Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 07-03-2011, 17:43   #1 (permalink)
ripon12's Avatar
Member: 1507803
Sonork: 100.1605433
Thanks Meter: 109
N73 phone start up failed
n73 scaning info all ok but coming phone start up failed contact the retailer.
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
Imei plain: 35642502886321-4
Product Code: 0544952
Battery voltage: 4745 mV, current: 106 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356425028863214
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 07-03-2011, 18:33   #2 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 727
change power ic,,its hardware problem,
becoz of
SIMLOCK_TEST passed
so,,all certs are ok,,
post result,,,first shake power ic,if still,,change it
Old 07-03-2011, 19:05   #3 (permalink)
Member: 296577
Thanks Meter: 126
format user area
c:
d:
may it help you
Old 07-03-2011, 20:14   #4 (permalink)
Member: 281174
Thanks Meter: 5
yes that is hardware problem...
Old 07-03-2011, 20:26   #5 (permalink)
ripon12's Avatar
Member: 1507803
Sonork: 100.1605433
Thanks Meter: 109
still same bro................
Old 07-03-2011, 20:27   #6 (permalink)
ripon12's Avatar
Member: 1507803
Sonork: 100.1605433
Thanks Meter: 109
becoz of
SIMLOCK_TEST passed
Old 07-03-2011, 21:40   #7 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 727
did u chaged power ic,,if yes ,now full flash yr phone,,after do full formate,and do
factory setting,,,post here flashing,logs,,self test and info,thx post result
Old 07-04-2011, 12:00   #8 (permalink)
ripon12's Avatar
Member: 1507803
Sonork: 100.1605433
Thanks Meter: 109
yes bro already changed power ic.and flashed also see here logs
12:42:53 : AdvanceBox Turbo Flasher Found
12:42:53 : Driver Version : 00020814
12:42:53 : Library Version : 00030118
12:42:53 : Initialize Device....
12:42:53 : Init TRY : 1
12:42:54 : Box Name : ATF Lightning
12:42:54 : Box Firmware : LogiCore 9.02.10
12:42:54 : Software Version : v7.65
12:42:54 : AdvanceBox SN : A85E3FF2CC730042B66691E4
12:42:54 : BOX Status : ACTIVATED
12:42:54 : INIT : OK
12:42:54 :
12:42:54 : VBATT OFF...
12:42:58 : VBATT ON
12:42:58 : Setting VBATT Done!...
12:42:58 :
12:42:58 :
12:42:58 : ///////// /// /// /////// /////// /////////
12:42:58 : /// /// /// /// // /// /// /// ///
12:42:58 : /// /// /// /////// /////// /// ///
12:42:58 : /// /// /// /// /// /// /// /// ///
12:42:58 : /// ///// /// /// /////// //////
12:42:58 :
12:42:58 : =======================================
12:42:58 : /// /// /// ///////// /////// //////
12:42:58 : ///// /// /// /// /// // /// ///
12:42:58 : /// ///// /// /// /////// /// ///
12:42:58 : /// //// /// /// /// /// /// ///
12:42:58 : /// /// /// /// /// /// //////
12:42:58 :
12:43:58 : ATF Software Version v7.65
12:43:58 : ATF Lightning FBUS Flash Started...
