Make free RPL for SL3 Series For ""problem Simlock"" Hurry UP. In this thread, you can provide full pm to your phone and send it in this thread get rpl file and burn on the phone to SIM lock issue is resolved. If you receive RPL will be available in all fields, including the 120 and 308 and healthy. This solution is for phones that are not manipulated. So it is better before doing anything, use this thread. For an appropriate response in this thread I should get BUS Check phone and full pm with the attached field including Reed taking place from 1 to 512. (The posts will not consider incomplete) Please download the rpl and burn it on the phone again put BUS Check. Samples can be solved this time: First example: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322*******34-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed SECURITY_TEST failed! SIMLOCK_DATA corrupted Second sample: Phone Type: RM-443 (Nokia 6303 classic) SW Version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 353199035*****-0 Product Code: 0577422 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted More examples can be solved will be presented. Note that the series should be available. Good luck. |
ALL the SL3 PHONE Simlock Repair |
hi...i got 2 5130c contact service...simlock data currupted ..possible to solve...if yes then what u need |
patel 5130 full pm RM-495_355212037613017.pm - 4shared.com - online file sharing and storage - download full rpl backup... patel 5130 full rpl backup with lock dataBB5_35521203761301_BACK.rpl - 4shared.com - online file sharing and storage - download send me rpl and guide me how to write.. |
Code: |
Download the RPL file and Write To Phone......:D:D:D patel 5130 full pm RM-495_355212037613017_E.M.S.C.rpl - 4shared.com - online file sharing and storage - download |
here is one contact service: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35422303033050-0 Product Code: 0576625 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! rpl backup:BB5_35422303033050_BACK.rar - 4shared.com - online file sharing and storage - download pm :pm 5130.rar - 4shared.com - online file sharing and storage - download |
use the Poste#8 Download RPL File and Write To Phone GOOD LUCK |
test The RPL File and sned Bus chek AFTER THEN Write RPL file E.M.S.C-WITH SINA.rpl - 4shared.com - online file sharing and storage - download GOOD LUCK |
totally fake.:(:(:(:(:( |
missing NPC data in the RPL file, skipped. Certificate programmed successfully ! yes it's not working and time passing stop joking and time passing foolish...................... |
:D heheheheheheheheheheh:D Hurry UP RPL for SL3 Series For "" Simlock problem"" . repair Fake solution |
how to write... |
