Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 10-08-2007, 10:45   #1 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 101
How To Reset Keypad Lock On E65? (security Code )
How To Reset Keypad Lock On E65? Phone Was Locked I Removed It In Jaf In Usbmote,then Phone Is Ok, But Keypad Locked After 2 Minutes-to Unlock Key Pad Then Asking Security Code (12345) Wrong Code But Code Was 12345 In Jaf ....how To Remove It...help...
Old 10-08-2007, 13:37   #2 (permalink)
Member: 567351
Thanks Meter: 40
@CHAPRAN
is it have arabic in it?
Old 10-08-2007, 14:01   #3 (permalink)
mohamed75's Avatar
Member: 102762
Sonork: 1583079
Thanks Meter: 186
just do full factory defaults from jaf software
Old 10-19-2007, 04:43   #4 (permalink)
shoaibk7's Avatar
Member: 145000
Thanks Meter: 20
do u i setting, and after that format user area either with jaf or with hwk thats works perfect
take care
shoaib
Old 10-19-2007, 07:10   #5 (permalink)
lie_james's Avatar
Member: 531344
Thanks Meter: 23
just do fullfactory default from jaf first and try to format your phone & MMc card sir...
thanks
Old 10-19-2007, 10:24   #6 (permalink)
Member: 508598
Thanks Meter: 11
just do full factory, ui default,format user
Old 10-19-2007, 16:30   #7 (permalink)
Member: 211406
Thanks Meter: 2
u must full flash the set,i try before solve 100%
Old 10-19-2007, 17:09   #8 (permalink)
mariochines's Avatar
Member: 283371
Thanks Meter: 13
make defaul security code with " NSS " and DKU2 cable
Old 10-19-2007, 17:38   #9 (permalink)
clearcom's Avatar
Member: 120669
Thanks Meter: 15
agree with that
Old 01-17-2008, 14:00   #10 (permalink)
Member: 203855
Thanks Meter: 4
e65 user code
just full flash the phone with mt everything will be ok tested 100%
Old 01-17-2008, 15:14   #11 (permalink)
luqmaan's Avatar
Member: 617428
Thanks Meter: 52
ok first just remember that when you read the code you format user area with jaf this will reset the phone to default which is 12345 only then can you go into security setings and disable keypad security with the default code.
Old 02-17-2008, 03:48   #12 (permalink)
Member: 273705
Thanks Meter: 34
Same problem...done with J.A.F. + DKU2 just do factory set full & user data reset !
Old 10-10-2008, 21:53   #13 (permalink)
Member: 350832
ok how remove Security Code with factory set i don't lose info and i want fast
Old 10-10-2008, 23:53   #14 (permalink)
Member: 592636
Thanks Meter: 674
my brother
1 solution is full flash then reset phone but user code dont delet or reset only keypad locker willbe off
Old 10-11-2008, 06:14   #15 (permalink)
watari31's Avatar
Member: 141262
Thanks Meter: 348
you got only 2 solution mate its either you fullflash it!! or do factory set full & user data reset ! good luck!!
How to Reset User Lock on New N96 Have UFS Box Rexys Nokia Base Band 5 ( BB-5 ) 1 11-06-2008 12:04
how to reset phone lock on sagem my 220x??? ABDELFATTAH NET Infinity-Box 1 06-02-2008 06:48
Need to reset user lock on BH4 phones using Vygis How to do it?? ReyTech VygisToolbox 7 06-26-2007 13:06
how to reset sim lock password on E800?please ramos SYSOL Platform 3 01-15-2005 10:06
how to reset 4 locks on t600 douda Sony Ericsson 1 01-04-2004 06:04
Page generated in 0.19817 seconds with 9 queries
