03-12-2010, 20:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: EGYPT Age: 53
Member: 157001 Status: Offline Sonork: 100.1585825 Thanks Meter: 45 | n82 nokia onlly how r u i have n82 was nokia only i have made to it allthink like enofiles and erase but no success and there is his info with jaf so plz help me. Powering the phone... Reading... MCU SW version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia PCI version: RFIC version: 17141714 DSP version: sharaku.ICPR62_09w10p1 Retu version: 15 Tahvo version: 22 Production serial number: 0 Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 358082013011479 IMEI spare to net: 3A 85 80 02 31 10 41 07 IMEI SV to net: 33 85 80 02 31 10 41 07 F9 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-313.ini Saved INI not found, loading INI list... Setting local mode... Failed! Aborting! Done! |
03-12-2010, 20:53 | #2 (permalink) |
Registered User Join Date: Apr 2007 Location: ==**Syria**== Age: 44
Member: 493205 Status: Offline Sonork: 100.1581647 Thanks Meter: 526 | i have same problem and solved by erase it with rapid_uni erase file ... by hwk then flash it with low version .....but before do any thing mack backup . try and post result.... |
03-12-2010, 21:47 | #3 (permalink) | |
Member: 157001 Status: Offline Sonork: 100.1585825 Thanks Meter: 45 | Quote:
thkx i will try and post result and this is the info with mxkey Phone Type: RM-313 (Nokia N82) SW Version: V 06wk41v64.24 05-11-09 RM-313 (c) Nokia Imei plain: 35808201301147-9 Product Code: 0553758 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358082013011479 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF | |
03-12-2010, 23:43 | #6 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Earth
Member: 426389 Status: Offline Thanks Meter: 2,356 | Quote:
B.R., Renegade | |
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] | mariaperezkkk | Cyclonebox | 19 | 03-30-2010 00:04 |
E1105T emergency calls onlly | zeerik | UST Pro II | 8 | 03-14-2010 09:57 |
3220 onlly local mode..... | lucik | Nokia Hardware & Hardware Repair | 1 | 06-20-2006 09:29 |
alcatel 311after unlock problem .warning sos calls onlly HELP!!! | ssulkaa | BF, BG, TH, BHx Series | 1 | 09-26-2002 02:35 |