12:43:58 :
12:43:58 : Number of Image Files: 3
12:43:58 :
12:43:58 : Processing Image File :
12:43:58 : F:\PRODUCT\RM-133\N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx
12:43:59 : CMT Type : BB5
12:43:59 : CMT Algorithm : BB5 ALGORITHM
12:43:59 : Secondary Sending Speed : 51000Hz
12:43:59 : Algorithm Sending Speed : 6500000Hz
12:43:59 : Program Sending Speed : 6500000Hz
12:43:59 : Message Reading Speed : 98000Hz
12:43:59 : APE PHONE Type : BB5
12:43:59 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG
12:43:59 : APE Supported Hardwares :
12:43:59 : > 17100708
12:43:59 : Number of Blocks : 1732
12:43:59 : Entry Point: 0x1B5C6
12:43:59 : Page Format : -1
12:43:59 : MAX PAGE : 0x00008000
12:43:59 : Changing MODE : FLASH
12:43:59 :
12:43:59 : AdvanceBox SendBootCodeEx
12:43:59 : InitialiseBootstrap_DCT5 DIR
12:43:59 : BootFlashMode_DCT5
12:43:59 :
12:43:59 : ************************************************** ****
12:43:59 : TIME STARTS HERE
12:43:59 :
12:43:59 : BootFlashModeDCT5Ex Succeeded First Time
12:43:59 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
12:43:59 : Number of Sub Blocks 12 (0x0C)
12:43:59 : 1 SYSTEM_ASIC_ID 01
12:43:59 : Block Length : 5 (05)
12:43:59 : BB ASIC Index : 1 (01) APE
12:43:59 : ID DWORD 0 : 17100708
12:43:59 : 2 ASIC_MODE_ID 13
12:43:59 : Block Length : 2 (02)
12:43:59 : Mode Id : 00
12:43:59 : 3 PUBLIC_ID 12
12:43:59 : Block Length : 21 (15)
12:43:59 : ID DWORD 0 : 593B0EFB
12:43:59 : ID DWORD 1 : 596862E1
12:43:59 : ID DWORD 2 : 5410EE5A
12:43:59 : ID DWORD 3 : 23234723
12:43:59 : ID DWORD 4 : BAEDEE04
12:43:59 : 4 ROOT_KEY_HASH 14
12:43:59 : Hash : 49 A9 7E 82 6B 93 BA 20 B7 ED 0B 08 24 75 C0 05 00 00 00 00
12:43:59 : 5 ROM_ID 15
12:43:59 : Block Length : 9 (09)
12:43:59 : CRC 0 : 1DFD6613
12:43:59 : CRC 1 : 2C872FD4
12:43:59 : 6 SYSTEM_ASIC_ID 01
12:43:59 : BB ASIC Index : 0 (00) CMT
12:43:59 : ID DWORD 0 : 00000001
12:43:59 : ID DWORD 1 : 00000226
12:43:59 : ID DWORD 2 : 00010006
12:43:59 : ID DWORD 3 : 010C1921
12:43:59 : ID DWORD 4 : 01003000
12:43:59 : 7 ROM_ID 15
12:43:59 : ID DWORD 0 : 00000295
12:43:59 : 8 ROM_ID 15
12:43:59 : ID DWORD 0 : 00000B22
12:43:59 : 9 PUBLIC_ID 12
12:43:59 : ID DWORD 0 : 1E300009
12:43:59 : ID DWORD 1 : 805B7C56
12:43:59 : ID DWORD 2 : D6850CC6
12:43:59 : ID DWORD 3 : B33F3108
12:44:00 : ID DWORD 4 : 008CAAC7
12:44:00 : 10 ASIC_MODE_ID 13
12:44:00 : Block Length : 2 (02)
12:44:00 : BB ASIC Index : 0 (00) CMT
12:44:00 : Mode Id : 00
12:44:00 : 11 ROOT_KEY_HASH 14
12:44:00 : Block Length : 17 (11)
12:44:00 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
12:44:00 : 12 ROM_ID 15
12:44:00 : Block Length : 9 (09)
12:44:00 : CRC 0 : 273F6D55
12:44:00 : CRC 1 : DFAAF68F
12:44:00 : Checksum 11
12:44:00 :
12:44:00 :
12:44:00 : ============================================
12:44:00 : NOR Chip Detected... Nitro Flashing Disabled
12:44:00 :
12:44:00 : SearchForBootstrap_DCT5..
12:44:00 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_2nd.fg
12:44:00 : Boot File - Version 01.030.00
12:44:00 : Boot File - Revision 0x0000 (0)
12:44:00 : eBB5ProtocolType == Original
12:44:00 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
12:44:00 : Secondary Loader Sent...
