N73 Security Test Failed HELP!!! i got this phone with sim card not valid http://img848.imageshack.us/img848/2429/n731.png after i repaired, security test failed is still my problem, http://img34.imageshack.us/img34/179...terrepairs.png trying to mx-key repair.. 1: Repair simlock 2: Super sd and write 1-309pm load from server 3: Repair sd and write 4: Load pm 1-309 super sd and write 5: Write without_npc_data 6: Erase using erase bin 8, 16 and 32mb and write latest version N73 flash files 7: restore imei 8: Still Security test failed, Do again as i mention above 1 to 5 but still same result. i also used this free soft JAF_Nokia_BB5_and_BB5Plus_201_FREE_by_Zulea.zip sad to say same result any idea?? TIA |
write pss ser din post result..;) |
i mean pm 309 sowe..hehe |
use this trick.... http://forum.gsmhosting.com/vbb/f299/simple-trick-remove-cs-bb5-mobi_soft-1085197 hope u get success... |
That trick helped me mobi_soft! Thanks!!! |
bro use this 100% tested http://forum.gsmhosting.com/vbb/f299...ution-1051436/ |
brother,why security code show always failed:confused: look this thread and read carefuly http://forum.gsmhosting.com/vbb/f550...ution-1044092/ |
Bro Try This .......................... 1.Backup Just NPC Data rpl (only npc data) Or recover cert with HWK. 2.Full erase With erase file (BB5Erase_8MBrap)with hwk after erase full flash and ui setting then 3.write backup Just Npc Data Rpl Not hwc ccc data just NPC data. 4.Then repair sd and simlock 5.Then write full pm with pmauth |
Thanks to all reply.. problem solved by mx-key recover cert http://img24.imageshack.us/img24/4239/n73.png http://img43.imageshack.us/img43/4651/unledsql.png http://img835.imageshack.us/img835/7...0120091163.jpg |
