09-28-2009, 15:02 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | N73 pm120 is not present with zulea Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. IMEI: 351851015176440 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. IMEI: 351851015176440 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked ERROR: PM120 field not present (this is not BB5+ phone) Err no (Jobs): 25030002 please help me the phone says phone startup failed contact retailer |
09-28-2009, 15:09 | #2 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | Code: SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 |
09-28-2009, 15:22 | #3 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | If you don't have any backup so you should write good PM using SX4 auth.Try with this http://rapidshare.com/files/28566151...RM-133.pm.html If this doesn't help you may have to buy new RPL.... |
09-28-2009, 15:36 | #5 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | wrote a modified pm file with hwk and now the phone is alive and working config key is ffffffffff now but the phone says sim card not valid with zulea it says phone is locked and the pm120 is not present in the phone dundytm please help me out to revive this phone |
09-28-2009, 15:38 | #6 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | log with hwk bro : MCU SW : V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. APE Core: V 2.0628.0.0.3 27-07-2006 RM-133 APE Var : V 2.0628.0.0.3-56 27-07-2006 RM-133 Prd.Code: 0545033 Bpr.Code: 0537044 Prod.Sn : CFI492231 HW Vers : 7200 APE HW : 1 APE Adsp: 256 EM VILMA: 15 EM BETTY: 21 RFIC Ver: 17191719 DSP Vers: scarfe_05wk46v30 IMEI : 351851-01-517644-0 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : FFF-FF-FFFFFFFFFFF SL Prof : FFFFFFFFFFFFFFFF SL Count: 00 01 BLK1= L1: CLOS Provider: Not Found |
09-28-2009, 15:44 | #8 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Searching for JAF box ... Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. IMEI: 351851015176440 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Provider Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Counters: 0/3, 0/10 Phone is Locked Read Phone Info OK this is the log with zulea now ?? |
The Following User Says Thank You to dapinderjit For This Useful Post: |
09-28-2009, 15:52 | #10 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | bro when i try to repair sl data with zulea v2.01 it says Searching for JAF box ... Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. IMEI: 351851015176440 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Provider Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Counters: 0/3, 0/10 Phone is Locked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v28.3 26-07-06 RM-133 (c) Nokia. IMEI: 351851015176440 SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Provider Key: FFFFFFFFFFFFFFFF Counters: 0/3, 0/10 Phone is Locked ERROR: PM120 field not present (this is not BB5+ phone) Err no (Jobs): 25030002 |
09-28-2009, 15:55 | #11 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Bro,are you sure that you choose SL 1??!!Couse i think that you are choosing SL 2 from Zulea!!! Check it,pls. |
The Following User Says Thank You to DundyTM For This Useful Post: |
SD repair Button is not Present | Kethey | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-11-2010 08:57 |
blackberry 8520 error unlocking[ MEP IS NOT PRESENT FOR THE MOMENT] | Doniiyor | PolarBox 3 | 6 | 12-20-2009 12:45 |
ERROR: PM120 field not present in 6500s phone (SL2) | Ros_GSM | Nokia Base Band 5 ( BB-5 ) | 5 | 08-31-2009 19:03 |
imei change is not present in new exe. | software zone | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-14-2009 19:46 |
D600 The badge of a battery is not present | FarhadSoft | SWIFT Platform | 0 | 08-30-2006 15:00 |
