Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 04-30-2009, 19:17   #1 (permalink)
Member: 125350
Thanks Meter: 13
n82 config 00000000000000000
nokia n82 goes off after few minutes n config key is 000000000000000..solution pls
Old 05-01-2009, 07:11   #2 (permalink)
Member: 996684
Thanks Meter: 46
be more specific about how did it happen. did u unlock it?
Old 05-01-2009, 07:19   #3 (permalink)
rose4u86's Avatar
Member: 500858
Sonork: 1589054
Thanks Meter: 392
_SL3 /SL2 FREE Solution for Nokia Software Demaged Phones
This Is tested by us for SL3 & SL2 Phones & it Works 100 %.
if phone shows any of the followings after Unlock attempt
.contat servicre
.phone startup failed
.failed to read
.RPL SL3 PHONES NOT SUPPORTED
Do NOt worry because you do not need RPl or SX4 and would n't cost you anything
You need to have Mt Box
and follw these steps
1)Connect the Phone to MT Box
2)Select PM Edit option
3)Type 120 in 1st field and 0 in 2nd field
4)You will see some information in window Simply Select All and delete it
5)You should be having Same network Locked Phones's data
6)Simply copy and paste the information in window
7)Press Write
Its All Done :-) ;-)
In some SL2 Phones you need to Unlock again it will be ok
_________________________________________________ ______________
(1) no need Network Operato provider cod !!! your phone read it in the 120pm.
[120]
0=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXX
1=2CD46AFDD3A19B389B5D5509C79713599E3ED237F6E0AF57 1B2EBB35FE3B2A1210F484B1051B048E34CF896A3E556D569A E8F38A4670677EDF0C278088A07DFD29106
5B5602B6C8A7
60D33AE81892430
2=AE1E1422590F2B91DCFD32506BDB177C0D81EE25
(2) edit pm 120pm,
[120]
0=800000000000000223420000000000000018020000000000 0028000001FFFFFF003C000001FFFFFF000000007FFF6F07FF FFFFFFF800005003000502000
000007FFF6F07FFFFFFFFF80000530300050223420F23594FF FFF
1=2CD46AFDD3A19B389B5D5509C79713599E3ED237F6E0AF57 1B2EBB35FE3B2A1210F484B1051B048E34CF896A3E556D569A E8F38A4670677EDF0C278088A07DFD291065
B5602B6C8A760D33AE81892430
The Following User Says Thank You to rose4u86 For This Useful Post:
I have backup but CONFIG KEY: 000000000000000 JAVA Good Nokia Base Band 5 ( BB-5 ) 13 11-26-2009 22:01
n82 config 0000000000000000 snowchild_2007 Gsmfather The Wholesale Unlocking Database 5 09-30-2009 23:27
hi iwant repair n82 CONFIG KEY: 0000000000000000 momen_osman Nokia Base Band 5 ( BB-5 ) 13 06-17-2009 09:04
FAID=000000000000000 Ebi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-23-2002 10:34
Page generated in 0.33303 seconds with 8 queries
