N73 phone start up failed n73 scaning info all ok but coming phone start up failed contact the retailer. http://dc395.4shared.com/img/XBNUyAp.../ATF_HASAN.bmp Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35642502886321-4 Product Code: 0544952 Battery voltage: 4745 mV, current: 106 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356425028863214 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
change power ic,,its hardware problem, becoz of SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed so,,all certs are ok,, post result,,,first shake power ic,if still,,change it |
format user area c: d: may it help you:D |
yes that is hardware problem... |
still same bro................ |
did u chaged power ic,,if yes ,now full flash yr phone,,after do full formate,and do factory setting,,,post here flashing,logs,,self test and info,thx post result |
yes bro already changed power ic.and flashed also see here logs 12:42:53 : AdvanceBox Turbo Flasher Found 12:42:53 : Driver Version : 00020814 12:42:53 : Library Version : 00030118 12:42:53 : Initialize Device.... 12:42:53 : Init TRY : 1 12:42:54 : Box Name : ATF Lightning 12:42:54 : Box Firmware : LogiCore 9.02.10 12:42:54 : Software Version : v7.65 12:42:54 : AdvanceBox SN : A85E3FF2CC730042B66691E4 12:42:54 : BOX Status : ACTIVATED 12:42:54 : INIT : OK 12:42:54 : 12:42:54 : VBATT OFF... 12:42:58 : VBATT ON 12:42:58 : Setting VBATT Done!... 12:42:58 : 12:42:58 : 12:42:58 : ///////// /// /// /////// /////// ///////// 12:42:58 : /// /// /// /// // /// /// /// /// 12:42:58 : /// /// /// /////// /////// /// /// 12:42:58 : /// /// /// /// /// /// /// /// /// 12:42:58 : /// ///// /// /// /////// ////// 12:42:58 : 12:42:58 : ======================================= 12:42:58 : /// /// /// ///////// /////// ////// 12:42:58 : ///// /// /// /// /// // /// /// 12:42:58 : /// ///// /// /// /////// /// /// 12:42:58 : /// //// /// /// /// /// /// /// 12:42:58 : /// /// /// /// /// /// ////// 12:42:58 : ======================================= 12:42:58 : 12:43:58 : ATF Software Version v7.65 12:43:58 : ATF Lightning FBUS Flash Started... 12:43:58 : 12:43:58 : Number of Image Files: 3 12:43:58 : 12:43:58 : Processing Image File : 12:43:58 : F:\PRODUCT\RM-133\N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx 12:43:59 : CMT Type : BB5 12:43:59 : CMT Algorithm : BB5 ALGORITHM 12:43:59 : Secondary Sending Speed : 51000Hz 12:43:59 : Algorithm Sending Speed : 6500000Hz 12:43:59 : Program Sending Speed : 6500000Hz 12:43:59 : Message Reading Speed : 98000Hz 12:43:59 : APE PHONE Type : BB5 12:43:59 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG 12:43:59 : APE Supported Hardwares : 12:43:59 : > 17100708 12:43:59 : Number of Blocks : 1732 12:43:59 : Entry Point: 0x1B5C6 12:43:59 : Page Format : -1 12:43:59 : MAX PAGE : 0x00008000 12:43:59 : Changing MODE : FLASH 12:43:59 : 12:43:59 : AdvanceBox SendBootCodeEx 12:43:59 : InitialiseBootstrap_DCT5 DIR 12:43:59 : BootFlashMode_DCT5 12:43:59 : 12:43:59 : ************************************************** **** 12:43:59 : TIME STARTS HERE 12:43:59 : ************************************************** **** 12:43:59 : 12:43:59 : BootFlashModeDCT5Ex Succeeded First Time 12:43:59 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 12:43:59 : Number of Sub Blocks 12 (0x0C) 12:43:59 : 1 SYSTEM_ASIC_ID 01 12:43:59 : Block