How To Reset Keypad Lock On E65? (security Code ) How To Reset Keypad Lock On E65? Phone Was Locked I Removed It In Jaf In Usbmote,then Phone Is Ok, But Keypad Locked After 2 Minutes-to Unlock Key Pad Then Asking Security Code (12345) Wrong Code But Code Was 12345 In Jaf ....how To Remove It...help... |
@CHAPRAN is it have arabic in it? |
do u i setting, and after that format user area either with jaf or with hwk thats works perfect take care shoaib |
just do fullfactory default from jaf first and try to format your phone & MMc card sir... thanks |
just do full factory, ui default,format user |
u must full flash the set,i try before solve 100% |
make defaul security code with " NSS " and DKU2 cable :D |
e65 user code just full flash the phone with mt everything will be ok tested 100% |
ok first just remember that when you read the code you format user area with jaf this will reset the phone to default which is 12345 only then can you go into security setings and disable keypad security with the default code. |
ok how remove Security Code with factory set i don't lose info and i want fast |
my brother 1 solution is full flash then reset phone but user code dont delet or reset only keypad locker willbe off |
you got only 2 solution mate its either you fullflash it!! or do factory set full & user data reset ! good luck!! |
