07-29-2010, 10:58 | #1 (permalink) |
Insane Poster Join Date: Dec 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 929647 Status: Offline Thanks Meter: 37 | Make free RPL for SL3 Series For ""problem Simlock"" Hurry UP. If you receive RPL will be available in all fields, including the 120 and 308 and healthy. This solution is for phones that are not manipulated. So it is better before doing anything, use this thread. For an appropriate response in this thread I should get BUS Check phone and full pm with the attached field including Reed taking place from 1 to 512. (The posts will not consider incomplete) Please download the rpl and burn it on the phone again put BUS Check. Samples can be solved this time: First example: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322*******34-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed SECURITY_TEST failed! SIMLOCK_DATA corrupted Second sample: Phone Type: RM-443 (Nokia 6303 classic) SW Version: V 10.10 18-11-09 RM-443 (c) Nokia Imei plain: 353199035*****-0 Product Code: 0577422 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted More examples can be solved will be presented. Note that the series should be available. Good luck. |
The Following 21 Users Say Thank You to sat_help For This Useful Post: |
07-29-2010, 12:22 | #4 (permalink) |
No Life Poster Join Date: Apr 2008 Location: IT POINT Ankleshwar
Member: 756719 Status: Offline Thanks Meter: 80 | full pm backup patel 5130 full pm RM-495_355212037613017.pm - 4shared.com - online file sharing and storage - download full rpl backup... patel 5130 full rpl backup with lock dataBB5_35521203761301_BACK.rpl - 4shared.com - online file sharing and storage - download send me rpl and guide me how to write.. |
The Following User Says Thank You to jasperali For This Useful Post: |
07-29-2010, 13:06 | #5 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Behind u...
Member: 1355122 Status: Offline Sonork: inside certificate Thanks Meter: 34 | Code: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322*******34-2 Product Code: 0577793 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed SECURITY_TEST failed! SIMLOCK_DATA corrupted |
07-29-2010, 13:32 | #6 (permalink) | |
Member: 929647 Status: Offline Thanks Meter: 37 | Quote:
Download the RPL file and Write To Phone...... patel 5130 full pm RM-495_355212037613017_E.M.S.C.rpl - 4shared.com - online file sharing and storage - download | |
The Following 3 Users Say Thank You to sat_help For This Useful Post: |
07-29-2010, 14:06 | #7 (permalink) |
Insane Poster Join Date: May 2010
Member: 1298717 Status: Offline Thanks Meter: 43 | here is one contact service: Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35422303033050-0 Product Code: 0576625 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! rpl backup:BB5_35422303033050_BACK.rar - 4shared.com - online file sharing and storage - download pm :pm 5130.rar - 4shared.com - online file sharing and storage - download |
07-29-2010, 14:32 | #8 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 465286 Status: Offline Thanks Meter: 77 | Quote:
The Following 5 Users Say Thank You to icu778 For This Useful Post: |
07-29-2010, 14:37 | #9 (permalink) | |
use the Poste#8 Download RPL File and Write To Phone GOOD LUCK | |
07-29-2010, 14:56 | #11 (permalink) |
Member: 929647 Status: Offline Thanks Meter: 37 | test The RPL File and sned Bus chek AFTER THEN Write RPL file E.M.S.C-WITH SINA.rpl - 4shared.com - online file sharing and storage - download GOOD LUCK |
07-29-2010, 15:03 | #12 (permalink) | |
Member: 756719 Status: Offline Thanks Meter: 80 | Quote:
totally fake. | |
07-29-2010, 15:08 | #13 (permalink) | ||
Member: 1298717 Status: Offline Thanks Meter: 43 | Quote:
missing NPC data in the RPL file, skipped. Certificate programmed successfully ! yes it's not working and time passing stop joking and time passing foolish...................... | ||
The Following User Says Thank You to 3G WORLD For This Useful Post: |
07-29-2010, 15:12 | #15 (permalink) | |
how to write... | |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