Length : 5 (05) 12:43:59 : BB ASIC Index : 1 (01) APE 12:43:59 : ID DWORD 0 : 17100708 12:43:59 : 2 ASIC_MODE_ID 13 12:43:59 : Block Length : 2 (02) 12:43:59 : BB ASIC Index : 1 (01) APE 12:43:59 : Mode Id : 00 12:43:59 : 3 PUBLIC_ID 12 12:43:59 : Block Length : 21 (15) 12:43:59 : BB ASIC Index : 1 (01) APE 12:43:59 : ID DWORD 0 : 593B0EFB 12:43:59 : ID DWORD 1 : 596862E1 12:43:59 : ID DWORD 2 : 5410EE5A 12:43:59 : ID DWORD 3 : 23234723 12:43:59 : ID DWORD 4 : BAEDEE04 12:43:59 : 4 ROOT_KEY_HASH 14 12:43:59 : Block Length : 21 (15) 12:43:59 : BB ASIC Index : 1 (01) APE 12:43:59 : Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00 12:43:59 : 5 ROM_ID 15 12:43:59 : Block Length : 9 (09) 12:43:59 : BB ASIC Index : 1 (01) APE 12:43:59 : CRC 0 : 1DFD6613 12:43:59 : CRC 1 : 2C872FD4 12:43:59 : 6 SYSTEM_ASIC_ID 01 12:43:59 : Block Length : 21 (15) 12:43:59 : BB ASIC Index : 0 (00) CMT 12:43:59 : ID DWORD 0 : 00000001 12:43:59 : ID DWORD 1 : 00000226 12:43:59 : ID DWORD 2 : 00010006 12:43:59 : ID DWORD 3 : 010C1921 12:43:59 : ID DWORD 4 : 01003000 12:43:59 : 7 ROM_ID 15 12:43:59 : Block Length : 5 (05) 12:43:59 : BB ASIC Index : 0 (00) CMT 12:43:59 : ID DWORD 0 : 00000295 12:43:59 : 8 ROM_ID 15 12:43:59 : Block Length : 5 (05) 12:43:59 : BB ASIC Index : 0 (00) CMT 12:43:59 : ID DWORD 0 : 00000B22 12:43:59 : 9 PUBLIC_ID 12 12:43:59 : Block Length : 21 (15) 12:43:59 : BB ASIC Index : 0 (00) CMT 12:43:59 : ID DWORD 0 : 1E300009 12:43:59 : ID DWORD 1 : 805B7C56 12:43:59 : ID DWORD 2 : D6850CC6 12:43:59 : ID DWORD 3 : B33F3108 12:44:00 : ID DWORD 4 : 008CAAC7 12:44:00 : 10 ASIC_MODE_ID 13 12:44:00 : Block Length : 2 (02) 12:44:00 : BB ASIC Index : 0 (00) CMT 12:44:00 : Mode Id : 00 12:44:00 : 11 ROOT_KEY_HASH 14 12:44:00 : Block Length : 17 (11) 12:44:00 : BB ASIC Index : 0 (00) CMT 12:44:00 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 12:44:00 : 12 ROM_ID 15 12:44:00 : Block Length : 9 (09) 12:44:00 : BB ASIC Index : 0 (00) CMT 12:44:00 : CRC 0 : 273F6D55 12:44:00 : CRC 1 : DFAAF68F 12:44:00 : Checksum 11 12:44:00 : 12:44:00 : 12:44:00 : ============================================ 12:44:00 : NOR Chip Detected... Nitro Flashing Disabled 12:44:00 : ============================================ 12:44:00 : 12:44:00 : SearchForBootstrap_DCT5.. 12:44:00 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_2nd.fg 12:44:00 : Boot File - Version 01.030.00 12:44:00 : Boot File - Revision 0x0000 (0) 12:44:00 : eBB5ProtocolType == Original 12:44:00 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:44:00 : Secondary Loader Sent... 12:44:00 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 12:44:00 : MCU_CONFIGURATION_RESPONSE_BB5: 12:44:00 : MessageID : 03 12:44:00 : SubBlocks : 03 12:44:00 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:44:00 : Block Length : 0B 12:44:00 : BB ASIC Index : CMT 00 12:44:00 : Device Type : NOR 00 12:44:00 : Device Index : 00 12:44:00 : Manufacturer Code : 00EC -> 12:44:00 : Device ID : 22E8 -> K5G2829ATC 12:44:00 : Extended/Fixed ID : 0000 12:44:00 : Revision ID : 6921 12:44:00 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 12:44:00 : Block Length : 13 12:44:00 : BB ASIC Index : CMT 00 12:44:00 : Device Type : NOR 00 12:44:00 : Device Index : 00 12:44:00 : Device Contents : 00000000000000000000 12:44:00 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:44:00 : Block Length : 0B 12:44:00 : BB ASIC Index : CMT 00 12:44:00 : Device Type : MMC 04 12:44:00 : Device Index : 00 12:44:00 : Manufacturer Code : FFFF -> Flash 12:44:00 : Device ID : 0000 -> BAD FLASH TYPE 12:44:00 : Extended/Fixed ID : 0000 12:44:00 : Revision ID : 0000 12:44:00 : Checksum : 20 12:44:00 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:44:00 : FLS1SendAlgoCodeEx.. 