12:44:00 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
12:44:00 : MCU_CONFIGURATION_RESPONSE_BB5:
12:44:00 : MessageID : 03
12:44:00 : SubBlocks : 03
12:44:00 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
12:44:00 : Block Length : 0B
12:44:00 : BB ASIC Index : CMT 00
12:44:00 : Device Type : NOR 00
12:44:00 : Device Index : 00
12:44:00 : Manufacturer Code : 00EC ->
12:44:00 : Device ID : 22E8 -> K5G2829ATC
12:44:00 : Extended/Fixed ID : 0000
12:44:00 : Revision ID : 6921
12:44:00 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
12:44:00 : Block Length : 13
12:44:00 : Device Contents : 00000000000000000000
12:44:00 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
12:44:00 : Device Type : MMC 04
12:44:00 : Manufacturer Code : FFFF -> Flash
12:44:00 : Device ID : 0000 -> BAD FLASH TYPE
12:44:00 : Revision ID : 0000
12:44:00 : Checksum : 20
12:44:00 : FLS1SendAlgoCodeEx..
12:44:00 : SendAlgoCode_DCT5..
12:44:00 : SearchForAlgorithm_DCT5..
12:44:00 : Looking for ALL Devices...
12:44:00 : Searching Algorithm Files NOR (00) ManID :00EC DevID :22E8 ExtID :0000 RevID :6921
12:44:00 : Flash Descriptor
12:44:00 : Size : 01000000 (16 MB)
12:44:00 : VPP Info : 0009
12:44:00 : Erase10s : 28
12:44:00 : Block1s : 32
12:44:00 : BErase1s : 02
12:44:00 : Reserved0 : 00
12:44:00 : Reserved1 : 00
12:44:00 : Reserved2 : 00
12:44:00 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
12:44:00 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg
12:44:00 : Algorithm File - Version 01.040.00
12:44:00 : Algorithm File - Revision 0x0000 (0)
12:44:00 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
12:44:00 : TransmissionTypeRequest_DCT5...
12:44:00 : SuggestedType : 01 16BIT
12:44:00 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
12:44:00 : ReturnedType : 01 16BIT
12:44:00 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
12:44:00 :
12:44:00 : Uploading ALGO File...
12:44:00 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
12:44:00 : Pabub KEY Request
12:44:01 : PhoneInfoRequest_BB5 (Asic Index 00 )
12:44:01 : PHONE_INFO_RESPONSE_BB5
12:44:01 : PAPUB_KEYS_HASH_RESP_BB5 2A
12:44:01 : BB Asic Index : 00
12:44:01 : CMT PAPUBKEYS HASH:
12:44:01 : 5E8D0D504A0902E261268C14FCD8A2C9093523BC
12:44:01 : Searching for APE Boot File..
12:44:01 : SearchForBootstrap_DCT5...
12:44:01 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\helen3_2nd.fg
12:44:01 : Boot File - Version
12:44:01 : Boot File - Revision 0x (2)
12:44:01 : eBB5ProtocolType == New
12:44:01 : TransmissionTypeRequest_DCT5..
12:44:01 : SuggestedType : 04 DDR & 2TX
12:44:01 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
12:44:01 : ReturnedType : 04 DDR & 2TX
12:44:01 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
12:44:01 :
12:44:01 : SendAPECodeRequest_DCT5..
12:44:01 : SendAPECodeRequest_DCT5 FLS1_NO_ERROR..
12:44:01 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
12:44:01 : MCU_CONFIGURATION_RESPONSE_BB5:
12:44:01 : MessageID : 02
12:44:01 : SubBlocks : 02
12:44:01 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
12:44:01 : Block Length : 0B
12:44:01 : BB ASIC Index : APE 01
12:44:01 : Device Type : NAND 01
12:44:01 : Device Index : 00
12:44:01 : Manufacturer Code : 00EC ->
12:44:01 : Device ID : 00A1 -> K5E1G12ACM
12:44:01 : Extended/Fixed ID : 0080
12:44:01 : Revision ID : 0015
12:44:01 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
12:44:01 : Block Length : 13
12:44:01 : Device Contents : FFFFFFFFFFFFFFFFFFFF
12:44:01 : Checksum : A8
12:44:01 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
12:44:01 : Searching for APE Algorithm File..
