Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-29-2008, 10:53   #1 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
n73 vodafone {3/3 10/10} counter reset & unlocked with BB5Box 0.0.41[REFERENCE]
this unit came from japan marked vodafone.the owner came from manila but they didnt able to unlock the unit and worst it became 3/3 10/10 counter limit.
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-133
Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia.
IMEI: 359738004245694
SP LOCK status:
    Config Key: 2341500000000000
    Block 1: CLOSED  Type 5      Data: 23415F
    Block 2: CLOSED  Type 5      Data: 23415F
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Create autobackup of PM 308
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving autobackup to file: RM-133_359738004245694_Locked_Keycnt_3_Fbuscnt_10__V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin
Counter limit reached. Please write PM 308 backup.
good thing model supported but not the version so i flashed it with mt for the supported version.
Phone is in: Local mode
Model: RM-133 ( N73-1)
	V 05wk47v28.1/22-06-06/RM-133 (c) Nokia.
Production serial number	SBH323066
Product code	0541044
Module code	0202855
Basic production code	0527006
Flash code
Order number
Long production SN
MCU SW V 05wk47v28.1/22-06-06/RM-133/(c) Nokia.
HW 6000
PCI
RFIC  	17191719
DSP   scarfe_05wk46v30
APE SW Core 	V 2.0628.0.0.1/10-07-2006/RM-133/
APE Variant 	V 2.0628.0.0.1-34/10-07-2006/RM-133/
Retu 	15
Tahvo 	21
APE HW 	1
APE ADSP SW 	256
Camera 	1
APE BT 	HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
BB5 PM back Phone is in: Local mode
Backup file: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\RM-133_359738004245694.pm
Processing File:  N73_4.0743.2.8.2_western_C00_PRD_cc.fpsx
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
h3_sam_nand_xsr.fg
NPC 0x180
Variant 0xC0
		Backup: \GSM_35973800424569.r3c
Erase RAP3 [00080000 - 007314D1]
Erase RAP3 [00000000 - 0005FFFF]
Erase RAP3 [001E0000 - 001FFFFF]
Erase RAP3 [00880000 - 00FEFFFF]
Erase APE [00000000 - 0007FFFF]
Erase APE [00080000 - 000FFFFF]
Erase APE [00100000 - 0025FFFF]
Erase APE [003C0000 - 04E1FFFF]
Erase[91.38 MB]...
Waiting response for  320 Sec...in 1.23s
Flash[43.67 MB]...in 88.27s
* * Processed file in 108.45 seconds
Processing File:  N73_userarea_4.0743.2.8.2.U23
Low level format...OK
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
h3_sam_nand_xsr.fg
Erase APE [04E20000 - 07C9FFFF]
Erase[46.50 MB]...
Waiting response for  320 Sec...in 0.83s
Flash[5.28 MB]...in 11.30s
* * Processed file in 29.95 seconds
Extract content...OK
Processing File:  N73_rofx_4.0743.2.8.2_PRD.V71
Boot...
rap3gv3_2nd.fg
RAP3Gv3_algo.fg
helen3_2nd.fg
h3_sam_nand_xsr.fg
Erase APE [03920000 - 04E1FFFF]
Erase[21.00 MB]...
Waiting response for  320 Sec...in 0.50s
Flash[16.14 MB]...in 38.74s
* * Processed file in 48.67 seconds
* * * Phone flashing done in   3:32 minutes
 Post Flash serial tunning of phone....
Pooling mode for full factory set...
V 05wk47v50.5/16-10-07/RM-133 (c) Nokia.
Factory Default Settings...OK
Module code	0202855
Flash code
Order number
Long production SN
MCU SW V 05wk47v50.5/16-10-07/RM-133/(c) Nokia.
HW 6000
PCI
RFIC  	17191719
DSP   scarfe_05wk46v50
APE SW Core 	V 4.0743.2.8.2/16-11-2007/RM-133/
APE Variant 	V 4.0743.2.8.2-71/16-11-2007/RM-133/
Retu 	15
Tahvo 	21
APE HW 	1
APE ADSP SW 	256
Camera 	1
unlocking process with bb5 box 0.0.41
Type: RM-133
Version: V_05wk47v50.5_16-10-07_RM-133_(c)_Nokia.
SP LOCK status:
Cable wrong codes counter: 14 wrong tries from max. 10 tries
XLX DW: 0B7A9FF3
Checking if model/version is supported for reset counters ...
Checking if model/version is supported for unlock ...
Please connect testpoints (DATA must be connected on AD8)
Testpoints connected OK
Keep Testpoints connected until procedure finish!
Reset FBUS counter ...
Try reset SP counters ...
Try number (Counter reset): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 0C
Reading again SP Locks counters ...
FBUS counter reset fail. Please try again.
COUNTER RESET
Type: RM-133
SP LOCK status:
XLX DW: 0B7A9FF3
Response byte: 08
Try number (Counter reset): 2
Response byte: 08
Cable wrong codes counter: 0 wrong tries from max. 10 tries
FBUS counter reset succesfull
UNLOCKING PROCESS
Type: RM-133
SP LOCK status:
Reset phone ...
Saving autobackup to file: RM-133_359738004245694_Locked_Keycnt_3_Fbuscnt_0__V_05wk47v50.5_16-10-07_RM-133_(c)_Nokia..bin
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 00
Reading again SP Locks ...
SP LOCK status:
    Block 1: OPEN    Type 5      Data: 23415F
    Block 2: OPEN    Type 5      Data: 23415F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Phone unlocked succesfull
Old 04-29-2008, 10:55   #2 (permalink)
Member: 686489
congratulation..
keep it up sir....
** Discussion about BB5 v0.0.4.1- 3/3 10/10 FBUS counter reset abdooo_19888 BB5BOX 62 04-03-2008 17:31
** BB5BOX Updates Only Here - BB5 v0.0.4.1 - 3/3 10/10 FBUS counter reset ** MANOLE BB5BOX 24 03-29-2008 23:30
** Discussion about BB5 v0.0.4.0 - 3/3 10/10 FBUS counter reset ** snsoftkiller BB5BOX 62 03-25-2008 14:03
5500 sucessfully flashed via USB for upgrade to 3,55 for unlock with bb5box Rezn Universalbox 0 01-03-2008 22:14
NOKIA 6085 SUCCSEFULLY UNLOCKED WITH BB5box thanks to raskal & his team SHANU BB5BOX 0 10-11-2007 11:51
Page generated in 0.25127 seconds with 11 queries