12:44:00 : SendAlgoCode_DCT5.. 12:44:00 : SearchForAlgorithm_DCT5.. 12:44:00 : Looking for ALL Devices... 12:44:00 : Searching Algorithm Files NOR (00) ManID :00EC DevID :22E8 ExtID :0000 RevID :6921 12:44:00 : Flash Descriptor 12:44:00 : Manufacturer Code : 00EC 12:44:00 : Device ID : 22E8 12:44:00 : Extended/Fixed ID : 0000 12:44:00 : Revision ID : 0000 12:44:00 : Size : 01000000 (16 MB) 12:44:00 : VPP Info : 0009 12:44:00 : Erase10s : 28 12:44:00 : Block1s : 32 12:44:00 : BErase1s : 02 12:44:00 : Reserved0 : 00 12:44:00 : Reserved1 : 00 12:44:00 : Reserved2 : 00 12:44:00 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK 12:44:00 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg 12:44:00 : Algorithm File - Version 01.040.00 12:44:00 : Algorithm File - Revision 0x0000 (0) 12:44:00 : eBB5ProtocolType == Original 12:44:00 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 12:44:00 : TransmissionTypeRequest_DCT5... 12:44:00 : SuggestedType : 01 16BIT 12:44:00 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 12:44:00 : ReturnedType : 01 16BIT 12:44:00 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:44:00 : 12:44:00 : Uploading ALGO File... 12:44:00 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 12:44:00 : Pabub KEY Request 12:44:01 : PhoneInfoRequest_BB5 (Asic Index 00 ) 12:44:01 : PHONE_INFO_RESPONSE_BB5 12:44:01 : PAPUB_KEYS_HASH_RESP_BB5 2A 12:44:01 : BB Asic Index : 00 12:44:01 : CMT PAPUBKEYS HASH: 12:44:01 : 5E8D0D504A0902E261268C14FCD8A2C9093523BC 12:44:01 : Searching for APE Boot File.. 12:44:01 : SearchForBootstrap_DCT5... 12:44:01 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\helen3_2nd.fg 12:44:01 : Boot File - Version 12:44:01 : Boot File - Revision 0x (2) 12:44:01 : eBB5ProtocolType == New 12:44:01 : TransmissionTypeRequest_DCT5.. 12:44:01 : SuggestedType : 04 DDR & 2TX 12:44:01 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 12:44:01 : ReturnedType : 04 DDR & 2TX 12:44:01 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:44:01 : 12:44:01 : SendAPECodeRequest_DCT5.. 12:44:01 : SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. 12:44:01 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 12:44:01 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 12:44:01 : MCU_CONFIGURATION_RESPONSE_BB5: 12:44:01 : MessageID : 02 12:44:01 : SubBlocks : 02 12:44:01 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:44:01 : Block Length : 0B 12:44:01 : BB ASIC Index : APE 01 12:44:01 : Device Type : NAND 01 12:44:01 : Device Index : 00 12:44:01 : Manufacturer Code : 00EC -> 12:44:01 : Device ID : 00A1 -> K5E1G12ACM 12:44:01 : Extended/Fixed ID : 0080 12:44:01 : Revision ID : 0015 12:44:01 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 12:44:01 : Block Length : 13 12:44:01 : BB ASIC Index : APE 01 12:44:01 : Device Type : NAND 01 12:44:01 : Device Index : 00 12:44:01 : Device Contents : FFFFFFFFFFFFFFFFFFFF 12:44:01 : Checksum : A8 12:44:01 