12:44:01 : SearchForAlgorithm_DCT5
12:44:01 : Flash Descriptor
12:44:01 : Extended/Fixed ID : 0000
12:44:01 : Revision ID : 0000
12:44:01 : Size : 08000000 (128 MB)
12:44:01 : VPP Info : 0015
12:44:01 : Erase10s : 0F
12:44:01 : Block1s : 32
12:44:01 : BErase1s : 02
12:44:01 : Reserved0 : 00
12:44:01 : Reserved1 : 00
12:44:01 : Reserved2 : 00
12:44:01 : VPPInfo : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK
12:44:01 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\h3_sam_nand_xsr.fg
12:44:01 : Algorithm File - Version 01.047.00
12:44:01 : Algorithm File - Revision 0x0000 (0)
12:44:01 : eBB5ProtocolType == Original
12:44:01 :
12:44:01 : APE Algorithm Sent
12:44:01 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
12:44:01 : Pabub KEY Request
12:44:01 : PhoneInfoRequest_BB5 (Asic Index 01 )
12:44:01 : BB Asic Index : 01
12:44:01 : APE PAPUBKEYS HASH:
12:44:01 : ( CMT and APE PAPUBKEYS HASH are Identical )
12:44:01 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
12:44:01 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
12:44:01 : No RESTORE CERTIFICATE FOUND IN IMAGE FILE
12:44:01 : ProcessPartitionInfo_DCT5...
12:44:01 : Partition Info
12:44:01 : Partition Blocks : 1
12:44:01 : 1 PARTITION_INFO_BB5
12:44:01 : BB ASIC Index : 0x01 APE
12:44:01 : Device Type : 0x01 NAND
12:44:01 : Device Index : 0x00
12:44:01 : Partition Version : 00010000
12:44:01 : Spare : FFFFFFFF
12:44:01 : Num Partitions : 00000003
12:44:01 : Partition 1
12:44:01 : ID : 00000003 COPIEDOS
12:44:01 : Attribute : 00000002 RO
12:44:01 : Start Address : 00420000
12:44:01 : Size : 00E80000
12:44:01 : Partition 2
12:44:01 : ID : 00000004 DEMANDONOS
12:44:01 : Start Address : 012A0000
12:44:01 : Size : 03B80000
12:44:01 : Partition 3
12:44:01 : ID : 00000008 FILESYSTEM
12:44:02 : Attribute : 00000001 RW
12:44:02 : Start Address : 04E20000
12:44:02 : Size : 02E80000
12:44:02 : PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000 00020042000000E800000000000400000002012A000003B800 00000000080000000104E2000002E800009A
12:44:02 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
12:44:02 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
12:44:02 : VPP Enabled by Software
12:44:02 : Using Internal VPP
12:44:02 : StartErase_DCT5...
12:44:02 : BlockLength : 0x4B (75)
12:44:02 : ERASE Blocks : 0x02 (2)
12:44:02 : 0 ERASE_AREA_BB5 0x12
12:44:02 : Block Length : 0x23 (35)
12:44:02 : BB ASIC Index : 0x00 CMT
12:44:02 : Device Type : 0x00 NOR
12:44:02 : Device Index : 0x00
12:44:02 : 0 : 00080000-0073194D
12:44:02 : 1 : 00000000-0005FFFF
12:44:02 : 2 : 001E0000-001FFFFF
12:44:02 : 3 : 00880000-00FEFFFF
12:44:02 : 1 ERASE_AREA_BB5 0x12
12:44:02 : BB ASIC Index : 0x01 APE
12:44:02 : Device Type : 0x01 NAND
12:44:02 : 0 : 00000000-0007FFFF
12:44:02 : 1 : 00080000-000FFFFF
12:44:02 : 2 : 00100000-0025FFFF
12:44:02 : 3 : 003C0000-04E1FFFF
12:44:02 :
12:44:02 : Erase_SendEraseBlock_BB5_NOR
12:44:02 : Task in Progress... Please Wait...
