05-10-2018, 20:35 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 599952 Status: Offline Thanks Meter: 0 | How to upgrade firmware in Nokia Car Kit CK-100, 200, 300 and 600 ? I am trying to upgrade firmware in two of my Nokia Car Kits and it seems it is almost impossible these days. During 2016 all of the Nokia servers went down and now the Nokia Car Kit Software Updater (NCKU) is unable to contact them to receive firmware files. Here is what I have already tried: 1) Obtaining the firmware files for Car Kits: - Nokia servers where NCKU connects to obtain firmware files are down - Nokia Firmware Suite does not have the firmware for Car Kits in repository - You can obtain “some” of the files occasionally on the file hosting servers but definitely not all of them (for instance language specific firmware files are almost impossible to be found on the internet) 2) Upgrading the firmware - NCKU won’t accept the firmware from My Documents\Nokia Firmware folder (same problem as described here: /vbb/f139/nokia-ck-300-upgrade-2118036/#post13100096) - Phoenix – won’t connect with the Car Kits at all - Nokia Care Suite - won’t connect - Care Suite For Store - won’t connect So the main question: How to update firmware in Nokia Car Kits these days? How to obtain all of the firmware files? Thanks, gombik |
05-13-2018, 06:09 | #2 (permalink) | |
Crazy Poster Join Date: Dec 2016 Location: Downtown Bay
Member: 2661088 Status: Offline Thanks Meter: 9 | Quote:
It's good to see someone like you still uses Nokia Car Kits these days and I shall be happy to help you with providing firmware for your Nokia Car Kit. Let me know what all you need. What kind of cable you are using to upgrade Nokia CK-100, 200, 300 and 600 ? | |
05-15-2018, 12:50 | #3 (permalink) | |
Junior Member Join Date: May 2018
Member: 2837484 Status: Offline Thanks Meter: 0 | Quote:
I've got exactly the same problem as gombik described. I'd like to upgrade my CK-200. I installed NokiaCarKitUpgrader, and have put proper files in MyDocuments/Nokia Firmware/CK-200/<product code> folders. Unfortunately NCKU still sees no files. When I sniff it with Process Monitor I can see NCKU goes through all the firmware directories and even reads *.vpl files but this doesn't help. Any idea how to force it to work? Or any other method? I've all the *.vpl and *.dfu files for CK-200 (all FW versions and languages) and I'd be happy to trade them for valid instructions how to push them into the kit. :-) BTW: I'm using standard USB cable. Best regards, Lucas | |
05-19-2018, 19:36 | #4 (permalink) |
Member: 599952 Status: Offline Thanks Meter: 0 | Hi Guys, For start it would be beneficial to have all of the firmware files available. Personally for me I have the CK-100 and CK-200 installed and both have the factory firmware without any update. The CK-100 is using USB Mini B and the CK-200 micro USB connector. The NCKU behaves exactly as lcielecki described. The NCKU read all the files but displays an error “No software variant was found on local storage”. I disassembled the NCKU and looked for hidden command line switch to enable at least some debug logging, but It seems nothing like that is present in the app. Does anyone know about software for testing these Kits? I highly doubt that Nokia was developing the firmware without some kind of app like Phoenix was… That way we could identify and try to obtain a software that should be able to flash the CK devices. What I´m trying to achieve here is to create a comprehensive guide for other users to let them perform the firmware upgrade of Nokia Car Kit’s. Regards, gombik |