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:44:01 : Searching for APE Algorithm File.. 12:44:01 : SearchForAlgorithm_DCT5 12:44:01 : Flash Descriptor 12:44:01 : Manufacturer Code : 00EC 12:44:01 : Device ID : 00A1 12:44:01 : Extended/Fixed ID : 0000 12:44:01 : Revision ID : 0000 12:44:01 : Size : 08000000 (128 MB) 12:44:01 : VPP Info : 0015 12:44:01 : Erase10s : 0F 12:44:01 : Block1s : 32 12:44:01 : BErase1s : 02 12:44:01 : Reserved0 : 00 12:44:01 : Reserved1 : 00 12:44:01 : Reserved2 : 00 12:44:01 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK 12:44:01 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\h3_sam_nand_xsr.fg 12:44:01 : Algorithm File - Version 01.047.00 12:44:01 : Algorithm File - Revision 0x0000 (0) 12:44:01 : eBB5ProtocolType == Original 12:44:01 : TransmissionTypeRequest_DCT5.. 12:44:01 : SuggestedType : 04 DDR & 2TX 12:44:01 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 12:44:01 : ReturnedType : 04 DDR & 2TX 12:44:01 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:44:01 : 12:44:01 : SendAPECodeRequest_DCT5.. 12:44:01 : APE Algorithm Sent 12:44:01 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 12:44:01 : Pabub KEY Request 12:44:01 : PhoneInfoRequest_BB5 (Asic Index 01 ) 12:44:01 : PHONE_INFO_RESPONSE_BB5 12:44:01 : PAPUB_KEYS_HASH_RESP_BB5 2A 12:44:01 : BB Asic Index : 01 12:44:01 : APE PAPUBKEYS HASH: 12:44:01 : 5E8D0D504A0902E261268C14FCD8A2C9093523BC 12:44:01 : ( CMT and APE PAPUBKEYS HASH are Identical ) 12:44:01 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) 12:44:01 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) 12:44:01 : No RESTORE CERTIFICATE FOUND IN IMAGE FILE 12:44:01 : ProcessPartitionInfo_DCT5... 12:44:01 : Partition Info 12:44:01 : Partition Blocks : 1 12:44:01 : 1 PARTITION_INFO_BB5 12:44:01 : BB ASIC Index : 0x01 APE 12:44:01 : Device Type : 0x01 NAND 12:44:01 : Device Index : 0x00 12:44:01 : Partition Version : 00010000 12:44:01 : Spare : FFFFFFFF 12:44:01 : Num Partitions : 00000003 12:44:01 : Partition 1 12:44:01 : ID : 00000003 COPIEDOS 12:44:01 : Attribute : 00000002 RO 12:44:01 : Start Address : 00420000 12:44:01 : Size : 00E80000 12:44:01 : Partition 2 12:44:01 : ID : 00000004 DEMANDONOS 12:44:01 : Attribute : 00000002 RO 12:44:01 : Start Address : 012A0000 12:44:01 : Size : 03B80000 12:44:01 : Partition 3 12:44:01 : ID : 00000008 FILESYSTEM 12:44:02 : Attribute : 00000001 RW 12:44:02 : Start Address : 04E20000 12:44:02 : Size : 02E80000 12:44:02 : PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000 00020042000000E800000000000400000002012A000003B800 00000000080000000104E2000002E800009A 12:44:02 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) 12:44:02 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) 12:44:02 : VPP Enabled by Software 12:44:02 : Using Internal VPP 12:44:02 : StartErase_DCT5... 12:44:02 : BlockLength : 0x4B (75) 12:44:02 : ERASE Blocks : 0x02 (2) 12:44:02 : 0 ERASE_AREA_BB5 0x12 12:44:02 : Block Length : 0x23 (35) 12:44:02 : BB ASIC Index : 0x00 CMT 12:44:02 : Device Type : 0x00 NOR 12:44:02 : Device Index : 0x00 12:44:02 : 0 : 00080000-0073194D 12:44:02 : 1 : 00000000-0005FFFF 12:44:02 : 2 : 001E0000-001FFFFF 12:44:02 : 3 : 00880000-00FEFFFF 12:44:02 : 1 ERASE_AREA_BB5 0x12 12:44:02 : Block Length : 0x23 (35) 12:44:02 : BB ASIC Index : 0x01 APE 12:44:02 : Device Type : 0x01 NAND 12:44:02 : Device Index : 0x00 12:44:02 : 0 : 00000000-0007FFFF 12:44:02 : 1 : 00080000-000FFFFF 12:44:02 : 2 : 00100000-0025FFFF 12:44:02 : 3 : 003C0000-04E1FFFF 12:44:02 : 12:44:02 : Erase_SendEraseBlock_BB5_NOR 12:44:02 : Task in Progress... Please Wait... 12:44:50 : Status_BB5 STATUS_REQUEST_BB5.. 