12:44:50 : Status_BB5 STATUS_REQUEST_BB5..
12:44:50 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:44:50 : Block Length : 01
12:44:50 : BB ASIC Index : 00
12:44:50 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:44:50 : Block Length : 0F
12:44:50 : BB ASIC Index : 01
12:44:50 : Device Type : 03
12:44:50 : Device Type : 00
12:44:50 : Num Bad Blocks : 00504A09
12:44:50 : Additional Bad : 00E26126
12:44:50 : Correctable ECC : 0014FCD8
12:44:50 :
12:44:50 : Erase_SendEraseBlock_BB5_NAND
12:44:50 : Task in Progress... Please Wait...
12:44:52 : Status_BB5 STATUS_REQUEST_BB5..
12:44:52 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:44:52 : Block Length : 01
12:44:52 : BB ASIC Index : 00
12:44:52 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:44:52 : Block Length : 0F
12:44:52 : BB ASIC Index : 01
12:44:52 : Device Type : 03
12:44:52 : Device Type : 00
12:44:52 : Num Bad Blocks : 00504A09
12:44:52 : Additional Bad : 00E26126
12:44:52 : Correctable ECC : 0014FCD8
12:44:52 :
12:44:52 : Successfully erased..
12:44:52 : Time Taken to Erase : 00:00:50
12:44:52 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
12:44:52 : ReturnedType : 04 DDR & 2TX
12:44:52 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
12:44:52 :
12:44:52 : Flashing Speed: 15.00 Mhz
12:44:52 : Processing : N73_4.0850.43.0.1_western_C00_PRD_cc.fpsx
12:44:52 : Total blocks to write : 1732
12:44:52 : ================================================
12:44:52 : FBUS Cable RX2 PIN Diagnostics
12:44:52 : INFO: RX2 PIN is OK
12:44:52 : >> CMT Rootkey Hash CERT : NOLO
12:44:52 : >> CMT Rootkey Hash CERT : KEYS
12:44:52 : >> CMT Rootkey Hash CERT : PRIMAPP
12:44:52 : >> CMT Rootkey Hash CERT : PASUBTOC
12:44:52 : >> CMT Rootkey Hash CERT : PAPUBKEYS
12:44:52 : >> CMT Rootkey Hash CERT : UPDAPP
12:44:54 : >> CMT Rootkey Hash CERT : ADL
12:44:54 : >> CMT Rootkey Hash CERT : DSP0
12:45:04 : >> CMT Rootkey Hash CERT : MCUSW
12:45:31 : >> APE Rootkey Hash CERT : KEYS
12:45:31 : >> APE Rootkey Hash CERT : X-LOADER
12:45:31 : >> APE Rootkey Hash CERT : PRIMAPP
12:45:31 : >> APE Rootkey Hash CERT : SOS+LOADER
12:45:32 : >> APE Rootkey Hash CERT : SOS*UPDAPP
12:45:33 : >> APE Rootkey Hash CERT : SOS+UZIP
12:45:33 : >> APE Rootkey Hash CERT : PAPUBKEYS
12:45:33 : >> APE Rootkey Hash CERT : PASUBTOC
12:45:33 : >> APE Rootkey Hash CERT : ADL
12:45:33 : >> APE Rootkey Hash CERT : SOS+XZIP
12:45:33 : >> APE Rootkey Hash CERT : SOS*CORE
12:45:52 : >> APE Rootkey Hash CERT : SOS+ROFS
12:46:41 : >> APE Rootkey Hash CERT : SOS+ROFX
12:46:41 : ContinueFlash_DCT5 Complete
12:46:41 : Status_BB5 STATUS_REQUEST_BB5..
