1820020223960052BEBF5379DFC825F2E7DE0EA1
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped due to protocol limitation.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
Error while programming [00] at 0x00084400, Result: 0000
Old 06-01-2015, 18:57   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
I don't know if u get any sucess by flash with mx **** ! but u may try flash with another third party tool .
also post here full history of ur set .
Page generated in 0.14056 seconds with 9 queries