12:44:50 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:44:50 : Block Length : 01 12:44:50 : BB ASIC Index : 00 12:44:50 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:44:50 : Block Length : 0F 12:44:50 : BB ASIC Index : 01 12:44:50 : Device Type : 03 12:44:50 : Device Type : 00 12:44:50 : Num Bad Blocks : 00504A09 12:44:50 : Additional Bad : 00E26126 12:44:50 : Correctable ECC : 0014FCD8 12:44:50 : 12:44:50 : Erase_SendEraseBlock_BB5_NAND 12:44:50 : Task in Progress... Please Wait... 12:44:52 : Status_BB5 STATUS_REQUEST_BB5.. 12:44:52 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:44:52 : Block Length : 01 12:44:52 : BB ASIC Index : 00 12:44:52 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:44:52 : Block Length : 0F 12:44:52 : BB ASIC Index : 01 12:44:52 : Device Type : 03 12:44:52 : Device Type : 00 12:44:52 : Num Bad Blocks : 00504A09 12:44:52 : Additional Bad : 00E26126 12:44:52 : Correctable ECC : 0014FCD8 12:44:52 : 12:44:52 : Successfully erased.. 12:44:52 : Time Taken to Erase : 00:00:50 12:44:52 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 12:44:52 : ReturnedType : 04 DDR & 2TX 12:44:52 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:44:52 : 12:44:52 : Flashing Speed: 15.00 Mhz 12:44:52 : Processing : N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx 12:44:52 : Total blocks to write : 1732 12:44:52 : ================================================ 12:44:52 : FBUS Cable RX2 PIN Diagnostics 12:44:52 : ================================================ 12:44:52 : Status_BB5 STATUS_REQUEST_BB5.. 12:44:52 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:44:52 : Block Length : 01 12:44:52 : BB ASIC Index : 00 12:44:52 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:44:52 : Block Length : 0F 12:44:52 : BB ASIC Index : 01 12:44:52 : Device Type : 03 12:44:52 : Device Type : 00 12:44:52 : Num Bad Blocks : 00504A09 12:44:52 : Additional Bad : 00E26126 12:44:52 : Correctable ECC : 0014FCD8 12:44:52 : ================================================ 12:44:52 : INFO: RX2 PIN is OK 12:44:52 : ================================================ 12:44:52 : >> CMT Rootkey Hash CERT : NOLO 12:44:52 : >> CMT Rootkey Hash CERT : KEYS 12:44:52 : >> CMT Rootkey Hash CERT : PRIMAPP 12:44:52 : >> CMT Rootkey Hash CERT : PASUBTOC 12:44:52 : >> CMT Rootkey Hash CERT : PAPUBKEYS 12:44:52 : >> CMT Rootkey Hash CERT : UPDAPP 12:44:54 : >> CMT Rootkey Hash CERT : ADL 12:44:54 : >> CMT Rootkey Hash CERT : DSP0 12:45:04 : >> CMT Rootkey Hash CERT : MCUSW 12:45:31 : >> APE Rootkey Hash CERT : KEYS 12:45:31 : >> APE Rootkey Hash CERT : X-LOADER 12:45:31 : >> APE Rootkey Hash CERT : PRIMAPP 12:45:31 : >> APE Rootkey Hash CERT : SOS+LOADER 12:45:32 : >> APE Rootkey Hash CERT : SOS*UPDAPP 12:45:33 : >> APE Rootkey Hash CERT : SOS+UZIP 12:45:33 : >> APE Rootkey Hash CERT : PAPUBKEYS 12:45:33 : >> APE Rootkey Hash CERT : PASUBTOC 12:45:33 : >> APE Rootkey Hash CERT : ADL 12:45:33 : >> APE Rootkey Hash CERT : SOS+XZIP 12:45:33 : >> APE Rootkey Hash CERT : SOS*CORE 12:45:52 : >> APE Rootkey Hash CERT : SOS+ROFS 12:46:41 : >> APE Rootkey Hash CERT : SOS+ROFX 12:46:41 : ContinueFlash_DCT5 Complete 12:46:41 : Status_BB5 STATUS_REQUEST_BB5.. 