12:46:41 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:46:41 : Block Length : 01
12:46:41 : BB ASIC Index : 00
12:46:41 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:46:41 : Block Length : 0F
12:46:41 : BB ASIC Index : 01
12:46:41 : Device Type : 03
12:46:41 : Device Type : 00
12:46:41 : Num Bad Blocks : 00504A09
12:46:41 : Additional Bad : 00E26126
12:46:41 : Correctable ECC : 0014FCD8
12:46:41 : Continue Flash Complete : : No Error - 0 (0x00)
12:46:41 : Time Taken to Flash : 00:01:49
12:46:41 :
12:46:41 : Processing Image File :
12:46:41 : F:\PRODUCT\RM-133\N73_rofx_4.0850.43.0.1_PRD.V12
12:46:41 : CMT Type : BB5
12:46:41 : CMT Algorithm : BB5 ALGORITHM
12:46:41 : Secondary Sending Speed : 650000Hz
12:46:41 : Algorithm Sending Speed : 6500000Hz
12:46:41 : Program Sending Speed : 6500000Hz
12:46:41 : Message Reading Speed : 100000Hz
12:46:41 : APE PHONE Type : BB5
12:46:41 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG
12:46:41 : APE Supported Hardwares :
12:46:41 : > 17100700
12:46:41 : > 17100701
12:46:41 : > 17100702
12:46:41 : > 17100708
12:46:41 : Number of Blocks : 1698
12:46:41 : Entry Point: 0x0172
12:46:41 : Page Format : -1
12:46:41 : MAX PAGE : 0x00002000
12:46:42 : ProcessPartitionInfo_DCT5...
12:46:42 : Partition Info
12:46:42 : Partition Blocks : 1
12:46:42 : 1 PARTITION_INFO_BB5
12:46:42 : BB ASIC Index : 0x01 APE
12:46:42 : Device Type : 0x01 NAND
12:46:42 : Device Index : 0x00
12:46:42 : Partition Version : 00010000
12:46:42 : Spare : FFFFFFFF
12:46:42 : Num Partitions : 00000003
12:46:42 : Partition 1
12:46:42 : ID : 00000003 COPIEDOS
12:46:42 : Attribute : 00000002 RO
12:46:42 : Start Address : 00420000
12:46:42 : Size : 00E80000
12:46:42 : Partition 2
12:46:42 : ID : 00000004 DEMANDONOS
12:46:42 : Start Address : 012A0000
12:46:42 : Size : 03B80000
12:46:42 : Partition 3
12:46:42 : ID : 00000008 FILESYSTEM
12:46:42 : Attribute : 00000001 RW
12:46:42 : Start Address : 04E20000
12:46:42 : Size : 02E80000
12:46:42 : PARTITION_INFO_REQUEST_BB5 : 64012F3F01010000010000FFFFFFFF00000003000000030000 00020042000000E800000000000400000002012A000003B800 00000000080000000104E2000002E800009A
12:46:42 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
12:46:42 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
12:46:42 : VPP Enabled by Software
12:46:42 : Using Internal VPP
12:46:42 : StartErase_DCT5...
12:46:42 : BlockLength : 0x0E (14)
12:46:42 : ERASE Blocks : 0x01 (1)
12:46:42 : 0 ERASE_AREA_BB5 0x12
12:46:42 : Block Length : 0x0B (11)
12:46:42 : 0 : 03920000-04E1FFFF
12:46:42 :
12:46:42 : Erase_SendEraseBlock_BB5_NAND
12:46:42 : Task in Progress... Please Wait...
12:46:43 : Status_BB5 STATUS_REQUEST_BB5..
12:46:43 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:46:43 : Block Length : 01
12:46:43 : BB ASIC Index : 00
12:46:43 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:46:43 : Block Length : 0F
12:46:43 : BB ASIC Index : 01
12:46:43 : Device Type : 03
12:46:43 : Device Type : 00
12:46:43 : Num Bad Blocks : 00504A09
12:46:43 : Additional Bad : 00E26126
12:46:43 : Correctable ECC : 0014FCD8
12:46:43 :
12:46:43 : Successfully erased..
