Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-07-2009, 01:25   #1 (permalink)
Member: 1034197
Sonork: freedom on my mind
mms settings vodafone ireland for nokia e66 wouldn't work...
Hi, does enyone know what may be the problem with settings for nokia e66 mms service? I've recived configuration sms from provider but it doesn't work, i'd try to set it manualy but without success. Nokia originally comes from orange Poland, mobile is unlocked and works in every network. Anyone can help? Please.
Old 06-07-2009, 01:44   #2 (permalink)
octavyus's Avatar
Member: 242469
Thanks Meter: 503
YOU CAN OBTAIN EASSY CONFIGURATION IN
www.nokia.com
or call to customer certer
B.R
Old 06-07-2009, 10:26   #3 (permalink)
Member: 1034197
I did call to customer service but they weren't helpfull. Nobody has been able to help me. They set up my occount, after that still without success. Also they said that nokia must be set manually. In www.nokia.com section "Test if your new device needs settings to send multimedia messages (MMS) and to browse the Internet." gets me through here : "Please contact your operator or service provider directly or via their internet pages for settings. "...
Old 06-08-2009, 10:45   #4 (permalink)
Member: 1034197
My access point settings: "Connection name" Vodafone MMS, "Data bearer" Packet data, "Access point name" mms.vodafone.net, "User name" dublin, "Prompt password" no, "Password" dublin, "Autentication" Normal, "Homepage" http://www.vodafone.ie/mms. "Unable to send message" detalis "Unable to send" Is there any think else causing message unable to send like device sittings ? What may be the cause of malfunction? If anybody found out similar problem, please, let me know how to fix it. Thanks .
Old 06-08-2009, 10:52   #5 (permalink)
Member: 1034197
Access point advenced settings: "Network type" IPv4, "Phone IP address" Automatic, "DNS address" Automatic, "Proxy server address" 10.24.59.200, "Proxy port number" 80.
Old 06-08-2009, 11:36   #6 (permalink)
ronandaly's Avatar
Member: 234917
Thanks Meter: 160
The settings you are using are correct. Try debranding the phone first. Then you will have a settings wizard in the phone menu to set up the phone correctly. Usually an E or N series Nokia is able to get the correct access point settings automatically from a Vodafone sim card although this will not happen because you have orange firmware on the phone.
Old 06-08-2009, 17:45   #7 (permalink)
Member: 1034197
I try to overwrite Orange Menu using NSS. I'm not sure what is correct "Product Code" for Vodafone Ireland. I've entered 0570280 and I'm have a try download new firmware. @ronandaly, you're very helpful, and this way may be correct but please tell me what does it mean: "No software updates available for your phone" and "Please note that your mobile service provider, operator or carrier may not have approved the latest nokia device firmware available". Even if I restore oryginal PC (0570820), this message occured and can't reinstall firmware. Help me please. Thanks.
Old 06-08-2009, 17:50   #8 (permalink)
Member: 1034197
P.S.
Of course "no software available..." means exactly that I've updated software 2 weeks ago, but I can't reinstall it now.
Old 06-08-2009, 19:09   #9 (permalink)
ronandaly's Avatar
Member: 234917
Thanks Meter: 160
register your phone number on www.vodafone.ie so you can log in and send the correct settings to your phone over the air. Also check in the mms settings that the correct profile is set as default ie. vodafone not orange.
Also are you able to access the internet (vodafone live)?
Old 06-09-2009, 11:05   #10 (permalink)
Member: 1034197
No, I'm not able to access vodafone live.
Old 06-09-2009, 11:53   #11 (permalink)
ronandaly's Avatar
Member: 234917
Thanks Meter: 160
Can you use mms and internet in another phone with this sim card?
Old 06-09-2009, 13:23   #12 (permalink)
Member: 1034197
I have downloaded the firmware update for PC 0557960 and...got new problem . Nokia won't start ! Anyway I'll check out later sim card in another phone. Now I need to back up symbian...
Old 06-09-2009, 13:45   #13 (permalink)
Member: 1034197
Leather Case for Nokia E66 Phone (white) - Original IPMART ipmart WebShop 0 10-30-2008 12:40
Compatible Silicone Case for Nokia E66 Phone (white) IPMART ipmart WebShop 0 10-15-2008 15:30
Compatible Silicone Case for Nokia E66 Phone (black) IPMART ipmart WebShop 0 10-15-2008 15:30
Compatible Crystal Case for Nokia E66 Phone (white) IPMART ipmart WebShop 0 10-15-2008 11:20
Compatible Crystal Case for Nokia E66 Phone (black) IPMART ipmart WebShop 0 10-15-2008 11:20
Page generated in 0.42188 seconds with 8 queries