12:46:41 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:46:41 : Block Length : 01 12:46:41 : BB ASIC Index : 00 12:46:41 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:46:41 : Block Length : 0F 12:46:41 : BB ASIC Index : 01 12:46:41 : Device Type : 03 12:46:41 : Device Type : 00 12:46:41 : Num Bad Blocks : 00504A09 12:46:41 : Additional Bad : 00E26126 12:46:41 : Correctable ECC : 0014FCD8 12:46:41 : Status_BB5 STATUS_REQUEST_BB5.. 12:46:41 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:46:41 : Block Length : 01 12:46:41 : BB ASIC Index : 00 12:46:41 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:46:41 : Block Length : 0F 12:46:41 : BB ASIC Index : 01 12:46:41 : Device Type : 03 12:46:41 : Device Type : 00 12:46:41 : Num Bad Blocks : 00504A09 12:46:41 : Additional Bad : 00E26126 12:46:41 : Correctable ECC : 0014FCD8 12:46:41 : Continue Flash Complete : : No Error - 0 (0x00) 12:46:41 : Time Taken to Flash : 00:01:49 12:46:41 : 12:46:41 : Processing Image File : 12:46:41 : F:\PRODUCT\RM-133\N73_rofx_4.0850.43.0.1_PRD.V12 12:46:41 : CMT Type : BB5 12:46:41 : CMT Algorithm : BB5 ALGORITHM 12:46:41 : Secondary Sending Speed : 650000Hz 12:46:41 : Algorithm Sending Speed : 6500000Hz 12:46:41 : Program Sending Speed : 6500000Hz 12:46:41 : Message Reading Speed : 100000Hz 12:46:41 : APE PHONE Type : BB5 12:46:41 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG 12:46:41 : APE Supported Hardwares : 12:46:41 : > 17100700 12:46:41 : > 17100701 12:46:41 : > 17100702 12:46:41 : > 17100708 12:46:41 : Number of Blocks : 1698 12:46:41 : Entry Point: 0x0172 12:46:41 : Page Format : -1 12:46:41 : MAX PAGE : 0x00002000 12:46:42 : ProcessPartitionInfo_DCT5... 12:46:42 : Partition Info 12:46:42 : Partition Blocks : 1 12:46:42 : 1 PARTITION_INFO_BB5 12:46:42 : BB ASIC Index : 0x01 APE 12:46:42 : Device Type : 0x01 NAND 12:46:42 : Device Index : 0x00 12:46:42 : Partition Version : 00010000 12:46:42 : Spare : FFFFFFFF 12:46:42 : Num Partitions : 00000003 12:46:42 : Partition 1 12:46:42 : ID : 00000003 COPIEDOS 12:46:42 : Attribute : 00000002 RO 12:46:42 : Start Address : 00420000 12:46:42 : Size : 00E80000 12:46:42 : Partition 2 12:46:42 : ID : 00000004 DEMANDONOS 12:46:42 : Attribute : 00000002 RO 12:46:42 : Start Address : 012A0000 12:46:42 : Size : 03B80000 12:46:42 : Partition 3 12:46:42 : ID : 00000008 FILESYSTEM 12:46:42 : Attribute : 00000001 RW 12:46:42 : Start Address : 04E20000 12:46:42 : Size : 02E80000 12:46:42 : PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000 00020042000000E800000000000400000002012A000003B800 00000000080000000104E2000002E800009A 12:46:42 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) 12:46:42 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) 12:46:42 : VPP Enabled by Software 12:46:42 : Using Internal VPP 12:46:42 : StartErase_DCT5... 12:46:42 : BlockLength : 0x0E (14) 12:46:42 : ERASE Blocks : 0x01 (1) 12:46:42 : 0 ERASE_AREA_BB5 0x12 12:46:42 : Block Length : 0x0B (11) 12:46:42 : BB ASIC Index : 0x01 APE 12:46:42 : Device Type : 0x01 NAND 12:46:42 : Device Index : 0x00 12:46:42 : 0 : 03920000-04E1FFFF 12:46:42 : 12:46:42 : Erase_SendEraseBlock_BB5_NAND 12:46:42 : Task in Progress... Please Wait... 12:46:43 : Status_BB5 STATUS_REQUEST_BB5.. 