12:46:43 : Time Taken to Erase : 00:00:00
12:46:43 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
12:46:43 : ReturnedType : 04 DDR & 2TX
12:46:43 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
12:46:43 :
12:46:43 : Flashing Speed: 15.00 Mhz
12:46:43 : Processing : N73_rofx_4.0850.43.0.1_PRD.V12
12:46:43 : Total blocks to write : 1698
12:46:43 : >> APE Rootkey Hash CERT : SOS+ROFX
12:47:36 : ContinueFlash_DCT5 Complete
12:47:36 : Status_BB5 STATUS_REQUEST_BB5..
12:47:36 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:47:36 : Block Length : 01
12:47:36 : BB ASIC Index : 00
12:47:36 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:47:36 : Block Length : 0F
12:47:36 : BB ASIC Index : 01
12:47:36 : Device Type : 03
12:47:36 : Device Type : 00
12:47:36 : Num Bad Blocks : 00504A09
12:47:36 : Additional Bad : 00E26126
12:47:36 : Correctable ECC : 0014FCD8
12:47:36 : Continue Flash Complete : : No Error - 0 (0x00)
12:47:36 : Time Taken to Flash : 00:00:53
12:47:36 :
12:47:36 : Processing Image File :
12:47:36 : F:\PRODUCT\RM-133\N73_userarea_4.0850.43.0.1.U01
12:47:36 : CMT Type : BB5
12:47:36 : CMT Algorithm : BB5 ALGORITHM
12:47:36 : Secondary Sending Speed : 650000Hz
12:47:36 : Algorithm Sending Speed : 6500000Hz
12:47:36 : Program Sending Speed : 6500000Hz
12:47:36 : Message Reading Speed : 100000Hz
12:47:36 : APE PHONE Type : BB5
12:47:36 : APE ALGORITHM : OMAP1710 UNISTORE-II-1.2.1 ALG
12:47:36 : APE Supported Hardwares :
12:47:36 : > 17100708
12:47:36 : Number of Blocks : 164
12:47:36 : Entry Point: 0x011B
12:47:36 : Page Format : -1
12:47:36 : MAX PAGE : 0x00008000
12:47:36 : NO PARTITION DATA FOR THIS IMAGE...
12:47:36 : VPP Enabled by Software
12:47:36 : Using Internal VPP
12:47:37 : StartErase_DCT5...
12:47:37 : BlockLength : 0x0E (14)
12:47:37 : ERASE Blocks : 0x01 (1)
12:47:37 : 0 ERASE_AREA_BB5 0x12
12:47:37 : Block Length : 0x0B (11)
12:47:37 : BB ASIC Index : 0x01 APE
12:47:37 : Device Type : 0x01 NAND
12:47:37 : Device Index : 0x00
12:47:37 : 0 : 04E20000-07C9FFFF
12:47:37 :
12:47:37 : Erase_SendEraseBlock_BB5_NAND
12:47:37 : Task in Progress... Please Wait...
12:47:38 : Status_BB5 STATUS_REQUEST_BB5..
12:47:38 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:47:38 : Block Length : 01
12:47:38 : BB ASIC Index : 00
12:47:38 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:47:38 : Block Length : 0F
12:47:38 : BB ASIC Index : 01
12:47:38 : Device Type : 03
12:47:38 : Device Type : 00
12:47:38 : Num Bad Blocks : 00504A09
12:47:38 : Additional Bad : 00E26126
12:47:38 : Correctable ECC : 0014FCD8
12:47:38 :
12:47:38 : Successfully erased..
12:47:38 : Time Taken to Erase : 00:00:00
12:47:38 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
12:47:38 : ReturnedType : 04 DDR & 2TX
12:47:38 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
12:47:38 :
12:47:38 : Flashing Speed: 15.00 Mhz
12:47:38 : Processing : N73_userarea_4.0850.43.0.1.U01
12:47:38 : Total blocks to write : 164
12:47:48 : ContinueFlash_DCT5 Complete
12:47:48 : Status_BB5 STATUS_REQUEST_BB5..
