Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-12-2009, 07:54   #1 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
n73 not booting, flashing ok
i have an n73 ok condition sometime restarts so i flash it with ub. Flashing ok but when i power on it then it stops on only lights . here is self test...tell me plz
Executing self tests...
Passed [2E] ST_TAHVOINT_TEST
Passed [03] ST_UEM_CBUS_IF_TEST
Passed [0C] ST_EAR_DATA_LOOP_TEST
Passed [0D] ST_SIM_CLK_LOOP_TEST
Passed [21] ST_SIM_IO_CTRL_LOOP_TEST
Passed [5D] ST_SIM_LOCK_TEST
Passed [5A] ST_SECURITY_TEST
Passed [02] ST_PWR_KEY_TEST
Passed [14] ST_CURRENT_CONS_TEST
Passed [3A] ST_BACKUP_BATT_TEST
Not executed [38] ST_CMT_APE_WAKEUP_TEST
Passed [2A] ST_SLEEPCLK_FREQ_TEST
Passed [60] ST_RADIO_TEST
Passed [65] ST_HOOKINT_TEST
Passed [31] ST_BTEMP_TEST
Passed [08] ST_VIBRA_TEST
Passed [6C] ST_MBUS_RX_TX_LOOP_TEST
Passed [00] ST_EXT_DEVICE_TEST
TBB5SelfTestThread 2.7.7.2090 finished at: 2009/07/12 11:18:39
Done.
The Following User Says Thank You to sameer918 For This Useful Post:
Old 07-12-2009, 08:39   #2 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,338
flash with higher firmwere, & use 7pin fbus cable
The Following User Says Thank You to masum_sohel For This Useful Post:
Old 07-12-2009, 10:15   #3 (permalink)
mt mobiles's Avatar
Member: 241662
Sonork: 100.1603988
Thanks Meter: 145
flash with higher firmwere and use 7pin fbus cable .ur problem will be solved
Old 07-12-2009, 14:35   #4 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Full flashing log.....Where is problem?.....
MCU Nokia Version: 1.126, and up to date.
SMCU Nokia Version: 1.44, and up to date.
Flashing file:
BB5 [BB5 ALGORITHM] MCU File: N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx 50 061 kB
Speed: [51k, 6500k, 6500k, 98k] Baud.
Supported Hardwares: [0103192101003000, 010C192101003000]
Supported APE Hardwares: [17100708]
Input power: 10.93V OK.
Output power at Line1 3.93V is in range of: 4.00V 10.0%
Boot Loader: RAP3Gv3_2nd_fps8.fg 15 kB
Version: 1.20.2
Supported Hardwares: [0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
Max Flash Devices: 2
Flash ID 1: 00EC22E8 - 0000 Rev: 6921 Manufacturer: Samsung MSB: 00 SectorSize: 0x020000
Flash ID 2: FFFF0000 - 0000 Rev: 0000 Manufacturer: Unknown MSB: 00 SectorSize: 0x020000
Signature: 00000000000000000000000000000000
Flash Loader: RAP3Gv3_algo_fps8.fg 63 kB
Version: 1.12.5
Supported Hardwares: [0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002]
APE Boot Loader: helen3_2nd.fg 13 kB
Version: 1.35.0
Supported APE Hardwares: [17100700, 17100701, 17100702, 17100703, 17100704, 17100708]
Max Flash Devices: 1
Flash ID 1: 00EC00A1 - 0080 Rev: 0015 Manufacturer: Samsung MSB: 00 SectorSize: 0x020000
Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
APE Flash Loader: h3_sam_nand_xsr.fg 79 kB
Version: 1.49.0
APE Asic ID: 17100708
APE Asic Mode ID: 00
APE Public ID: 59930BDDC1AA26270431C1FC52C20CD9BA699654
APE Hash: 49A97E826B93BA20B7ED0B082475C00500000000
APE ROM ID: 1DFD66132C872FD4
Asic ID: 000000010000022600010006010C192101003000
EM Asic ID: 00000295
EM Asic ID: 00000B21
Public ID: 04F0000456BF0054CF4A8DE3AEB072DDB99CB165
Asic Mode ID: 00
Hash: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecHash: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Erase time: 48,3 sec.
Writing flash...
After MCU Flash Delay: 5000 msec.
Flashing file:
BB5 [BB5 ALGORITHM] UCP File: N73_userarea_4.0839.42.2.1.UY5 10 913 kB
Speed: [650k, 6500k, 6500k, 100k] Baud.
Supported Hardwares: [0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000]
Version: 1.20.2
Version: 1.12.5
Version: 1.35.0
Version: 1.49.0
Asic Mode ID: 00
Converting UCP block to 128k
Erase time: 0,0 sec.
Writing flash...
Flashing file:
BB5 [BB5 ALGORITHM] PPM File: N73_rofx_4.0839.42.2.1_PRD.VY5 16 948 kB
Supported APE Hardwares: [17100700, 17100701, 17100702, 17100708]
Version: 1.20.2
Version: 1.12.5
Version: 1.35.0
Version: 1.49.0
Asic Mode ID: 00
Writing flash...
Total time: 12:36,7 sec.
After Flash Delay: 15000 msec.
Set Defaults Timeout: 250 sec.
Setting defaults (it can take a minunte, or more)...
Set defaults time: 0,4 sec.
Old 07-13-2009, 19:09   #5 (permalink)
sameer918's Avatar
Member: 754208
Thanks Meter: 67
Solved....Thanx a lot guys
n73 not booting (blank display) richardjf77 Nokia Hardware & Hardware Repair 4 06-19-2009 03:40
N73 doesn't boot - flashed successfully James_S Universalbox 5 11-21-2008 03:42
Page generated in 0.47442 seconds with 8 queries