12:46:43 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:46:43 : Block Length : 01 12:46:43 : BB ASIC Index : 00 12:46:43 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:46:43 : Block Length : 0F 12:46:43 : BB ASIC Index : 01 12:46:43 : Device Type : 03 12:46:43 : Device Type : 00 12:46:43 : Num Bad Blocks : 00504A09 12:46:43 : Additional Bad : 00E26126 12:46:43 : Correctable ECC : 0014FCD8 12:46:43 : 12:46:43 : Successfully erased.. 12:46:43 : Time Taken to Erase : 00:00:00 12:46:43 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 12:46:43 : ReturnedType : 04 DDR & 2TX 12:46:43 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:46:43 : 12:46:43 : Flashing Speed: 15.00 Mhz 12:46:43 : Processing : N73_rofx_4.0850.43.0.1_PRD.V12 12:46:43 : Total blocks to write : 1698 12:46:43 : >> APE Rootkey Hash CERT : SOS+ROFX 12:47:36 : ContinueFlash_DCT5 Complete 12:47:36 : Status_BB5 STATUS_REQUEST_BB5.. 12:47:36 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:47:36 : Block Length : 01 12:47:36 : BB ASIC Index : 00 12:47:36 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:47:36 : Block Length : 0F 12:47:36 : BB ASIC Index : 01 12:47:36 : Device Type : 03 12:47:36 : Device Type : 00 12:47:36 : Num Bad Blocks : 00504A09 12:47:36 : Additional Bad : 00E26126 12:47:36 : Correctable ECC : 0014FCD8 12:47:36 : Continue Flash Complete : : No Error - 0 (0x00) 12:47:36 : Time Taken to Flash : 00:00:53 12:47:36 : 12:47:36 : Processing Image File : 12:47:36 : F:\PRODUCT\RM-133\N73_userarea_4.0850.43.0.1.U01 12:47:36 : CMT Type : BB5 12:47:36 : CMT Algorithm : BB5 ALGORITHM 12:47:36 : Secondary Sending Speed : 650000Hz 12:47:36 : Algorithm Sending Speed : 6500000Hz 12:47:36 : Program Sending Speed : 6500000Hz 12:47:36 : Message Reading Speed : 100000Hz 12:47:36 : APE PHONE Type : BB5 12:47:36 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG 12:47:36 : APE Supported Hardwares : 12:47:36 : > 17100708 12:47:36 : Number of Blocks : 164 12:47:36 : Entry Point: 0x011B 12:47:36 : Page Format : -1 12:47:36 : MAX PAGE : 0x00008000 12:47:36 : NO PARTITION DATA FOR THIS IMAGE... 12:47:36 : VPP Enabled by Software 12:47:36 : Using Internal VPP 12:47:37 : StartErase_DCT5... 12:47:37 : BlockLength : 0x0E (14) 12:47:37 : ERASE Blocks : 0x01 (1) 12:47:37 : 0 ERASE_AREA_BB5 0x12 12:47:37 : Block Length : 0x0B (11) 12:47:37 : BB ASIC Index : 0x01 APE 12:47:37 : Device Type : 0x01 NAND 12:47:37 : Device Index : 0x00 12:47:37 : 0 : 04E20000-07C9FFFF 12:47:37 : 12:47:37 : Erase_SendEraseBlock_BB5_NAND 12:47:37 : Task in Progress... Please Wait... 12:47:38 : Status_BB5 STATUS_REQUEST_BB5.. 12:47:38 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:47:38 : Block Length : 01 12:47:38 : BB ASIC Index : 00 12:47:38 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:47:38 : Block Length : 0F 12:47:38 : BB ASIC Index : 01 12:47:38 : Device Type : 03 12:47:38 : Device Type : 00 12:47:38 : Num Bad Blocks : 00504A09 12:47:38 : Additional Bad : 00E26126 12:47:38 : Correctable ECC : 0014FCD8 12:47:38 : 12:47:38 : Successfully erased.. 12:47:38 : Time Taken to Erase : 00:00:00 12:47:38 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 12:47:38 : ReturnedType : 04 DDR & 2TX 12:47:38 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 12:47:38 : 12:47:38 : Flashing Speed: 15.00 Mhz 12:47:38 : Processing : N73_userarea_4.0850.43.0.1.U01 12:47:38 : Total blocks to write : 164 12:47:48 : ContinueFlash_DCT5 Complete 12:47:48 : Status_BB5 STATUS_REQUEST_BB5.. 