12:47:48 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5
12:47:48 : Block Length : 01
12:47:48 : BB ASIC Index : 00
12:47:48 : 2 Sub Block ID : 15 STATUS_NAND_OK_BB5
12:47:48 : Block Length : 0F
12:47:48 : BB ASIC Index : 01
12:47:48 : Device Type : 03
12:47:48 : Device Type : 00
12:47:48 : Num Bad Blocks : 00504A09
12:47:48 : Additional Bad : 00E26126
12:47:48 : Correctable ECC : 0014FCD8
12:47:48 : Continue Flash Complete : : No Error - 0 (0x00)
12:47:48 : Time Taken to Flash : 00:00:10
12:47:48 :
12:47:48 : Total Flash Write Time (Flashing Only) : 00:02:53
12:47:48 : Total Flashing Time (Booting + Erase + Flashing) : 00:03:46
12:47:48 :
12:47:48 : FlashInfo.RestartMode : 2
12:47:53 : Waiting for Phone to Go Online...
12:47:54 : Elapsed Time: 1s
12:47:55 : Elapsed Time: 2s
12:47:56 : Elapsed Time: 3s
12:47:57 : Elapsed Time: 4s
12:47:58 : Elapsed Time: 5s
12:47:59 : Elapsed Time: 6s
12:48:00 : Elapsed Time: 7s
12:48:01 : Elapsed Time: 8s
12:48:02 : Elapsed Time: 9s
12:48:03 : Elapsed Time: 10s
12:48:03 :
12:48:03 : MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
12:48:03 : IMEI Plain : 356425028863214
12:48:03 : IMEI Spare : A356425028863210
12:48:03 : IMEI SV : 33564250288632181F
12:48:03 : Phone Model: Nokia N73
12:48:03 : Product Serial Number: CDG024132
12:48:03 : Product Code : 0544952
12:48:03 : Module Code : 0202855
12:48:03 : Basic Production Code: 0537044
12:48:05 : PPM Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia.
12:48:05 : HW Version : 7201
12:48:05 : RFIC Version : 17211721
12:48:05 : DSP Version : scarfe_mc.05wk46v50p2
12:48:05 : AHNE Version : 30
12:48:05 : Retu Version : 15
12:48:06 : Tahvo Version : 22
12:48:06 :
12:48:06 : ******** Reading SimLock ********
12:48:06 : CONFIG KEY: 0000000000000000
12:48:06 : PROVIDER KEY: 2440700000000000
12:48:06 : Provider : AT&T;U.S.A. (3650)
12:48:06 : Counters : 0/3 , 0/10
12:48:06 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
12:48:06 : SP Lock Status : Not Locke
12:48:24 : FACTORY SET TO : Full Factory Set
12:48:25 : OK
12:48:25 : FACTORY SET TO : User Data
12:48:25 : OK
12:48:25 : FACTORY SET TO : Leave Factory
12:48:25 : OK
12:48:25 : FACTORY SET TO : Service Center
12:48:26 : OK
12:48:26 : FACTORY SET TO : Software Upgrade
12:48:26 : OK
12:48:26 : FACTORY SET TO : Production Tune
12:48:26 : OK
12:48:36 :
12:48:36 : Changing Phone Mode... (Wait for 5 seconds)
12:48:36 :
12:48:41 : Successfully set to : Normal
Battery voltage: 4853 mV, current: 111 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 4.453 s
Old 07-04-2011, 12:13   #9 (permalink)
ripon12's Avatar
Member: 1507803
Sonork: 100.1605433
Thanks Meter: 109
note; mobile not opening normally when i put charger and push power button then coming phone startup........................
Old 07-04-2011, 13:30   #10 (permalink)
GSM boy's Avatar
Member: 1375690
Thanks Meter: 92
thats mean 100% hardware problem
try to shake doubble ic
Old 07-19-2012, 08:08   #11 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 102
Never Never apply any hardware change in phone for contact retailer
only write pm without 308 and unlock
if not success again change an other source pm
if not then write again pm file from other source
Hopr you will be success like me
thanks to you all by gsm zaman
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 21:17
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Page generated in 0.58680 seconds with 8 queries