12:47:48 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 12:47:48 : Block Length : 01 12:47:48 : BB ASIC Index : 00 12:47:48 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:47:48 : Block Length : 0F 12:47:48 : BB ASIC Index : 01 12:47:48 : Device Type : 03 12:47:48 : Device Type : 00 12:47:48 : Num Bad Blocks : 00504A09 12:47:48 : Additional Bad : 00E26126 12:47:48 : Correctable ECC : 0014FCD8 12:47:48 : Continue Flash Complete : : No Error - 0 (0x00) 12:47:48 : Time Taken to Flash : 00:00:10 12:47:48 : 12:47:48 : Total Flash Write Time (Flashing Only) : 00:02:53 12:47:48 : Total Flashing Time (Booting + Erase + Flashing) : 00:03:46 12:47:48 : 12:47:48 : FlashInfo.RestartMode : 2 12:47:53 : Waiting for Phone to Go Online... 12:47:54 : Elapsed Time: 1s 12:47:55 : Elapsed Time: 2s 12:47:56 : Elapsed Time: 3s 12:47:57 : Elapsed Time: 4s 12:47:58 : Elapsed Time: 5s 12:47:59 : Elapsed Time: 6s 12:48:00 : Elapsed Time: 7s 12:48:01 : Elapsed Time: 8s 12:48:02 : Elapsed Time: 9s 12:48:03 : Elapsed Time: 10s 12:48:03 : 12:48:03 : MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. 12:48:03 : IMEI Plain : 356425028863214 12:48:03 : IMEI Spare : A356425028863210 12:48:03 : IMEI SV : 33564250288632181F 12:48:03 : Phone Model: Nokia N73 12:48:03 : Product Serial Number: CDG024132 12:48:03 : Product Code : 0544952 12:48:03 : Module Code : 0202855 12:48:03 : Basic Production Code: 0537044 12:48:05 : PPM Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia. 12:48:05 : HW Version : 7201 12:48:05 : RFIC Version : 17211721 12:48:05 : DSP Version : scarfe_mc.05wk46v50p2 12:48:05 : AHNE Version : 30 12:48:05 : Retu Version : 15 12:48:06 : Tahvo Version : 22 12:48:06 : 12:48:06 : ******** Reading SimLock ******** 12:48:06 : CONFIG KEY: 0000000000000000 12:48:06 : PROVIDER KEY: 2440700000000000 12:48:06 : Provider : AT&T;U.S.A. (3650) 12:48:06 : Counters : 0/3 , 0/10 12:48:06 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 12:48:06 : SP Lock Status : Not Locke 12:48:24 : FACTORY SET TO : Full Factory Set 12:48:25 : OK 12:48:25 : FACTORY SET TO : User Data 12:48:25 : OK 12:48:25 : FACTORY SET TO : Leave Factory 12:48:25 : OK 12:48:25 : FACTORY SET TO : Service Center 12:48:26 : OK 12:48:26 : FACTORY SET TO : Software Upgrade 12:48:26 : OK 12:48:26 : FACTORY SET TO : Production Tune 12:48:26 : OK 12:48:36 : 12:48:36 : Changing Phone Mode... (Wait for 5 seconds) 12:48:36 : 12:48:41 : Successfully set to : Normal Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. Imei plain: 35642502886321-4 Product Code: 0544952 Battery voltage: 4853 mV, current: 111 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356425028863214 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 4.453 s |
note; mobile not opening normally when i put charger and push power button then coming phone startup........................ |
thats mean 100% hardware problem try to shake doubble ic |
Never Never apply any hardware change in phone for contact retailer only write pm without 308 and unlock if not success again change an other source pm if not then write again pm file from other source Hopr you will be success like me thanks to you all by gsm zaman |
